Author Topic: What did you buy today? Post your latest purchase!  (Read 2801024 times)
wkb, jhenderson0107 and 18 Guests are viewing this topic.
Online Bud
« Reply #12075 on: March 23, 2023, 05:45:33 am »
How do you "pull" a thumb switch? (The one on top between light indicators)
One can only imagine it’s some spring loaded self locking toggle switch.
I’ve never seen such a beast.  :-//
https://www.ckswitches.com/blog/posts/2021/december/7000-series-locking-lever-toggle-switch-with-grip-tip-actuator/
Oh, ok, so the tip is spring loaded and you indeed pull the tip then move it. Interesting.
Offline EEVblog
« Reply #12076 on: March 23, 2023, 08:44:42 am »
Picked up a nice older Jamo S606 speaker set, had a look at the crossovers
https://flickr.com/photos/eevblog/albums/72177720306884129
Offline coppercone2
« Reply #12077 on: March 23, 2023, 09:30:50 am »
I use Jamos too, I replaced the capacitors with foil caps, but mine were way older (point to point)
Online wkb
« Reply #12078 on: March 23, 2023, 09:42:09 am »
[ Specified attachment is not available ]
Like on the attached pics. This switch lives in my Efratom Rb frequency reference btw.
« Last Edit: March 23, 2023, 09:45:21 am by wkb »
« Reply #12079 on: March 23, 2023, 10:02:23 am »
Standard locking switch, has been a staple of avionics for decades, where you need a switch that is easy to change state, but accidental operation is hard, but you can still do it while feeling by touch and wearing gloves.
Offline unknownparticle
« Reply #12080 on: March 23, 2023, 03:31:26 pm »
Thought I'd try some Pomona test leads.  Already have a few Probe Master sets, so this should be an interesting comparison.
DC coupling is the devils work!!
Offline McBryce
« Reply #12081 on: March 23, 2023, 03:42:20 pm »
As far as I know, Pomona are the manufacturer for most Fluke probes. So if you have any newer original Fluke probes they should be identical.
McBryce.
« Reply #12082 on: March 23, 2023, 05:20:03 pm »
I do but these don't look the same, and these are much cheaper than Fluke!  Also, are any Fluke leads silicone?
Offline Black Phoenix
  • Country: hk
« Reply #12083 on: March 23, 2023, 05:41:33 pm »
Yes, the TwistGuard one. Equivalent to the top picture but the grey in yellow - TL175.
Also the TL221, TL222, TL224, TL71(second picture but Fluke branded) and TL76 have their leads in Silicone.
Offline McBryce
« Reply #12084 on: March 23, 2023, 06:35:07 pm »
Yes, many of the new probes are now silicon.
McBryce.
Offline Kasper
« Reply #12085 on: March 23, 2023, 08:51:38 pm »
Doesn't seem electronics related but I was getting burnt out from electronics work and hadn't had a bike for 10 years.  This is helping me appreciate work again.  Also bought a miter saw as I plan to re-organize my garage to make room for the bike.  When I do that, I'll build cabinets around the saw and wanted to build around a good saw instead of the old cheap one that I wanted to replace some day.  It comes with a "bright LED light for precision cut alignment".
The following users thanked this post: Ed.Kloonk
Online Martin72
  • Testfield Technician
« Reply #12086 on: March 23, 2023, 09:45:16 pm »
A new USB microphone, UMIK-2 (32bit ADC)...
Offline Ed.Kloonk
  • Cat video aficionado
« Reply #12087 on: March 23, 2023, 10:14:02 pm »
Baarrrrrrpppp!
And that goes for the drop saw too! Have fun.
iratus parum formica
Offline SiliconWizard
« Reply #12088 on: March 23, 2023, 10:23:14 pm »
I have a couple USB audio streaming boards from miniDSP (XMOS-based) which are pretty cool. They have a USB 2 (UAC 2) interface and expose up to 10 I2S interfaces.
Makes it great for making your own audio interfaces with your own front-ends and ADCs/DACs.
Online PlainName
  • Country: va
« Reply #12089 on: March 23, 2023, 10:37:20 pm »
PriPrinter
As a long-time (very long) user of Fineprint, PriPrinter has a few better options and a bit easier to work with.
For those not in the know, these are virtual printers (for Windows) which you would set as the default printer. They then intercept any printouts and let you view what might have been 200 blank pages before you commit them to actual paper. You can force duplex, multiple pages per paper page, vice versa (print posters using A4 sheets) save to PDF, edit, redact, letterheads, etc. Saves a ton of paper and ink.
Offline Ground_Loop
« Reply #12090 on: March 23, 2023, 10:37:55 pm »
Nice bike.  I have the KTM 500 XCW version.  Easily hits 90MPH and Torque is unstoppable.
There's no point getting old if you don't have stories.
Offline Gary350z
« Reply #12091 on: March 24, 2023, 12:16:24 am »
Very nice bike. Dual purpose bikes are very fun.
What exactly is happening on the sticker on the side panel just below the seat?
Offline Ed.Kloonk
« Reply #12092 on: March 24, 2023, 12:25:44 am »
I'd call it fair warning.
Offline Kasper
« Reply #12093 on: March 24, 2023, 06:10:23 am »
Great bikes.  Whole nother level compared to my old DRZ 400.  I couldn't believe how quickly it gets to that speed.
Offline Kasper
« Reply #12094 on: March 24, 2023, 06:14:40 am »
Specially now when the dirt is up in the hills and still covered in snow, it's nice to have pavement as an option.
Sticker came with the bike: 'Warning, this vehical makes frequent stops'.
« Reply #12095 on: March 24, 2023, 03:11:16 pm »
Haven't had a dirt bike since riding MX in the 80's but I do still ride street bikes and have done since I was a teenager, a long time ago!
Mainly have classic bikes, including a Velocette and a Vincent Rapide, currently my most modern bike is a 2005 MV Agusta Brutale, my second ever only in line 4!!
Biking is therapy to mitigate against modern life and one of life's best forms of recreation.
Offline Kasper
« Reply #12096 on: March 24, 2023, 03:18:18 pm »
It's a great contrast to my favorite winter sport, snowboarding.  So nice to bike for hours after getting used to having to stop and sit on a chairlift every 20 minutes.
Online BillyO
« Reply #12097 on: March 24, 2023, 08:28:31 pm »
Didn't buy it today, but since we're all talkin' bikes 'n' stuff...
Yeah, it's nice to take a break from the o-scopes for a while.
Bill  (Currently a Siglent fanboy)
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
Offline Kasper
« Reply #12098 on: March 24, 2023, 08:33:14 pm »
It seems KTM/Husqy is the forums preferred brand  :-+
« Reply #12099 on: March 25, 2023, 01:29:42 pm »
Had one Husky and one KTM in my life,  a 1988 WR400 and a 1984 250MX.  The KTM still had drum brakes!  The WR was a forest rocket, I should never have sold it!
