AlfBaz, profanum429 and 26 Guests are viewing this topic.
Hi, I recognize the seller's pictures (F1*****), I bought from him once.The shipping is always high, but the parcels are rock solid and the equipment is very well protected.
Quote from: Falkra on December 11, 2019, 02:27:51 pmHi, I recognize the seller's pictures (F1*****), I bought from him once.The shipping is always high, but the parcels are rock solid and the equipment is very well protected.Is that the seller with the stupid prices for ancient crap? They refused my overly enthusiastic offer once, four months later they were still trying to push it for significantly less. Luckily I had come to my senses and scored better kit for less.
Just got these two Symmetricom 58502A.Perfect condition. Will be used with GPSO primary and rubidium clock secondary to distribute the 10MHz ref to the bench instruments.
More WEA for me Plunge Saw and some extra track to keep me on the straight and narrow at least for timber cutting unlike the operator As for the rest of todays spendings Bah Humbug Christmas shopping SUCKS
Quote from: beanflying on December 13, 2019, 04:43:47 amMore WEA for me Plunge Saw and some extra track to keep me on the straight and narrow at least for timber cutting unlike the operator As for the rest of todays spendings Bah Humbug Christmas shopping SUCKS Track saws are great for working with sheet goods. You'll love it!-Pat
Quote from: Cubdriver on December 13, 2019, 07:42:15 amQuote from: beanflying on December 13, 2019, 04:43:47 amMore WEA for me Plunge Saw and some extra track to keep me on the straight and narrow at least for timber cutting unlike the operator As for the rest of todays spendings Bah Humbug Christmas shopping SUCKS Track saws are great for working with sheet goods. You'll love it!-PatI was looking at buying a Triton or Contractors Table saw but then did some more research and youtube watching. Much safer for the fingers and it became clear keeping the sheet locked down and moving the saw makes more sense without in and out feed tables/horses taking up a heap of floor space.
Quote from: richnormand on December 13, 2019, 12:25:33 amJust got these two Symmetricom 58502A.Perfect condition. Will be used with GPSO primary and rubidium clock secondary to distribute the 10MHz ref to the bench instruments.Awesome!Before using them swap the caps on the power supplies(this is not optional if you want them to live).
Also bought an adjustable wrench from handtoolrescue.com. Got my son one for Christmas and just bought one for myself.
Quote from: TheSteve on December 13, 2019, 04:51:17 amQuote from: richnormand on December 13, 2019, 12:25:33 amJust got these two Symmetricom 58502A.Perfect condition. Will be used with GPSO primary and rubidium clock secondary to distribute the 10MHz ref to the bench instruments.Awesome!Before using them swap the caps on the power supplies(this is not optional if you want them to live).Will do. Thanks for the heads-up.Opened both as I was removing the usual stickers and glue plague. Today I undid the PSU on both and the caps looked OK (no bulge or leaks) and they tested OK for value ( one is about 10% low) and ESR OK for all.Will keep an eye out for this as I order replacements from Mouser.Are the caps going bad a known issue for the Symmetricoms or good prctice in general for older caps?
Quote from: GreyWoolfe on December 13, 2019, 11:05:59 pm Also bought an adjustable wrench from handtoolrescue.com. Got my son one for Christmas and just bought one for myself.Quite a coincidence, I bought one of those earlier in the year First one though, was disappointing. It was poorly finished in some places and the handle section was distorted. The guy was golden though, he replaced it without question within a week. The replacement is very good.
Just got a Fluke 87V, described as boxed, new and unused, for £160.00 UK. It does indeed look as new but the most recent date I can find on any of the included docs is 2007. Would anyone be able to date it from the S/No, which is 96350419?
Quote from: unknownparticle on December 13, 2019, 11:09:55 pmJust got a Fluke 87V, described as boxed, new and unused, for £160.00 UK. It does indeed look as new but the most recent date I can find on any of the included docs is 2007. Would anyone be able to date it from the S/No, which is 96350419?The sticker outside the box have the manufacturing date. Plus you can check the firmware in the DMM:From turned off:- Press and Hold: AutoHOLD- Switch to DC Voltage on the selector and the screen will show the firmware revision - Last one is v3.03Since the serial no is also greater than 19470148, it will have new generation LCD display and GSM fix installed. - https://www.eevblog.com/forum/testgear/fluke-87v-screen-goes-crazy-with-wifi-cell-phone-signals/
Quote from: richnormand on December 13, 2019, 08:57:07 pmQuote from: TheSteve on December 13, 2019, 04:51:17 amQuote from: richnormand on December 13, 2019, 12:25:33 amJust got these two Symmetricom 58502A.Perfect condition. Will be used with GPSO primary and rubidium clock secondary to distribute the 10MHz ref to the bench instruments.Awesome!Before using them swap the caps on the power supplies(this is not optional if you want them to live).Will do. Thanks for the heads-up.Opened both as I was removing the usual stickers and glue plague. Today I undid the PSU on both and the caps looked OK (no bulge or leaks) and they tested OK for value ( one is about 10% low) and ESR OK for all.Will keep an eye out for this as I order replacements from Mouser.Are the caps going bad a known issue for the Symmetricoms or good prctice in general for older caps?The specific issue is the MAP55-4001 that is often used in the 58502/58503. The worse cap is a 10-33 uF located right beside a transistor on the input side. On later revs of the supply they remote the capacitor with flying leads. When that one starts to go bad it will take other components with it. It is a pretty quick job to swap all the caps, well worth it for something that runs 24/7 and that you want a clean signal from.
Quite interesting; I have a 87V serial number 1056xxxx (firmware 3.01) and did the cellphone test around it in various ways. No interference either when calling or when transferring data via 2.4GHz Wi-Fi.I wonder if it was inherent to the frequencies used by 2/2.5G GSM and not the 4G/LTE used by modern smartphones.
Quote from: unknownparticle on December 13, 2019, 11:14:36 pmQuote from: GreyWoolfe on December 13, 2019, 11:05:59 pm Also bought an adjustable wrench from handtoolrescue.com. Got my son one for Christmas and just bought one for myself.Quite a coincidence, I bought one of those earlier in the year First one though, was disappointing. It was poorly finished in some places and the handle section was distorted. The guy was golden though, he replaced it without question within a week. The replacement is very good.I find it odd that you had a problem. I thought that they were CNC machined on a mill. Nice to know he made it right quickly.
Quote from: GreyWoolfe on December 14, 2019, 01:10:55 amQuote from: unknownparticle on December 13, 2019, 11:14:36 pmQuote from: GreyWoolfe on December 13, 2019, 11:05:59 pm Also bought an adjustable wrench from handtoolrescue.com. Got my son one for Christmas and just bought one for myself.Quite a coincidence, I bought one of those earlier in the year First one though, was disappointing. It was poorly finished in some places and the handle section was distorted. The guy was golden though, he replaced it without question within a week. The replacement is very good.I find it odd that you had a problem. I thought that they were CNC machined on a mill. Nice to know he made it right quickly.Same occured to me but then I've seen problems with CNC made mass produced car and motorcycle parts. He told me to keep the defective one, which does work despite the problems, but the distortion is quite obvious. Actually, I have one of the original wrenches too, makes and interesting comparison.
