Author Topic: What did you buy today? Post your latest purchase!  (Read 2837428 times)
0 Members and 23 Guests are viewing this topic.
« Reply #4175 on: October 06, 2017, 06:15:36 pm »
Heres my latest, arrived today and sourced via Ebay. Had a rattle when received so opened it up and checked, nut had come of, no sign of the nut any where so fitted new one, powered up and is working just fine. Just have to remember when using it, that it only does DC.
Will give it a lick of black paint on the cover, will be almost as good as new then.  :-+
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #4176 on: October 06, 2017, 06:25:22 pm »
Beautiful!
-Pat
Offline Gyro
« Reply #4177 on: October 06, 2017, 06:35:24 pm »
+1
An interesting way of (not) labeling the ranges though. Very minimalist!
Best Regards, Chris
« Reply #4178 on: October 06, 2017, 06:44:20 pm »
Agreed, but easy to work out, increments in multiples of 10. But what great ranges they are, nA, uA and up to 1G ohm, nicely extends the measuring capabilities of my other meters.
Offline bitseeker
« Reply #4179 on: October 06, 2017, 08:49:02 pm »
I didn't buy them, I saved them from the dumpster.
I'm lucky today :)
A nice save, indeed! Does the 34970 have the DMM option? Any modules in the slots?
I'm still looking for a HP 3437A going for little money because I've missed the time the HP 3437A were thrown out of the labs in numbers..  :palm:
Rémi and URI, what are you using (or going to use) the 3437A for? A companion to an analog scope? I got some stuff a while ago that included that model, but I'm curious what some modern use cases would be for it.
Offline nanofrog
« Reply #4180 on: October 06, 2017, 08:55:58 pm »
I'm lucky today :)
Yes you are. ;D
Oh, and you win today's YOU SUCK award.  :-+
The following users thanked this post: Rémi, Mr. Scram
Offline GreyWoolfe
  • NW0LF
« Reply #4181 on: October 06, 2017, 09:39:30 pm »
I wish I could get lucky enough to win the YOU SUCK award.
Offline chriswebb
« Reply #4182 on: October 06, 2017, 10:06:12 pm »
Hey blueskull, how are you liking that lecroy mercury t2?
Always learning. The greatest part of life is that there will always be more to learn.
Offline wasyoungonce
« Reply #4183 on: October 07, 2017, 12:33:26 am »
I got to stop living in the wrong dumpsters..... :-//
I'd forget my Head if it wasn't screwed on!
« Reply #4184 on: October 07, 2017, 01:10:30 am »
:-DD :-DD :-DD
Love it.
Offline URI
« Reply #4185 on: October 07, 2017, 04:25:11 am »
Yep.
I have "only" an analog scope without storage capabilities nor readout. Albeit a little old fashioned a 3437A would be a nice addon.  ;D
If I find a decent modern digital scope at an affordable price (has to be one with a "digital phosphor"-feature, I don't want to get behind the display capabilities of an analog scope) before bargaining a 3437A I will most likely not look for one any further.. -If TEA doesn't get me to get one anyway.  |O
« Last Edit: October 07, 2017, 04:33:20 am by URI »
Offline bitseeker
« Reply #4186 on: October 07, 2017, 04:56:46 am »
Sounds good. I've had a Kikusui COS5021 scope for ages. Its focus got progressively worse, is now beyond the range of the adjustment pots, and I haven't found a good source for a service manual. Anyway, my 3437A will be its companion, eventually.
Offline TheSteve
  • Living the Dream
« Reply #4187 on: October 07, 2017, 06:16:21 am »
Bird 8322 200 watt 30 dB attenuator.
It is only rated to 500 MHz but could be used well above that.
Tough to argue for $75 shipped(It is 19 pounds).
VE7FM
Offline Cubdriver
  • Nixie addict
« Reply #4188 on: October 07, 2017, 06:31:22 am »
Nice!!  And it looks like it hasn't been beaten to hell and dragged behind a freight train, either.  You done good!   :-+ :-+
-Pat
Offline daqq
  • Country: sk
    • My site
« Reply #4189 on: October 07, 2017, 06:43:08 am »
I'm lucky today :)
I'm not jealous at all... (makes grumpy noises)
Offline blackbird
  • Ooohhhh, what does this button do???
« Reply #4190 on: October 07, 2017, 06:27:55 pm »
Not EE related but at least something technical, just received a cauge to measure metric and Withworth threads.
Offline MadTux
« Reply #4191 on: October 07, 2017, 11:46:03 pm »
Nice dumpster you have, may I ask where it is?  ;D ;D ;D
HP-3456A is my favorite DVM btw. Extremely well designed and easy to repair, without any unobtainable custom parts.
Offline AF6LJ
« Reply #4192 on: October 08, 2017, 05:45:23 pm »
Nice score, it is not hammered up.
Sue AF6LJ
Offline AF6LJ
« Reply #4193 on: October 08, 2017, 05:54:13 pm »
Playing catch up...
The last two swap meets I have gone to yielded this Atlas 350XL and yesterday the Atlas 350PS
The Atlas 350XL needs some work, low RX sens, and very little TX power out. This is good news because what is most likely wrong is common to both RX and TX, that means the 200W PA is good. The 350XL is clean inside but missing one shield. (I'll worry about that later).
The power supply was cheap enough, and was clean on the outside, the inside looks like it was store in a chicken coop...
This pair is a project for next year, there is already too many projects in the cue for this year... Another HP-8569, A Tek 2440, and my Motorola Micom 2ET HF radio.
Sue AF6LJ
« Reply #4194 on: October 08, 2017, 05:54:58 pm »
Just wish I was able to find these dumpsters with decent stuff in them. They must exist somewhere but where is the question.................. :-//
Offline AF6LJ
« Reply #4195 on: October 08, 2017, 05:59:58 pm »
Good luck with that, I haven't found any since 1987.  :'(
Sue AF6LJ
« Reply #4196 on: October 08, 2017, 06:46:07 pm »
Meaning that 1987 was the last time you had any luck or was that the first time you went looking? :-//
Offline AF6LJ
« Reply #4197 on: October 08, 2017, 06:59:19 pm »
That was the last time I had any luck.
Two spools of Teflon coax.
Sue AF6LJ
Offline bitseeker
« Reply #4198 on: October 09, 2017, 01:47:04 am »
I think Dave took all the best dumpsters. :-DD
Offline nanofrog
« Reply #4199 on: October 09, 2017, 03:32:29 am »
In Sydney, you may well be right.
But the very best ones I'm aware of are in Silicon Valley.  >:D
Unfortunately I've not been back there since '96, so they may be a lot leaner now.
