Author Topic: What did you buy today? Post your latest purchase!  (Read 2837049 times)
0 Members and 27 Guests are viewing this topic.
Offline jonpaul
« Reply #11475 on: August 28, 2022, 09:46:16 pm »
Bonjour à tous, À vide grenier (neighborhood street sales) in Paris, Cour de Vincennes,
Set of precision tweezers, screwdrivers, millimètre hex keys, , files, €5
500V insulation and earth resistance tester ( "Megger") 6x AA battery, in hard field case, like a single range megohm meter with 500V DC applied....must be 40 years old, working fine, in calibration €5, listed on UK distribution site, 700£!
Used to check cables, insulation,  earth resistance.  I just tried it on a 4 conducteur telecommunications cable, 7m long, I can read the wire resistance of 0.5 ohm, the insulation is infinite at 500 V.
Schlumberger/Emertec/ Metrohm, Believed made in Germany or UK.   Any other information appreciated.
bon soirée
Jon
« Last Edit: August 29, 2022, 07:53:04 am by jonpaul »
Jean-Paul  the Internet Dinosaur
The following users thanked this post: pardo-bsso
Offline gamalot
  • Correct my English
    • Youtube
« Reply #11476 on: August 29, 2022, 02:10:59 pm »
I put this Iwatsu Bringo II oscilloscope in my collection because I like its small size, but when I first got it I found it was smaller than I thought. Not only that, but it has another thing that amazes me, which is how fast it is to boot up! I took a short video and put it on YouTube.
« Last Edit: August 29, 2022, 02:14:00 pm by gamalot »
The following users thanked this post: thm_w, edavid, BU508A, Peter_O
Offline PlainName
  • Country: va
« Reply #11477 on: August 29, 2022, 04:56:28 pm »
That is nice  :-+
Offline capt bullshot
« Reply #11478 on: August 29, 2022, 05:57:02 pm »
That's a neat scope. And it should say "Bingo" instead of "Bringo" at the splash screen  ::)
The following users thanked this post: CatalinaWOW
Online SiliconWizard
« Reply #11479 on: August 29, 2022, 07:07:33 pm »
OK, I admit that was fast!
Offline jonpaul
« Reply #11480 on: September 01, 2022, 06:53:36 am »
bonjour à tous
Both Iwatsu and Yokogawa digital scopes are very fine quality and specifications, easy to use interface.
We had Yokogawa DL1520, 1740, 7440 since 1990s, highly recommended.
Jon
Offline jonpaul
« Reply #11481 on: September 01, 2022, 07:01:40 am »
Fowler digital caliper, mm, in, ft, new in pouch, excellent battery life, but plastic not metal....
 $5 NIB, at a USA CL contractor sale....
Much better than the Chinese clones of Japanese mitutoyo calipers....
The Fowler is sold for $50 on Amazon etc.
Very useful and light weight
Jon
« Reply #11482 on: September 01, 2022, 07:18:22 am »
I've bought this nice little gadget:
a VOLTCRAFT MB-701 battery measuring adapter
https://www.ebay.com/itm/403649748388
Edit:
More information can be found here.
« Last Edit: September 02, 2022, 10:17:13 pm by BU508A »
The following users thanked this post: Mortymore
« Reply #11483 on: September 01, 2022, 07:22:00 am »
https://youtu.be/IxWcyei_6pc
It is booting faster than the fan reaching its final spinning velocity.  :-DD
« Reply #11484 on: September 01, 2022, 07:34:16 am »
That don't impress me much, my TDS220 / TDS2024 scopes do this all the time ;)
« Reply #11485 on: September 01, 2022, 07:44:54 am »
What can I say, I'm just easily entertained.   :-DD
Offline gamalot
    • Youtube
« Reply #11486 on: September 01, 2022, 08:58:45 am »
I'm wondering why the oscilloscope manufacturers don't add a quick boot option like the PC manufacturers put in the BIOS settings.
Offline PlainName
  • Country: va
« Reply #11487 on: September 01, 2022, 11:40:19 am »
Quote from: BU508A
That's a clever little thing.
Offline Gary350z
« Reply #11488 on: September 01, 2022, 12:16:14 pm »
I have wanted something like this for a long time. I had no idea someone made such a thing.
But Conrad does not ship to USA:(
Offline dl6lr
« Reply #11489 on: September 01, 2022, 12:18:14 pm »
Oh, did I enable you?
Online PA0PBZ
« Reply #11490 on: September 01, 2022, 12:37:12 pm »
A small piece of thin double-sided unetched pcb and you're done.
« Reply #11491 on: September 01, 2022, 12:41:18 pm »
Let me know (PM) if I can help you.
« Reply #11492 on: September 01, 2022, 12:44:01 pm »
Yes, thank you very much. :D
Offline PlainName
  • Country: va
« Reply #11493 on: September 01, 2022, 02:04:30 pm »
Have to be very thin. I think that one works because it's a flex PCB with stiffener, which is really very thin indeed.
Offline Zoli
  • Grumpy old men
« Reply #11494 on: September 01, 2022, 02:21:42 pm »
Copper tape + Kapton tape + stiffener sounds like a solution to me; I will try it. Alternatively, you can try 0.8mm copper clad; it would be interesting to know the thickness of the original  ;)
Offline gamalot
    • Youtube
« Reply #11495 on: September 01, 2022, 02:35:53 pm »
0.1mm nickel (or nickel plated) strips are easy to find as many people use them for lithium battery packs.
Offline wkb
« Reply #11496 on: September 01, 2022, 03:24:01 pm »
So does my Agilent 54641D. Given that one has a CRT, it is the CRT warmup that dictates when you can claim "it is up". No surprise really, the 68020 CPU is fast enough, and the whole firmware (I flashed it) fits on a single 1.44MB floppy disk.
No Windoze bloatware  :-+  :-+
Offline McBryce
« Reply #11497 on: September 01, 2022, 04:23:52 pm »
A piece of thin plastic (overhead projector foil) with copper tape on either side will probably give you the best results.
McBryce.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #11498 on: September 01, 2022, 05:07:49 pm »
Although purchased a few months ago, the package finally arrived yesterday: a Brüel & Kjær 1501.
The following users thanked this post: exor, Trader
Offline PlainName
  • Country: va
« Reply #11499 on: September 01, 2022, 05:42:38 pm »
Maybe. Would it be rigid enough? Only one way to find out... :)
