Author Topic: What did you buy today? Post your latest purchase!  (Read 2830184 times)
austfox and 25 Guests are viewing this topic.
Online DiTBho
« Reply #12450 on: September 10, 2023, 03:02:53 pm »
Brand new Campagnolo C-Record/8SP hubs for a new typology of self-assembled wheels: class retro vintage!
  • classic premium hubs
  • modern rims, modern aluminium alloy but not aero style, height < 30 mm
The first and second generation of C-Record hubs are the best ever made! Sure, they came with cones and balls require periodic inspection (every 5000Km) and grease changes (every 10000Km), they suffers terribly in case of rain, and if you leave the house and it starts to rain cats and dogs, as soon as you get home they absolutely need to be dried (with a hairdryer set to minimum) and lubricated, and there is also an "oil port"  as well as there is a "out hole" on both dust cover crowns to let out, thanks to centrifugal force, any water that accidentally enters, so you also have to worry about it, also the front hub is equipped with a pair of "dust cones" (aka "dustcaps"), which require a special (very expensive) "dustcap puller tool" extractor.
Modern hubs are compleatly different, since 1998 they are sold with sealed bearings, which are more robust against dust and water but less efficient on lateral friction when the wheel is not perpendicular to the ground but has an angle, typical of the trajectory when cornering.
My bike is hybrid: it uses classic (1983-1994) hubs for the wheels, and modern (1999-2005) sealed bearings for the bottom bracket.
NOS, in great condition, ready to use, they normally cost around 250-300 euros.
I was lucky enough to find a pair that had been sitting for over 30 years in storage for less than 120 euro.
Unfortunately, they are completely seized and don't turn at all. It's the fault of the fat that has aged badly. They must be completely disassembled, degreased, cleaned, regreased, and then the must be adjusted.
« Last Edit: September 10, 2023, 03:59:06 pm by DiTBho »
The opposite of courage is not cowardice, it is conformity. Even a dead fish can go with the flow
The following users thanked this post: Detlev
Offline jonovid
    • JONOVID
« Reply #12451 on: September 11, 2023, 12:57:15 am »
quick release bike axles are a bit of a joke.
when sold on bikes with caliper brakes also with fat tires or tires protruding outside the rims.
no time is saved in a wheel change. ::)
The following users thanked this post: Kim Christensen
Offline balun
« Reply #12452 on: September 11, 2023, 02:56:24 pm »
Back to the roots  :D
The following users thanked this post: xrunner, richnormand, exor, RAPo
Offline wkb
« Reply #12453 on: September 11, 2023, 03:00:47 pm »
Schön!   Kleinanzeigenfund?
Offline balun
« Reply #12454 on: September 11, 2023, 06:34:06 pm »
Offline armandine2
« Reply #12455 on: September 11, 2023, 07:00:02 pm »
yep - I got one first time around and can upload a picture well under 2000 kilobytes, schon :palm:
[ed]
and the right way up LOL
« Last Edit: September 11, 2023, 07:46:29 pm by armandine2 »
Funny, the things you have the hardest time parting with are the things you need the least - Bob Dylan
Online DiTBho
« Reply #12456 on: September 11, 2023, 09:35:55 pm »
the tire? 28",23mm what else 8)
Online DiTBho
« Reply #12457 on: September 12, 2023, 10:40:31 am »
A pair of super rare Campagnolo Lambda rims, "V" profile (24mm), A6082-T6, polished!!!
(50 euro each, NOS, I couldn't resist!)
my bicycle starts to look like the Delorian car from the third episode of the "Back To The Future" movie, where you see parts from different time periods  :o :o :o :o
hubs from 1985, rims from 1989, bb from 2005, brakes from 2010, crank from 1975, seatpod from 2023, seat from 2010, and the computer bicycle from 2026 (from the future, as I haven't yet finished it, but it's already virtually there)
« Last Edit: September 14, 2023, 09:20:00 am by DiTBho »
Offline u666sa
  • Country: ru
« Reply #12458 on: September 12, 2023, 03:10:30 pm »
Me bought this microscope! Me like it very much!
Really good complictation. No need for double boom arm or to drill my work bench, couple of cheap clamps from hardware store do the job. I've printed some eyepiece spacers, makes work much much nicer, you just stick your head into eyepieces and it's compfortable.  :popcorn:
Eyepiece spacers https://www.thingiverse.com/thing:4995024
Auxilary light adapter https://www.thingiverse.com/thing:5124819
Offline armandine2
« Reply #12459 on: September 13, 2023, 09:18:23 am »
From Cromwell Tools, for some upcoming heat sinking - transistors - I went for Dowsil 340 compound (seems popular and was in stock)
Offline gamalot
  • Correct my English
    • Youtube
« Reply #12460 on: September 14, 2023, 09:11:29 am »
A few connectors from DigiKey.
« Last Edit: September 14, 2023, 10:29:41 am by gamalot »
Offline ledtester
« Reply #12461 on: September 14, 2023, 03:54:31 pm »
A bunch of impulse items from Aliexpress.
Somewhat recently Aliexpress introduced "Choice" which gives you free shipping + a 14-day delivery time. I discovered that using the phone app that you seem to get additional offers in the form of $2, $3 and $4 deals. The catch is that your cart needs to have between 3 and 10 items and you can only buy qty 1 of the specially discounted items. However, you can place multiple orders.
Below is a montage of the stuff I bought.
If you're interested in the macro pad you should check out:
https://github.com/kriomant/ch57x-keyboard-tool
for alternative programming software (includes macos and linux support).
Offline exor
« Reply #12462 on: September 14, 2023, 05:01:32 pm »
Some lightning protection.
Offline paulca
« Reply #12463 on: September 15, 2023, 02:26:21 pm »
1874341-0
I have a shelved project not started to build a silent audio device power supply.  My initial KiCads where laying out the batteries.
Then AliExpress offered me one already made for £11.  Don't mind if I do.
It's a ~30V LifePO4 battery pack with balancing leads and possibly multi-taps on DIM connectors.  Plus the main 30V output rail with I think a 5Amp fuse.
Offline RAPo
« Reply #12464 on: September 15, 2023, 02:30:06 pm »
A Remax 20000mah power bank .
Offline armandine2
« Reply #12465 on: September 16, 2023, 09:49:12 am »
this came promptly from Cooksongold  :-+
new to me the 3/32 collet size means a few drills to purchase - went for a couple of Busch 0.5mm to 1.6mm 12 piece drill bit sets
Offline MegaVolt
  • Country: by
« Reply #12466 on: September 16, 2023, 11:53:20 am »
Can you provide a link to Ali?
Offline paulca
The following users thanked this post: MegaVolt
Offline Neepa
  • Mechanic by trade Electronics enthusiast by choice
« Reply #12468 on: September 17, 2023, 10:20:01 am »
Purchased an Eico 250 VTVM on a flea market for 10 bucks.
Very very minty condition. Almost no scratches aside from tow on the large coil meter front. No rust, only dust inside. Even the tubes in it look very new. Gotta change some original axial capacitors though before I even dream of plugging the mains into it.
Might make for a very nice Analog Amperemeter should I bundle it more permanently with a shunt resistor. Would free up my Keithley 2000 from such tasks.
Turbojet Mechanic playing EE.
Online VEGETA
  • Country: jo
  • I am the cult of personality
    • Thundertronics
« Reply #12469 on: September 18, 2023, 09:46:38 am »
I have purchased these:
ZD-915 desoldering vacuum station: https://www.amazon.co.uk/ZD-915-Desoldering-Rework-Station-Circuit/dp/B07GQ6BCJ6
Velleman DESOLDER4 Desoldering Braid: https://www.amazon.co.uk/dp/B076YXJJWT?psc=1&ref=ppx_yo2ov_dt_b_product_details
DURATOOL D03170 PCB Holder: https://www.amazon.co.uk/dp/B072BCZCXP?psc=1&ref=ppx_yo2ov_dt_b_product_details
and the book
Professional Electronic Design Best Practices: https://www.amazon.co.uk/dp/B0C1J56V97?psc=1&ref=ppx_yo2ov_dt_b_product_details
My review is:
Desoldering station: fantastic! best tool I bought, it helped me do stuff easily which previously were very hard.
Solder wick: also nice. all previous wicks I got were Chinese which never worked! like not even with flux or 480 degrees iron. these are the real deal.
book: looks unique but still to be read... it is on the tips and tricks side of things rather than traditional textbook.
pcb holder: kinda ok, since the board sometimes slips. very nice for the price.
Offline porter
« Reply #12470 on: September 18, 2023, 11:15:52 pm »
I recently purchased "Electromagnetics Explained" by Rob Schmitt
I spent a few weeks here and there reading this book so I thought I would post a couple passages of interest.
Here is an example of a circuit layout problem (there is plenty of practical info in this book). Following that is the explanation part. After reading this, I decided to like what I know.
Offline geb
« Reply #12471 on: September 19, 2023, 12:38:07 am »
I decided to add to my pile of cheap DMMs by getting a Zotek ZT-702S. USD55 before tax, and with free shipping.
Buying an oscilloscope-and-DMM also lets me delay buying a decent 100+ MHz scope. Since most of my purchases are of moddable and/or hackable cheap products, I'll undoubtedly get a scope where I can, um, "unlock" its frequency limits. I've seen a few models on the forums that qualify.
Last month I bought a Schneider 78005 soldering station at my local Harbor Freight store with a USD10 discount. Its tip and element seem identical to the USD15 irons with built-in temperature control that I get from Aliexpress. So, I found it amusing that Popular Mechanics said it was the best overall soldering station of 2023. https://www.popularmechanics.com/home/tools/a41977866/best-soldering-iron/
Offline armandine2
« Reply #12472 on: September 19, 2023, 06:48:43 am »
multiple indecipherable  :palm: not least Rob aka Ron
Offline paulca
« Reply #12473 on: September 19, 2023, 09:45:18 am »
Oops.  I started out with an SBC for a fileserver.  Then it spiralled.  "I should use M.2 for fast storage, it's cheap.... but I need a board with at least 2 slots.... that means it needs to be a modern B550 board....  £600.
1878310-0
« Reply #12474 on: September 19, 2023, 10:14:39 am »
(Attachment Link)
There are NVMe options depending on your SBC of choice   >:D PCIe3.0x4 not as fast as a full blown board but this SBC stock also runs dual 2.5Gbps LAN.
« Last Edit: September 19, 2023, 10:19:01 am by beanflying »
