If you only have added razorhttp://www.monsterscooterparts.com/e21.html?gclid=CjwKEAjw3YipBRDL2bHhjLmFkQsSJADtzktjO3hCds_y860zdMfPcaHzeTRuTBO3rW07Ka4uVAkXMhoCLeLw_wcBDiscontinued:http://www.monsterscooterparts.com/ract5wicomoe.html
I don't want the harness I want just the connector at the end
Hi All. I am look for the name of this type of connector and where I can order it. Anyone know who makes it and what it is called? Thanks for the help.Fluxed
Quote from: Richard Crowley on April 05, 2015, 05:23:53 pmContext is always helpful. Sorry, I should have explained better. The connector is used in an electric scooter. I had it but some bastard stole the old batteries with the connector still attached. I have new batteries now but I want to get proper replacement it, and I guess I will also need the contacts too.tsmith35 thanks for the link, The R&R kit may be the ticket.
Before you replied i was thinking u.fl connector.Did some more research, and the mounting pad size specs matches the u.fl.
Can someone help identify this power connector? It's used in Nokia Flex Power Distributor, I couldn't find it anywhere.
