Author Topic: What did you buy today? Post your latest purchase!  (Read 2801735 times)
Offline lewis
  • Nullius in verba
« Reply #7600 on: December 07, 2018, 04:07:05 pm »
I just bought this to measure that resistor in the bottom left of the image.
100fA resolution anyone?
I will not be pushed, filed, stamped, indexed, briefed, debriefed or numbered.
Offline GreyWoolfe
  • NW0LF
« Reply #7601 on: December 07, 2018, 04:52:45 pm »
Scissors!
These Engineer scissors are really cool. I have the same ones, they can cut quite a lot of things.
I have a pair of bandage scissors that I bought for a dollar at a yard sale years ago because a friend showed me you can cut a penny in half with them.
Offline Terry01
  • Country: scotland
« Reply #7602 on: December 07, 2018, 05:04:05 pm »
Scissors!
I did LOL a bit there!  :-DD
Sparks and Smoke means i'm nearly there!
Online TheSteve
  • Living the Dream
« Reply #7603 on: December 07, 2018, 05:50:21 pm »
Ooooooooooh, cable /connector porn!
Yep, and it is time to stop now, the collection is getting out of control.
Nice cables! What do you use them for? I haven't seen the connector on the ends of them before.
The connectors are on the ends are either SMA or 3.5mm precision connectors. They are used for RF work. The cables themselves are built to a guaranteed maximum loss and maximum phase error. The SMA cables are rated to 18 GHz, the 3.5mm cables are rated to 26.5 GHz. You can connect the SMA to the 3.5mm cables. The 3.5mm connectors use an air dielectric instead of PTFE and are built to a higher standard of precision. That also means they are very delicate. Torque wrenches are used for all mating connections. I use them with my 26.5 GHz network and spectrum analyzers.
VE7FM
Offline boB
    • my work www
« Reply #7604 on: December 07, 2018, 05:55:27 pm »
Bought two (2) more DE-5000 LCR meters for $104 USD each for work.
K7IQ
Offline Terry01
  • Country: scotland
« Reply #7605 on: December 07, 2018, 06:30:32 pm »
Cool  :)
Offline GreyWoolfe
  • NW0LF
« Reply #7606 on: December 07, 2018, 06:32:51 pm »
I bought a Fluke 101 and case for my toolbag.  I was disappointed in the inaccuracy of my Aneng 8009 on voltages when I checked it with my DMM Check plus.  I still wanted something relatively small and for $40 USD, it's a good enough deal.  I probably should have bought this first instead of the 8009 and the 8008 that I have as a back up.
« Last Edit: December 09, 2018, 11:22:29 pm by GreyWoolfe »
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #7607 on: December 07, 2018, 06:39:20 pm »
GreyWoolfe, this is interesting info; did the Anengs start to drift continuously or were they subjected to an... ahem... "event"?  :-BROKE
If the former, that says a lot about their build and reliability.
Offline mtdoc
« Reply #7608 on: December 07, 2018, 07:09:14 pm »
Excellent. I hope they help with getting those MNB17s shipped!  ;)
The following users thanked this post: boB
Offline mtdoc
« Reply #7609 on: December 07, 2018, 07:21:47 pm »
48v 600A Contactor for upcoming electric lawn tractor build.  Saved a bit of money using eBay 10% off coupon code PHYDAYTEN - today only!
Also purchased one of those cable extenders to be used for Tektronix TM500 series plug in repairs...
Offline GreyWoolfe
  • NW0LF
« Reply #7610 on: December 07, 2018, 11:07:47 pm »
Actually, no.  The only event they both went through was the well documented mods for the more stable display.  OF course, I received the DMM Check after the mods were done so I don't know if I  :-DMM something up doing the mods, though I doubt it.  C'mon, it's adding a couple of caps and replacing a couple--not hard to do.  The 8008 was much closer than the 8009 but not near as good as my old Fluke 27/FM.  They live a quiet life in my company van as I needed a small multimeter accurate on low ohms reading and they both do it very well.  The only voltages they have been exposed to was the DMM Check.  They are much better than the red HF meters, I found 2 of them NIB with fresh batteries that were an order of magnitude off for what I needed.  Quite embarrassing as this was at a training session which prompted the Aneng purchase.  After more pondering and rumination, I may need to do quick voltage checks including mains and I don't really trust the Anengs for that.  That's what prompted the Fluke purchase.   I will still keep the 8008 as a spare but I may Wildarize the 8009 just for fun.  I haven't used my 2 pound hammer for anything in quite awhile.  I will see if the voices in my head tell me to keep it intact. >:D
Offline georges80
« Reply #7611 on: December 08, 2018, 12:21:05 am »
Actually bought a couple of weeks ago. Good investment for about $150 delivered (amazon).
Cheap vna that has good reviews and indeed it does work very well for testing out antenna prototypes.
Picture is of a prototype moxon antenna for lora at nominal 910MHz.
I also purchased Matlab home (about $150) and the antenna plug in for $50. I have a PCB prototype layout of a moxon antenna that I'll have to send it to a cheap PCB fab when I get a chance.
cheers,
george.
Offline scuzzyTerminator
« Reply #7612 on: December 08, 2018, 03:14:26 am »
Really bad news. HSC Specialties "HalTed" of silicon valley will be closing January 12, 2019.
https://www.halted.com/
There's a big sale until then.Today I grabbed a few things.
A couple of toroidal transformers at 50% off. This one has two 120V primaries.
This one I'm still looking for specs.
These super cap banks were for server memory backup (SCU CA05954-0920). Each cap is 47F/2.7V. They are currently $3 per bank.
I'm really gonna miss this store. SV is really drying up.
« Last Edit: December 08, 2018, 03:18:22 am by scuzzyTerminator »
Offline Gixy
« Reply #7613 on: December 08, 2018, 08:09:26 am »
100 fA = 0.1 pA = 0.0001 nA = 0.0000001 uA. Not so much Amps anyway...
« Reply #7614 on: December 08, 2018, 10:24:27 am »
More "junk"  :)
Those parts trays are really good, I've got 3 of them  :-+
Offline tooki
« Reply #7615 on: December 08, 2018, 12:14:26 pm »
I don't know what those are for, but they sure are pretty!! :D (And almost in my favorite color!)
Offline Terry01
  • Country: scotland
« Reply #7616 on: December 08, 2018, 02:30:13 pm »
That's exactly what I thought so I asked what they were for and Steve was good enough to explain...
Cool eh?  :)
Offline djos
« Reply #7617 on: December 08, 2018, 11:59:55 pm »
I bought some proper flux cleaner the other day, after years of using isoprophyl I'm shocked at how much better this stuff is! I really wish I'd found it sooner.  :palm:
Online beanflying
« Reply #7618 on: December 09, 2018, 12:24:08 am »
If a product label ever asked to have liquid paper and texta used on it this could be the one  >:D
Offline djos
« Reply #7619 on: December 09, 2018, 12:35:54 am »
 :-DD
Offline boB
    • my work www
« Reply #7620 on: December 09, 2018, 07:28:37 am »
You bet they help !
And one for production, too.  We have a few of these now.  Really great especially for the price.  Then there's the big monster, HP 4194 Gain-Phase analyzer for the heavy duty testing
K7IQ
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #7621 on: December 09, 2018, 03:01:42 pm »
However, it smells awful and you should definitely not breathe the fumes.
The following users thanked this post: djos
Offline Alex Eisenhut
  • Place text here.
« Reply #7622 on: December 09, 2018, 04:11:45 pm »
A bunch of these
https://www.ebay.ca/itm/5pcs-Banana-Plug-to-Crocodile-Alligator-Clips-Set-Test-Probe-Lead-Wire-Cable/292378751414?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
I was still using the same short, flimsy, and unreliably crimped set of cheap alligator cables I had been using since my college days. These new ones are much thicker and better built. The jaws align correctly, and I passed 3A through them and got a 50mV drop for a 4 ft length. Not bad. I don't think I'll ever use them for more than 5A so I'm happy.
(And yes Canada Post has slowed to a trickle lately but it eventually makes it here!)
Offline Terry01
  • Country: scotland
« Reply #7623 on: December 09, 2018, 04:38:19 pm »
A bunch of these
I got some of the 4mm banana each side ones and agree they are good leads. they are well worth the £!
Offline t1d
« Reply #7624 on: December 09, 2018, 05:44:19 pm »
A bunch of these
On sale at Banggood.com, for $6.99USD. Woot
https://www.banggood.com/DANIU-5Pcs-1M-4mm-Silicone-Banana-Plug-to-Crocodile-Alligator-Clip-Test-Probe-Lead-Wire-Cable-p-1062184.html?rmmds=search&cur_warehouse=CN
