Author Topic: Whats your Work-Bench/lab look like? Post some pictures of your Lab.  (Read 2306952 times)
« Reply #1925 on: April 10, 2016, 06:30:44 pm »
More upgrades, bench related.
Previously all my probes and test cables were stuffed away in a drawer in another room. I had some left over lumber from a previous project and decided to put it to good use. A probe rack on a wall directly opposite my bench for ready access.
« Last Edit: July 19, 2017, 10:19:58 am by med6753 »
Offline McBryce
« Reply #1926 on: April 10, 2016, 08:08:32 pm »
For test leads I use some this: http://image.made-in-china.com/43f34j00GMATrVERgFgJ/Plastic-PVC-Channel-Slotted-Track-Cable-Tray-Wiring-Duct.jpg wire ducting.
Cut one of the sides off, screw it to the wall (holes already in the plastic) and it's cheap as chips (the edible ones).
McBryce.
Online gamalot
  • Correct my English
    • Youtube
« Reply #1927 on: April 11, 2016, 10:44:12 am »
this is mine  :)
Offline VK5RC
« Reply #1928 on: April 12, 2016, 09:21:07 am »
@gamalot Love the U1253B OLED, despite the recharging PITA, it a great meter.++++
Offline TinkerFan
« Reply #1929 on: April 12, 2016, 09:50:54 am »
@gamalot and all the others who manage to keep their desks tidy:
How do you do that?? As soon as I start something, it gets messy as hell, even though my desk is not so small (About 2m²)..
"A good scientist is a person with original ideas. A good engineer is a person who makes a design that works with as few original ideas as possible. There are no prima donnas in engineering." - Freeman Dyson
Offline McBryce
« Reply #1930 on: April 12, 2016, 10:30:52 am »
When I realise that there's not enough space on my desk to put my current PCB down without starting a pile, I then stop all project work and have a clean-up day (and also take a photo for this thread :) ).
McBryce.
Offline Sbampato12
« Reply #1931 on: April 12, 2016, 12:21:46 pm »
Intense fight night with a 5kV power supply, took a cellphone photo (sorry), before sleep.
I hope I can clean up a bit this weekend, this is getting hard to work on this bench..... ::)
Online gamalot
    • Youtube
« Reply #1932 on: April 12, 2016, 04:45:31 pm »
Did you mean "pain in the ass"? Yolo, my English sucks  :'(
I guess it's the reason why they give up on using OLED display in their new U128x meters.
Online gamalot
    • Youtube
« Reply #1933 on: April 12, 2016, 04:47:52 pm »
I have to do some clean up everyday cuz I share this room with my son, I don't wanna be a bad example  :) :)
Offline German_EE
« Reply #1934 on: April 12, 2016, 05:01:52 pm »
Every Friday afternoon is clear up day. So, I put all the tools away in the right places, all the parts go back in the right boxes and each project gets returned to it's own storage box. I then clean the work benches and vacuum the floor. After the weekend it all starts again but every Monday I have a visitor and his mother so at least they get to see a clean workshop.
Should you find yourself in a chronically leaking boat, energy devoted to changing vessels is likely to be more productive than energy devoted to patching leaks.
Warren Buffett
Offline Sbampato12
« Reply #1935 on: April 12, 2016, 05:14:13 pm »
This could be my case someday, but for now, without any son I may need another strong scuse to do it.... :)
Mine problem is that this is mine cave, so basically just I get inside, neither my wife come here... But I don't like to work like that, not a clean room, but not like that. I'm moving in this 'new' lab, so I don't get all the storages, box and shelves yet... Maybe this later....
Offline rdl
« Reply #1936 on: April 12, 2016, 05:15:49 pm »
I have almost a fetish about keeping the bench neat and clean. There are only four items that have a permanent spot on my bench top: keyboard, monitor/PC, jar for pens,pencils etc., and a jar used as a small wastebasket. Everything else sits up on a shelf. Usually only one project is worked on at a time, and every project has a box that it and all its parts are stored in. Inactive project boxes are stored out of the way in a drawer or in a closet.
Offline Fortran
« Reply #1937 on: April 21, 2016, 04:31:08 pm »
Since I just cleaned my lab I figured now would be a good opportunity to post a photo here.
Usually you can hardly see the bench.
Offline japasetelagoas
  • Country: br
  • Just an ordinary electronics hobbyist.
« Reply #1938 on: April 24, 2016, 06:46:57 pm »
Proud to be a member of this forum, and there's nothing better than showing my workbench/lab as first post.
It used to be a music studio back when I was not into electronics as I'm today (hence the drum kit and guitars laying around).
The Holy Grail
That's all guys, hopefully I'll be an active member here at the EEV.
The endless river...
Offline sotos
  • Country: gr
« Reply #1939 on: April 24, 2016, 07:25:32 pm »
The Holy Grail
Welcome to the forum. I see the lamps above the bench are very bright. What are they?
  • Country: br
« Reply #1940 on: April 24, 2016, 07:53:53 pm »
Thanks sotos. That's a lighting fixture made by a Brazilian company called Taschibra, two LED strips with 55 LED's and 10W on each strip, 6500K temperature color, I actually attached those to the workbench two days ago, using some angle brackets and scrap MDF.
Offline AF6LJ
« Reply #1941 on: April 24, 2016, 09:23:36 pm »
Nice bench..
Sue AF6LJ
Offline TerraHertz
    • It's not really a Blog
« Reply #1942 on: April 24, 2016, 10:26:06 pm »
japasetelagoas that's a very pleasant room, and nice work area. Also welcome to the forum!
But the strips of MDF holding up those lights... I'd suggest hunting around for some real wood pieces to replace those eventually. MDF bends slowly under load, and really isn't very strong. Also with screws into the edges of a narrow piece it's prone to splitting.
  • Country: br
« Reply #1943 on: April 24, 2016, 10:40:21 pm »
Terra, thanks for the tip. Even though the fixture itself is quite light (less than 1kg) I'll keep an eye in case the MDF starts to warp.
Offline bookaboo
  • Country: ie
« Reply #1944 on: April 25, 2016, 08:34:41 am »
Nice bench japasetelagoas. What brand is that screwdriver set? Are they good quality? looks neat.
Offline dvdouden
  • 0 != 0!
« Reply #1945 on: April 25, 2016, 10:20:00 am »
Lots of nice benches/labs/man-caves in this thread! :clap: Mine is very much a work in progress. I wouldn't call it a man-cave really, it's more like a man-corner; a bit cramped. But at least it's all mine, all four square meters of it and it beats having to share a desk with the missus ;D
Just a couple of layers of paint on the shelves and I can start moving my stuff in there!
The following users thanked this post: hammy
Offline BillyD
  • Country: ie
« Reply #1946 on: April 25, 2016, 12:04:40 pm »
Very nice indeed. Is that the landing at the top of a stairs? I like the way you've extended the desktop over the railing to maximise the space - and given it a 'guard rail'. Very good use of a difficult shaped space. Just remember not to let anything roll off the end of the shelves in case it lands on somebody coming up the stairs!
The following users thanked this post: dvdouden
Offline ElektroQuark
    • ElektroQuark
« Reply #1947 on: April 25, 2016, 12:17:11 pm »
Quote from: japasetelagoas on Yesterday at 19:53:53
I like them very much.
Anyone can recommend something similar and decent quality from eBay?
Offline dvdouden
  • 0 != 0!
« Reply #1948 on: April 25, 2016, 12:20:03 pm »
Yes! We've placed a new dormer on our roof about a year ago. That made that space much more useful than before  :-+ The extension is removable, in case I ever need to move large objects again.
Leave it up to my carpenters eye to make sure nothing is level. Anything rolling off the shelves will, by accident design, be rolling in the safe direction ;D
« Last Edit: April 25, 2016, 12:31:30 pm by dvdouden »
The following users thanked this post: BillyD
Offline nanofrog
« Reply #1949 on: April 25, 2016, 05:56:41 pm »
It might still be a work in progress, but it's an excellent use of the available space IMHO.  :-+  :clap:
