Author Topic: What did you buy today? Post your latest purchase!  (Read 2815832 times)
Johnny10 and 17 Guests are viewing this topic.
« Reply #5800 on: March 09, 2018, 12:26:44 pm »
I was more of a PSION fan. I went through most of them and still have my PSION 3c and MX5. The sliding keyboard on the MX5 was an engineering masterpiece and the button feel could put many modern laptops to shame.
McBryce.
I still have mine as well, the biggest problem with them was the screen, lack of contrast made them hard to read unless in the best lighting.
Offline BravoV
  • +++ ATH1
« Reply #5801 on: March 10, 2018, 08:16:13 am »
An used Korean spectrum analyzer 9kHz-3.0GHz NX-30.  :P
Offline VEGETA
  • Country: jo
  • I am the cult of personality
    • Thundertronics
« Reply #5802 on: March 10, 2018, 09:16:03 am »
I bought 2 of these: https://www.banggood.com/YIHUA-908D-220V-LED-Digital-Display-Soldering-Station-Soldering-Iron-Kit-p-1059873.html?rmmds=myorder&cur_warehouse=CN
It is a nice soldering station but one of the 2 units had its heating element burned out after short usage for no reason... I have to replace it now. Do you know where I can buy one? I got the whole station for 18$ on discount!
Offline neo
  • The specialist.
« Reply #5803 on: March 10, 2018, 10:08:04 am »
Well I might have some good news for you, if you are not afraid of splicing. It is of course a generic element, but that specific type is common as dirt in china.  It is the, "A1322 Heating Element", i am guessing based off the handle. No guarantees of course, i may be wrong, but i had a handle very similar.
« Last Edit: March 10, 2018, 10:11:26 am by neo »
« Reply #5804 on: March 10, 2018, 10:21:30 am »
Personally, I'd spend a fraction more and get some 220 in 24 out T12 soldering units, spares are really plentiful and cheap. They are the best soldering experience I've ever had, really fast heat up time and fully controllable Banggood and Aliexpress  sell them.
Offline VEGETA
  • Country: jo
    • Thundertronics
« Reply #5805 on: March 10, 2018, 12:16:48 pm »
Is this the one: https://www.banggood.com/5pcs-24V-50W-A1322-Soldering-Station-Replacement-Heating-Element-Ceramic-Heater-p-1094025.html ??
and Banggood has this:
https://www.banggood.com/110V220V-Heating-Element-for-YIHUA-908-Electric-Iron-Thermostat-Soldering-Station-p-1117931.html
My luck was bad on the one that stopped working, because I am using the other one and it is perfect. I liked it because of small size and so on.. will get others too in the future.
This is the one you mean: https://www.banggood.com/DSK-Digital-Soldering-Station-Kit-Soldering-Iron-Station-Temperature-Controller-p-1055574.html
it is 50$ without the base so it is not as you explained, I expect the whole one to be 60$ at least. Cannot compete 18$.
this one was my first choice: https://www.banggood.com/110V-220V-Inverter-Frequency-Change-Electric-936-Power-Soldering-Station-Iron-p-1093556.html
« Reply #5806 on: March 10, 2018, 12:41:48 pm »
You could always try Aliexpress and purchase the system in kit form.
Ignore the photo of the apple power supply in the enclosure, I think you will receive the one shown expanded view of parts.
https://www.aliexpress.com/item/QUICKO-STC-T12-LED-Digital-Soldering-Station-DIY-kits-ABS-plastic-Shell-new-controller-ver-HAKKO/32838444422.html?spm=2114.search0104.3.32.45798d616tN3CP&ws_ab_test=searchweb0_0,searchweb201602_3_10152_10065_10151_10344_10068_10130_10324_10342_10547_10325_10343_10340_10548_10341_10192_10190_10084_10083_10618_10307_10301_10303_5711211_10313_10059_10184_10534_100031_10103_10627_10626_10624_10623_10622_5722411_10621_10620_5711313,searchweb201603_25,ppcSwitch_5&algo_expid=b4b66a58-6e22-4606-85af-4fb44bc3230f-4&algo_pvid=b4b66a58-6e22-4606-85af-4fb44bc3230f&priceBeautifyAB=0
Offline rodcastler
  • Country: cl
« Reply #5807 on: March 10, 2018, 01:16:08 pm »
After a few years of reliable power delivery and ease of use, I went ahead for my second Korad KA3005P unit.
I guess the lesson learned is to either buy two of these or get a triple-output PS. Even though I have two other low-range power supplies, I kept myself finding the need for a second lab-graded PS during some experiments.
Offline JorgeRamos1
  • Country: mx
« Reply #5808 on: March 10, 2018, 07:27:38 pm »
recently i got a bunch of  microcontrollers  some dspic30f and 16f
Offline ChrisLX200
« Reply #5809 on: March 10, 2018, 08:51:45 pm »
Ever ordered something and completely forgotten about it? This DPS5015 arrived today which I'd ordered just before Chinese New Year..
Also thirty 608 bearings to go into stock - less 8 to be used to make a couple of 3D Printer filament rollers (the base is the red thing to the right). That's printed with PET-G, good stuff to print with albeit it's a bit stringy requiring some clean up. A little more flexible than ABS but much tougher and less likely to crack/snap. Another big advantage - it doesn't warp like ABS!
Offline frozenfrogz
« Reply #5810 on: March 10, 2018, 09:18:12 pm »
Regarding stringing while printing PETG:
I found, that PETG can be printed nicely at lower temperatures than specified. Depending on the part and how quick I am printing, I usually go for 205°C as a starting point. Gives me very nice results, even with high extrusion rates on the UMO+.
IPETG from dasfilament.de that is - can not say a lot about other manufacturers.
« Last Edit: March 10, 2018, 09:52:09 pm by frozenfrogz »
Offline ChrisLX200
« Reply #5811 on: March 10, 2018, 09:42:10 pm »
I found, that PETG can be printed nicely at lower temperatures than specified. Depending on the part and how quick I am printing, I usually go for 205°C as a starting point. Gives me a very results, even with high extrusion rates on the UMO+.
That's interesting, and worth an experiment. I start the first layer @ 240 then drop to 230 for the remainder. I've tried with/without the nozzle cooler enabled too and the stringing is worse with the cooler on, although the result is much more 'blobby' without (which is actually more difficult to clean up). A quick exposure to a cigarette light flame quickly removes the fine strings but does nothing for the blobs which need to be manually cut off.
Offline neo
  • The specialist.
« Reply #5812 on: March 10, 2018, 10:51:17 pm »
this one was my first choice: https://www.banggood.com/110V-220V-Inverter-Frequency-Change-Electric-936-Power-Soldering-Station-Iron-p-1093556.html[/url
Either should work, give or take some improvisation.
« Reply #5813 on: March 11, 2018, 03:30:00 am »
Brought a top up of Aluminium stock to lop up into a dual rack kit for my 34970A's and 6632B power supply.
Even s/hand these are too !@#$ing expensive for the real thing.  :rant:
Drilling and Tapping time  :)
Offline amspire
« Reply #5814 on: March 11, 2018, 05:23:50 am »
I would wait till I had the iron and can take a look at the element. It is probably either the A1321 or A1322 but they are different. The temperature elements has different resistances. The A1321 is almost 50 ohms and the A1322 is something like 12 ohms. The wire length for the power and sense leads are different to the extent that you couldn't out a A1321 element in a A1322 iron or visa-versa without extending wires.
Offline VEGETA
  • Country: jo
    • Thundertronics
« Reply #5815 on: March 11, 2018, 06:21:34 am »
But this one clearly says it is for Yihua 908:
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #5816 on: March 12, 2018, 06:59:52 am »
Well, it was technically purchased on Friday, but it arrived today.  I believe I saw this on someone's bench picture on the 'Show us your workbench' thread about a month ago, and, being tired of hanging my pliers on the edge of a cardboard box on top of my wire equipment rack, decided to buy one.  I think it will make for much neater tool storage:
-Pat
« Reply #5817 on: March 12, 2018, 07:17:03 am »
-Pat
I have a couple of old Hacksaw Blade Racks in use for storing small diameter tube and wire including heatshrink. Works well until the content gets 'shoved' to the side of the bench  :-DD
Offline VK5RC
« Reply #5818 on: March 12, 2018, 09:29:17 am »
A few weeks ago I bought an STM32f746g-disco development board.
 If you add on a small daughter board with a small synthesiser (SI5351A) along with two mixer IC (SA612), using the board layout and software very Kindly shared freely by EU1KY;  for a total of about AUD$110 you can make a 450MHz  S11 Antenna VNA! As Dave would say BEAUDY MATE  :-+
It can measure R + j
                       Time Domain Reflectometry
                       Scan a reasonable span ie multiple 10s of MHz
                       Calculate a solution for 50 Ohm system
                       Act as a weak 2-20mV signal generator
http://www.st.com/en/evaluation-tools/32f746gdiscovery.html
https://bitbucket.org/kuchura/eu1ky_aa_v3/wiki/Home
Below is a screenshot of one of the outputs of my unit- ie Smith Chart, it can also do return loss, VSWR.
A big thanks to EU1KY  :-+
The following users thanked this post: bitseeker, julianhigginson
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #5820 on: March 12, 2018, 08:44:26 pm »
I bought a 10 bit Absolute rotary encoder, from china. And it works!
But I had to take it apart to find the pinout of the connector, I can't read chinese colors.
To my surprise, I did not expect it to work with a magnet.
*note: none of the sellers on aliexpress have the correct product description.
Offline lukier
    • Homepage
« Reply #5821 on: March 12, 2018, 09:32:04 pm »
Nice! Do you have the link? Is it based on Austria Microsystems chips (AS5040 and similar)?
Offline Kjelt
« Reply #5822 on: March 12, 2018, 10:35:17 pm »
Red thick black black green white
Using the same color twice for different signals, i have no words , why?
Offline TerraHertz
    • It's not really a Blog
« Reply #5823 on: March 12, 2018, 10:43:14 pm »
Wait, what? So, if there's some external magnetic field, the angle data this thing gives will be wrong?
And how linear is it?
Edit @Kjelt:   thick-black, black.  What same color?  :-//
« Last Edit: March 12, 2018, 10:47:00 pm by TerraHertz »
Offline TerraHertz
« Reply #5824 on: March 12, 2018, 11:09:15 pm »
There is a magnet bond to the shaft, when the shaft rotates, the magnetic field commutates, and the sensor IC detects the position by the H field.
Yes, I deduced all that from the photo.  Which is why I asked about external fields. Presumably the housing is steel or mu-metal and provides some magnetic shielding. But it can't be 100%.
