Author Topic: What did you buy today? Post your latest purchase!  (Read 2816868 times)
0 Members and 26 Guests are viewing this topic.
Offline Decoman
  • Country: no
« Reply #4850 on: December 13, 2017, 10:26:51 am »
Being new to soldering, and having to wait for stuff to arrive in the mail, I decided to get four more soldering tips in addition to the one that came with the soldering station I also ordered somewhere on eBay:
As I understand it, the flat ones will transfer more heat over to a flat surface. And I will have to guess that the thin and curved one is for soldering tiny spots that maybe are hard to get at.
Edit: Unsurprisingly, I have a lot to learn about soldering. :)
« Last Edit: December 14, 2017, 07:15:37 pm by Decoman »
Offline McBryce
« Reply #4851 on: December 13, 2017, 02:10:38 pm »
The fourth one you've circled isn't really for soldering. These are usually used for modelling plastics or woodwork. The first and third you've marked will cover you for 95% of what you want to do.
McBryce.
Offline rdl
« Reply #4852 on: December 13, 2017, 02:47:14 pm »
Yep, I got my first good soldering iron in 2004. It was a Hakko 937 and came with the usual pointed conical tip. I replaced that tip with one that looks like the first on the left in your picture and that's been just about all I've ever used.
Offline tablatronix
« Reply #4853 on: December 13, 2017, 03:03:23 pm »
Actually it is for drag soldering, granted you are correct in that I doubt it is used by many, metcal has similar called a drag hoof. I see most people preffering gullwing or mini hoof with dimples. I use wedges of various sizes for all around general soldering.
https://www.hakko.com/english/tip_selection/work_drag.html#type_j
Offline edgelog
« Reply #4854 on: December 13, 2017, 03:11:48 pm »
I don't know what it's intended for, but I'm using a knife tip like that on my Ersa iTool for connectors and larger straight edges. Has a lot of heat delivery capacity.
Offline rdl
« Reply #4855 on: December 13, 2017, 03:23:15 pm »
Mine has just a flat bevel, not the hollowed out type used for drag soldering. It's more like a chisel tip with only one side flattened. On my other cheap soldering iron I use a regular chisel tip that's a little larger.
Offline FrankBuss
    • Frank Buss
« Reply #4856 on: December 13, 2017, 04:16:49 pm »
The beveled tips are useful for drag soldering as well:
But I've also used just a standard round tip, works too. I think it is a bit like art or crafting: a good artist can do anything even with a ballpoint pen, but if you have no talent or practice, you can use the most expensive tools, but achieve nothing.
Offline ChrisLX200
« Reply #4857 on: December 13, 2017, 05:21:26 pm »
Bought another USB>3-1/2" floppy drive (well, two actually..). Trying to hack my Tek 3014B only to find the drive I already owned had decided it would no longer read/write a floppy drive. They were cheap, and I needed to get above £20 to get free postage so I just ordered two. I have a pile of PC floppy drives but no way of interfacing them - and the cheap USB option was just easier anyway. So now I can give the hack a try - but first I need to drop back a version of firmware.
« Reply #4858 on: December 13, 2017, 06:40:55 pm »
https://www.hakko.com/english/tip_selection/series_900m.html#type_k
Certainly listed as for soldering.
Haako even have a link in the above page to show examples of usage but not how I use them for when they outshine all other tips......SMD passive rework.
No need to fire up hot air to remove SMD passives when you have one of these, simply bridge both pads and wipe the component off when the solder has melted.
« Reply #4859 on: December 13, 2017, 09:40:06 pm »
A flux pen and a jar of tip restorer plus a new desk chair.
Nice, I have a very very similar chair in my study ... it's super comfortable!
https://www.officeworks.com.au/shop/officeworks/p/bathurst-chair-blue-jbbathchbe
Well you're not wrong about it being very comfortable, lovely padding and a nice high back to it . :-+
« Reply #4860 on: December 13, 2017, 09:41:49 pm »
How fast does it go?
It doesn't go at all, seems I forgot to order the engine but it is nice and comfy  :popcorn:
Offline georges80
« Reply #4861 on: December 13, 2017, 09:55:55 pm »
Bought (and hopefully receive next week through the xmas package buildup) a B&K 9104 power supply. Needed something that could get to at least 60V at 3A. The 9104 is 0-84V 0-10A (any combo that is 320W max). It's a switcher, so not 'quiet' but not a 30kg boat anchor either :). I need it for testing a higher voltage/power LED driver prototype and a bit of rms/p-p noise on the input is a non-issue.
cheers,
george.
Offline tooki
« Reply #4862 on: December 14, 2017, 03:49:19 pm »
Quote from: edgelog
The two regular transformers are probably back-to-back to end up with 1:1 turn ratio. I'm not sure why they didn't just do that with a single 1:1 transformer. Perhaps to be able to change the input voltage and/or range.
That makes sense.
Quote from: tooki
My latest purchase, if you will, is about $2500 of tattoo work. So much left to go... ::sigh::
That makes no sense whatsoever.  :palm:
Tattoo artists don’t work for free!
Offline Decoman
  • Country: no
« Reply #4863 on: December 14, 2017, 07:09:42 pm »
Not knowing if I really would bee needing a crimping tool soon, I ordered two models off eBay. I hope they do not turn out to be crap. :) A cheap wire stripper I bought down town ended up in the garbage bin the very same day I got it.
« Last Edit: December 14, 2017, 07:11:13 pm by Decoman »
The following users thanked this post: tablatronix
Offline GreyWoolfe
  • NW0LF
« Reply #4864 on: December 14, 2017, 07:16:26 pm »
Quote from: edgelog
That makes sense.
Quote from: tooki
Nor are good artists cheap.  I have a small black and grey tattoo on my chest, custom that was pretty expensive.
Offline jonovid
    • JONOVID
« Reply #4865 on: December 14, 2017, 08:04:31 pm »
I am seeing this type of chair pop-up with popular youtubers.
the desk chair for a whole generation that may never own a car!  :o
it has me wondering what they the automotive aftermarket will do with unsold gear knobs & steering wheel covers.
Offline Macbeth
« Reply #4866 on: December 14, 2017, 08:28:11 pm »
Exactly. As soon as I see useless shit like 4 point harness stuff in an office chair it instantly triggers alarm bells - form over function.
I have a Thrustmaster GT steering wheel and pedals (in a crate somewhere) and the last thing I wanted was a 4 point harness computer chair (with no roll cage) rolling about on castors when using it.  :-DD
« Reply #4867 on: December 14, 2017, 08:43:16 pm »
Whatever the stuff is that you're smoking or chewing on, its pretty good stuff because you're seeing a lot more than I am when I look at both the photo of and the real chair in the flesh and I certainly cannot detect any hint of a 4 point harness on it anywhere.  :-DD
I know that there is another version of this chair on sale which does indeed have straps on it, 1 set for a lumber support, adjustable position wise and also a neck support which again is adjustable.
Offline Macbeth
« Reply #4868 on: December 14, 2017, 09:10:48 pm »
Why do you pay extras for 2 useless holes designed for seatbelts to slip through and cross your chest and clip down at your crotch, like Recaro Rally seats? You are shoving a mouse and tapping on a keyboard, not pretending to be Colin McCrae... Even when you are pretending by playing video games, you are never going to roll over and require strapping in anyway.  :-DD
It's fashion or form over function. Ergonomic chairs are far more sensible and don't have useless crap like that, but tend to be a personal thing rather than mass market gamer chair stuff. One day your back may go out and it is hell on earth I can tell you.
Offline Mr. Scram
  • Display aficionado
« Reply #4869 on: December 14, 2017, 10:05:06 pm »
You're mistaken. Those are vent holes for sweaty nerds.
« Reply #4870 on: December 14, 2017, 10:56:45 pm »
The only difference between this chair and a normal office managers chair (ignoring the colour and stripes) is the fact it has higher backrest and the top is shaped rather than going straight and flat from side to side. As a 6ft 4" tall person, I find the extra support for my head welcome. The holes are there for other reasons one of these could be the addition of a adjustable lumber cushion as the one in the attached photo shows and also additional support for natural curvature of your neck when sitting right back in the chair, also shown in the attached photo. I did not buy it as gaming, nor a racing chair but as it was advertised as, and is being as, an office chair.
« Last Edit: December 14, 2017, 11:01:14 pm by Specmaster »
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« Reply #4871 on: December 15, 2017, 07:22:21 am »
I wonder if this makes any sense: I bought some used PCB's with automotive i.MX6D chips on it for $15, and took the chips (along with the Micron 4Gb DDR3L SDRAM and Micron 16GB eMMC chips, et al) off the board. The seller was using those as development units for some kind of auto infotainment system and since the products delivered they no longer need to keep that amount of development units. I am having a reballing kit coming soon
Should I resell the reballed chips, or just keep them for myself? The exact part numbers are:
  • Processor: MCIMX6D6AVT08AC
  • SDRAM: MT41K256M16HA-125 IT:E
  • eMMC: MTFC16GJDEC-4M IT
  • PMIC: TPS65251Q1
  • GPS: UBX-G6010-ST
  • NOR Flash: S29GL128S90DHI01
Also, does anyone know how to program Renesas µPD78F1824? Those also came off the same board.
Offline Mr. Scram
« Reply #4872 on: December 15, 2017, 07:28:10 am »
I take my words back. They can't allow both drives to spin up simultaneously. One has to spin up first before the other one. So I bodged another power module to solve this. This time a very beefy one. I found a 200W Vicor Mini Gen2 in my crap bin. It would be better if I have a smaller 1/8 or 1/16 brick module, but I don't. All of my smaller modules are 48V input modules, only the half brick one is 24V input model. After sitting in my crap bin for more than 8 years, I finally found a use for it.
This calls for a 555 timer!
Offline technix
  • Country: cn
    • My Untitled Blog
« Reply #4873 on: December 15, 2017, 09:19:38 am »
  • PMIC: TPS65251Q1
  • GPS: UBX-G6010-ST
The SoC is $45 new, I don't think you can even fetch $15 on second hand market.
The eMMC and RAM combined may get you $5 if you are extremely lucky.
The GPS, if there's a datasheet, maybe $5.
Others are trash.
I got 14x the RAM chip and 7x of the SoC, eMMC, GPS and everything else in the $15 grab bag of boards. Everything is Industrial or Automotive grade or better. I took four off the boards and three still mounted.
Offline technix
  • Country: cn
    • My Untitled Blog
« Reply #4874 on: December 15, 2017, 09:41:42 am »
If you can get hold onto a copy of BSP package, selling the board will fetch much more money.
I don't have the BSP. I know that the seller has but he cannot release it to me, even with NDA. So I am kind of on my own here.
Since those powerful chips are so damn cheap, maybe I can practice BGA routing and soldering with them? Maybe I can get a board made for about $50, and if it works, I can create my own BSP. I know for a fact that NXP mainlined the drivers for this chip, so it is very likely I can get stock Ubuntu or Debian armhf running on it.
