Author Topic: What did you buy today? Post your latest purchase!  (Read 2818753 times)
gamalot, djadeski, PlainName, shapirus and 37 Guests are viewing this topic.
« Reply #6550 on: June 11, 2018, 08:34:47 am »
I brought a "Laser"  ;D and will be wrapped up with a CR-10S 3D printer  8)
Pre EOFY Tax Time is Tool Time  :-+
« Reply #6551 on: June 11, 2018, 08:35:31 am »
Well I didn't know that what's the sticker meant, I thought it was a warning that it  had been checked and found to be needing calibration. Good job the seller didn't know that then, in fact they didn't know anything about it apart from what they had been sold for on Ebay and they quoted me 150 to 300 USD. I found one that sold as working for only 60USD and told the seller that unlike theirs, it was photographed working. As they couldn't power it up to prove it was OK, I offered a price for spares or repair and was accepted.
As I wasn't in need of another, already have sufficient so I was fully prepared to walk away from the deal if they said no. [emoji41]
From mobile device so predictive text might have struck again [emoji83]
« Last Edit: June 11, 2018, 08:37:34 am by Specmaster »
Offline bitseeker
« Reply #6552 on: June 11, 2018, 09:06:32 am »
Yep, that's the best position to be in for negotiations.
Offline McBryce
« Reply #6553 on: June 11, 2018, 09:37:45 am »
In our lab (and several others I've worked in), "not colibrated, indicator only" doesn't mean it's out of calibration. We have devices that get regular calibration, but don't want the expense of calibrating all instruments. However, the "non-calibrated" devices are checked against calibrated ones on a regular basis to make sure that they are within range, the only difference with the "non-calibrated" devices is that there is no verifiable calibration paper-trail.
McBryce.
Offline CatalinaWOW
« Reply #6554 on: June 11, 2018, 03:42:03 pm »
I agree that the not calibrated sticker only means that the unit is not on the normal calibration schedule.  I have worked at places where it also means that the only time it will be checked against other instruments is if the readings are so whacky that the person using it can't believe what they are seeing.
So if you are buying, a sticker like this should be interpreted as "probably not terribly wrong".
« Reply #6555 on: June 11, 2018, 04:53:48 pm »
Well now we have cleared that up, keep it under your hat and use it as a bargaining tool like I did  :-DD
Offline Richard Crowley
  • KJ7YLK
« Reply #6556 on: June 11, 2018, 05:37:07 pm »
When I first read that, I thought it referred to Donald Trump's position on meeting with Kim Jong Un
President Donald Trump says he's "totally prepared to walk away" if his meeting with North Korean leader Kim Jong Un is not productive.
https://www.cnn.com/videos/politics/2018/06/07/trump-maximum-pressure-walk-away-kim-north-korea-nr-bts.cnn
Offline Mr. Scram
  • Display aficionado
« Reply #6557 on: June 12, 2018, 02:26:08 pm »
I'd say it's not really a negotiation if you're not.
Offline GerryBags
« Reply #6558 on: June 12, 2018, 02:56:37 pm »
I had one of Leo Bodnar's fast-edge pulsers turn up today, very speedy as I only ordered on Friday night!  :-+
Looking forward to testing rise-times... once I've finished fixing my 'scope  :-/O
Offline Calambres
    • Piso-Tones
« Reply #6559 on: June 12, 2018, 04:19:07 pm »
ON-ON-ON mini switch.
Impossible to find at local stores so I had to web-buy.
« Last Edit: June 12, 2018, 04:21:05 pm by Calambres »
« Reply #6560 on: June 12, 2018, 04:36:07 pm »
I get to collect my Fluke 3390B tomorrow so I'll be posting some pics of it later, my first foray into the world of digital scopes apart from a DSO138 which many consider a toy but is really a pretty useful but basic digital scope with a stupidly low band width but good for checking if clock pulses etc are there and does provide rudimentary cursors and automatic measurements etc, especially handy as a floating scope.
Offline bitseeker
« Reply #6561 on: June 12, 2018, 09:13:35 pm »
I thought that was called a "jumper". ;D Thanks for including the diagram.
Offline Mr.B
« Reply #6562 on: June 12, 2018, 09:37:42 pm »
I am curious as to an application where such a switch might be used.
Can someone enlighten me.
I approach the thinking of all of my posts using AI in the first instance. (Awkward Irregularity)
« Reply #6563 on: June 12, 2018, 09:41:05 pm »
Transformer tappings?
Offline Mr.B
« Reply #6564 on: June 12, 2018, 09:43:23 pm »
Ah, yes, that makes sense.
Offline PTR_1275
« Reply #6565 on: June 13, 2018, 04:32:25 am »
We used to use them for measuring 3 battery bank voltages from one meter.
Offline bitseeker
« Reply #6566 on: June 13, 2018, 04:51:44 am »
That also makes sense. I had never seen a switch with this kind of arrangement before. Pretty useful.
Offline capt bullshot
« Reply #6567 on: June 13, 2018, 04:58:34 am »
It can be wired as a single pole, triple throw switch, like the ones with the rotating knob, but with a lever.
Quite useful back in the days, when you wanted to avoid additional electronics to emulate this behaviour with the more common ON-OFF-ON switch.
Offline Mr.B
« Reply #6568 on: June 13, 2018, 06:33:08 am »
I clearly don't have my Tetris hat on tonight.
How would that be wired?
Thanks.
« Reply #6569 on: June 13, 2018, 07:44:02 am »
Thanks.
Too lazy to make a sketch, so I try to describe it:
Common is middle pin of upper switch. Connect left pin of upper switch to middle of lower.
Pole 1 is left pin of lower switch,
Pole 2 is right pin of lower switch,
Pole 3 is right pin of uppser switch
The following users thanked this post: Mr.B, bitseeker
Offline Mr.B
« Reply #6570 on: June 13, 2018, 08:23:05 am »
Brilliant.
Thank you.
Offline Calambres
    • Piso-Tones
« Reply #6571 on: June 13, 2018, 08:32:15 am »
Those ON-ON-ON switches are widely used to soup up electric guitars but this is not my case (this time... have look at my signature ;) )
I've ordered it to finish my Mr. Carlson's "Ultra Sensitive Forecasting Capacitor Leakage Tester":
Offline JaspaJami
    • Susijarvi
« Reply #6572 on: June 13, 2018, 06:12:49 pm »
Arrived today. Both pass self test without problems but 33220A have some problems with rotary encoder. Seems that im not only one who have those: http://www.dasarodesigns.com/projects/cleaning-the-encoders-in-agilent-33220a-function-generators/
320€ totally posted to home. Not bad.
Wow, that's a great price. Just a 34401A can cost a lot more than both of these.
i agree, it was good deal.
Funny was that i was she was selling Agilent Power Supply that i bought from her for 120€. Well, there was a mistake and she didn't know that there was multiple different units and she had picture from wrong unit. Did see that before shipping and did say that actually she was selling 34401A and do i still want it for 120€. For sure i agreed. And then i asked if she has some more and there was still this 33220A that i agreed to buy for 200€
Offline Kjelt
« Reply #6573 on: June 13, 2018, 06:55:03 pm »
Bought this last week, was always on my wanted list but since the price now dropped <€100 I could not resist getting one, a Wiha Torque screwdriver with universal bitholder so I can use all my bits and set the torque on the screwdriver from 0,8Nm - 5Nm
Wiha, what else ?  ;)
Online thm_w
  • Non-expert
« Reply #6574 on: June 13, 2018, 09:03:55 pm »
Really impressed with this seller of COB LEDs. They have some unique designs, its mostly car oriented (12V rating) but they have lower voltage as well.
For 12V its about 9-11V across the LEDs depending on color, then the 3V ones are 1.9-2V or so. For the 12V I just used a resistor, for the 3V would need a small current regulated dc-dc ideally.
Don't get the triangular red/yellow LEDs yet, they appear to be rejects as one or two LEDs are not lit (still works OK though, as they are in parallel).
https://www.aliexpress.com/store/group/COB-bulb-chip/1657218_260583422.html
