jellytot and 13 Guests are viewing this topic.
It looks like you don't post code changes, only releases. And no bug tracker. Is this the case?
Single sided board, 128x160 Color display. I soldered a header on, the AVR is locked of course, so I can't dump the firmware to just give it a shot. I browsed the subversion repo and google'd all the different display variants but didn't notice one that would be appropriate for this one.
1. What would be the reason as to why my component tester is showing 15-18v
2. How do I go about upgrading this kit to the custom firmware that's around on the internet? I'm at version 1.12k currently.
if I go to the selection menu and select selftest, it works fine. What've I done wrong?
Wow. Looks like I ripped out the connection for that pin on the IC Socket. I'm going to have to get a new one. Thanks for the help!
2. The LDO at 3.3V from power which the display - very not reliable and ceases to work in case of connection of the programmator. Therefore it is recommended to disconnect or unsolder it before programming of the processor.
#ifdef LCD_ROTATE /* swap X and Y */ #define LCD_PIXELS_X LCD_DOTS_Y #define LCD_PIXELS_Y LCD_DOTS_X #ifdef LCD_OFFSET_X #define LCD_SHIFT_Y 3 /* shift y by 4 dots */ #endif #ifdef LCD_OFFSET_Y #define LCD_SHIFT_X 1 /* shift x by 2 dots */ #endif#else
Quote from: Argiros on April 05, 2018, 02:21:14 am<Argiros>Can I add a rottary switch button to this model GM328B ? Where I can solder this ? or else can I add 3 more buttons for using them for scrolling up down and for back ? <madires>You can use two push buttons for up/down (increase/decrease) instead of a rotary encoder (k-firmware: WITH_ROTARY_SWITCH 4, m-firmware: HW_INCDEC_KEYS, and check the portpins). The test button is mandatory, either as a separate push button or integrated in the rotary encoder. And there's no back button. As timelessbeing already has mentioned, the wiring is explained in Karl-Heinz' documentation.
I have added a protection relay to my tester. It is essentially the same as described in the KHK manual.
You don't need to enable anything in the k-firmware for using the protection relay. It's part of the basic code.
