Author Topic: What did you buy today? Post your latest purchase!  (Read 2818433 times)
shapirus and 24 Guests are viewing this topic.
Online Calambres
    • Piso-Tones
« Reply #5300 on: January 25, 2018, 12:32:18 pm »
I just received this (fake) Hakko FG-100 soldering iron tip thermometer. It arrived in just 11 days which is amazingly fast compared to other purchases I've made in ebay so far.
I've opened it up as per Dave's famous motto and it's the typical fake circuit without the trimmers or jumper to switch fom ºC to ºF (this one is in ºC). The make quality is not top notch, a bit on the cheap side but not that bad whatsoever. In the back of the PCB there are some unpopulated marks for a couple of thru-hole lytics, paralelling C3 & C7 SMD capacitors and a trimmer (VR1 - 1K).
The sensors blister clearly states: "contents 10pcs." but only includes 5  :)  To be fair, the original ebay ad clearly indicated 5 sensors, not 10.
It seems to work well although I have not a means to compare the temperature reading (yet... awaiting  ::)) . Goes up to 400ºC with my old trusty JBC iron.
Some photos below.
By the way... how can I put the attached photos in the text, not just at the end?  :-//
Offline paulca
« Reply #5301 on: January 25, 2018, 01:07:38 pm »
Have you noticed how hard it is to judge the scale of things from pictures and youtube videos?
I remember being surprised when I got my first 18650 cells at just how much bigger than AA's they actually were, but I'd seen dozens of youtube videos of people handling them.
Tuesday night I got a surprise when I opened the DSO112A scope.  It's absolutely TINY!  I'd watched several reviews of people handling them, but it never looked just that small.  It will literally it in the palm of my hand with virtually no overlap.
Offline ChrisLX200
« Reply #5302 on: January 25, 2018, 01:11:51 pm »
Just bagged this on eBay so I can experiment with my microscope to see if I can rig these LEDS up and reduce the amount of direct reflection back to the screen.
That could be just the thing to improve lighting, Let us know if it works :)
« Reply #5303 on: January 25, 2018, 01:23:16 pm »
Will do, it states that the inside diameter is 60mm and with those long screws it might just clamp onto the barrel of mine which is 34mm, failing that I should be able to source some longer screws, at least thats the plan. 8)
« Reply #5304 on: January 25, 2018, 02:04:44 pm »
This arrived today, although I already have a few ways to measure everything that this using more expensive equipment, I still like these cheap Chinese testers for quick tests they are actually more accurate then a lot of people give them credit for.
Here is the actual value using far more accurate meter but as you will see its not that bad.
And here is the same resistor being tested with another Chinese tester I got a while ago.
So all things considered I don't think there are that bad after all?
And now on my bench LCR meter
« Last Edit: January 25, 2018, 02:24:27 pm by Specmaster »
« Reply #5305 on: January 25, 2018, 02:29:55 pm »
Now for a test using Caps
I don't think the results are to shabby at all. :popcorn:
Online Calambres
    • Piso-Tones
« Reply #5306 on: January 25, 2018, 04:10:06 pm »
What is the "Vloss" reding for capacitors?
« Reply #5307 on: January 25, 2018, 04:27:35 pm »
Vloss is the percentage of volts that has been lost in the capacitor since the tester first charged it. A low value % is good as even a new one will have have lost some voltage as nothing is ever 100% perfect. As electrolytic's age, they dry out and the amount of drying out can be seen by the Vloss figure, the higher the value, the nearer a capacitor is to expiring so therefore it is wise to replace a capacitor that has significant Vloss and it is also very likely to have a high ESR reading as well.
The following users thanked this post: Calambres
Online Calambres
    • Piso-Tones
« Reply #5308 on: January 25, 2018, 05:24:23 pm »
But that should depend on the capacitance, right?
Online netdudeuk
« Reply #5309 on: January 25, 2018, 05:42:11 pm »
Some photos below.
I thought about getting one of these but surely you cannot rely on the readings ?
Online Calambres
    • Piso-Tones
« Reply #5310 on: January 25, 2018, 05:45:31 pm »
Online netdudeuk
« Reply #5311 on: January 25, 2018, 05:56:02 pm »
« Reply #5312 on: January 25, 2018, 06:27:02 pm »
Yes it does, ESR also depends on the capacitance value as well and both will be affected by the capacitor drying out as it ages and or is exposed to high levels of heat for extended periods.
Online Calambres
    • Piso-Tones
« Reply #5313 on: January 25, 2018, 07:30:56 pm »
Then... is there a table "a la ESR" for valid Vloss values?
Offline ManuelMcLure
  • WW1FA
« Reply #5314 on: January 25, 2018, 07:39:22 pm »
Yesterday I ordered a couple pairs of 1m 14AWG silicone stackable banana leads (https://www.ebay.com/itm/172002582714) and this morning I ordered an Aneng AN8009 to back up my main handheld DMM - an HP (none of this Agilent/Keysight junk) 974A (with ProbeMaster leads). I'll keep the 974A for when I need to work on high energy stuff, but the AN8009 has several features that the 974A doesn't. I could get the thermocouple probe for the 974A but it would cost me almost 3 times what the AN8009 cost!
Offline GreyWoolfe
  • NW0LF
« Reply #5315 on: January 25, 2018, 08:36:22 pm »
I have been on the hunt to find a broken piece of HP test gear to get the pushbutton caps to replace the broken ones on my HP 3312 Function Generator.  I was at the local surplus store and found an HP 5314A frequency counter that they hadn't looked at or priced yet.  After an inquiry, the owner said he would look at it and let me know a price but it would take a day or two.  I was getting ready to leave and saw he had it powered up and after saying he still didn't know if it worked, I could have it for $20.  I bring it home and make the mistake of hooking it up to a function generator for kicks.  Of course it works.  Now I have 2 pieces of gear that need the button caps. |O  The surplus store has 2 HP pulse generators that look good at $40 each, but I am afraid to bring one home and find out it woks also.  I hope to find something cheeeeeep at the Orlando Hamcation next month.
« Last Edit: January 25, 2018, 08:39:50 pm by GreyWoolfe »
« Reply #5316 on: January 25, 2018, 09:07:03 pm »
None that I'm aware of, there does exist many tables for various ESR values v Capacitance value but each manufacturer appears to have different values, these can be found if you google for them. The ESR is most critical value, it can effectively kill a piece of equipment if this value is high enough, particularly on power rails, instead of offering any AC ripple a route to ground, it shuts that route off and the AC gets into places where you don't want it to with dire consequences.
« Reply #5317 on: January 25, 2018, 09:21:59 pm »
Received today some goodies from forum member Franky (iloveelectronics):
The following users thanked this post: SeanB, Inverted18650
Offline bitseeker
« Reply #5318 on: January 25, 2018, 09:35:48 pm »
Don't you hate it when that happens?  ;D
3D print replacements? Or consolidate the original caps to one of the counters and get new ones (which likely won't be tapered like the HP ones, but still fit on the switch shafts) for the other.
Online rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #5319 on: January 25, 2018, 10:56:32 pm »
 :-DD That is the problem with quality gear - they actually survive the passing of time. I am on the same boat and I always promise myself to sell them before I get too attached. Obviously that does not happen...
US is a paradise for such gear, especially the local ads.
Offline rdl
« Reply #5320 on: January 25, 2018, 11:04:32 pm »
Those kind of pushbuttons are common, maybe an industry standard, and with a little digging you may be able to find some caps that will fit the plungers and work as a replacement. I seem to remember seeing some that were trapezoidal shaped when looking to fix my E3610A power supply. Or if you replace all of them, maybe regular rectangular types would look okay. Painting will probably be necessary for a color match though, all I could find was red and black.
Replacement caps on the bottom unit.
https://www.eevblog.com/forum/repair/hp-e3610a-does-this-look-worth-fixing/msg616470/#msg616470
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #5321 on: January 26, 2018, 02:03:47 am »
I have put up an antenna (horizontal loop) that seems to be a bit quiet re all the *******. SMPSU hash around here, so am firing up my boat anchor, an Yaesu FT 101E.  I found an external VFO unit (FV101B) to go with it. I have the receiver FRG-7, the monitor scope YO-100, now for the PA >:D
Rob, is that a Sparton Bluebird I see in the background?
-Pat
Offline kelchm
« Reply #5322 on: January 26, 2018, 02:15:37 am »
How does one go about finding a local surplus store like this?
Offline cdev
« Reply #5323 on: January 26, 2018, 03:24:18 am »
Areas that are blessed by a NASA center or national lab's presence often have good surplus stores.
Good book stores for lovers of technology books too.
Offline JoeN
  • We Buy Trannies By The Truckload
« Reply #5324 on: January 26, 2018, 03:58:35 am »
Sometimes those stores have insane prices.  I don't recall the details now, but I remember going to one such store in Los Alamos years ago, around 2003 and they had total junk the the prices were insane.  There wasn't anything remotely useful or in decent condition at any price, not even worth haggling.
Have You Been Triggered Today?
