Author Topic: What did you buy today? Post your latest purchase!  (Read 2818146 times)
BennoG, paulca, mahi and 38 Guests are viewing this topic.
Offline GreyWoolfe
  • NW0LF
« Reply #12900 on: March 01, 2024, 03:39:51 pm »
A Rohde & Schwarz NGL 35:
A Metcal MX-500P with a soldering iron, a desoldering tweezer and two stands:
A HP 4329A TOhm meter:
I have the same Metcal setup, my all time favorite system.
The following users thanked this post: Smokey, BU508A, pdenisowski
Online Martin72
  • Testfield Technician
« Reply #12901 on: March 02, 2024, 06:39:32 pm »
Arrived today, a cheap DC switching supply...
Good display, good display/output accuracy, slim fit.
Available in three versions, 0-30, 0-60 and even 0-120V, this is the 120V version.
Online Messtechniker
« Reply #12902 on: March 02, 2024, 08:45:38 pm »
These Jesverty thingies are interesting. Basically
I am in the market for dual 0-120 V 100 mA
(maybe even with a bit more umpf)
lab supply which will not cost an arm and a leg.
Intend use: High voltage Opamps. Since these Jesverties
apparently do not have a control input of some sort :palm:,
I would have to improvise to gang two such units.
Almost there. Maybe some day these things will sport
an USB control input. :popcorn:
Anyway, thanks for the heads up.
« Reply #12903 on: March 03, 2024, 01:30:49 am »
Remember to buy the model with the powerful inner core like I did  :-DD Also check and see if the output floats high relative to earth to avoid any surprises.
Online RAPo
« Reply #12904 on: March 03, 2024, 07:51:23 am »
Some nostalgia, a Micronta 22-204A.
Offline gamalot
  • Correct my English
    • Youtube
« Reply #12905 on: March 03, 2024, 08:19:33 am »
Which costs more, the compact power supply or pair of Hirschmann banana test leads?  :-DD
Online RAPo
« Reply #12906 on: March 03, 2024, 12:27:20 pm »
I found a hp3456a in working order.
The following users thanked this post: Peter_O
Offline pqass
« Reply #12907 on: March 05, 2024, 02:50:20 am »
I LOVE mine.
Not only is it gorgeous to look at but the math features are amazing; specifically the "(X-Z)/Y" and "100(X-Y)/Y" functions.
Although the meter does not offer a current post, you can first measure a small shunt (via 4-wire) then store that in register Y (STORE, 8 buttons). Attach probes across the shunt then enable "(X-Z)/Y" via MATH,7 buttons to show current directly!
Also, I'm currently exploring the "(X-Z)/Y" function to directly read ESR!  By (a) setting my FG to produce 1Vpp +0.5Voffset 200KHz square wave, 50R output Z, (b) the cap under test across the FG output, (c) a 100n cap (A/C coupling) to the 3456A set to ~V, (d) Y register set to the magic constant 0.006400, (e) then enable "(X-Z)/Y" via MATH,7 buttons to read out ohms directly.
Need to sort 10K resistors? Just punch in 10000 STORE 8 to save 10000 in register Y.  Enable "100(X-Y)/Y" via MATH,8 buttons, then proceed to measure your resistors.  The display shows % error directly.  Easy peasy!
Can't wait to buy a bunch of thermistors to play with the THMS*C function too.
« Last Edit: March 05, 2024, 07:04:21 pm by pqass »
The following users thanked this post: BU508A, Peter_O, RAPo
« Reply #12908 on: March 05, 2024, 07:04:47 am »
Pictures of my 3456A:
The following users thanked this post: pqass, Peter_O, RAPo
Offline woody
« Reply #12909 on: March 05, 2024, 02:49:58 pm »
Finally....
Oh, and not the Logitech, not the table, not the LP mess, but the Quad ;D
The following users thanked this post: Martin72, RAPo
Offline msuffidy
« Reply #12910 on: March 06, 2024, 01:24:54 am »
I got a Ti-89 Titanium used for $20 Canadian, and immediately flashed it to os version 3.10 using Linux TILP. Also I continue to mess with an Odroid C1+ that I got for $20 used with a 16GB SD card. I am still looking into it but it seemed to fail with certain SD cards on cold cold boot, but seems to be working with a certain SD card so far.
Online Martin72
« Reply #12911 on: March 06, 2024, 03:24:29 pm »
The first... ;)
Online pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #12912 on: March 06, 2024, 03:29:44 pm »
Well, I guess I technically didn't "buy" this, but I'm pretty sure I'm the first person to have one :)
« Last Edit: March 06, 2024, 03:41:48 pm by pdenisowski »
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
Free online test and measurement fundamentals courses from Rohde & Schwarz:  https://tinyurl.com/mv7a4vb6
The following users thanked this post: Sparky
Online pdenisowski
« Reply #12913 on: March 06, 2024, 03:44:35 pm »
Wow!  Very nice!
Online Martin72
« Reply #12914 on: March 06, 2024, 10:36:19 pm »
NPA stands for Network Problem Analyzer, I guess ?
Offline Bud
« Reply #12915 on: March 06, 2024, 11:01:59 pm »
I LOVE mine.
Data logger for 3456a based on MS Excel is here:
https://www.eevblog.com/forum/metrology/data-logger-for-legacy-hp-instruments/
Online pdenisowski
« Reply #12916 on: March 07, 2024, 01:13:26 am »
(laughs) Good guess.  Actually, we have a software feature in our cellular network drive test analyzers (ROMES/TSMx) called "NPA" and it does stand for "network problem analyzer," but that's not this :)
https://www.rohde-schwarz.com/us/manual/r-s-romes-npa-user-manual-manuals_78701-117121.html
We do have a scheme for at least the first letter of our three-letter product names:  F for spectrum analyzers, S for signal generators, Z for network analyzers (get it?), C for communications testers, etc.   N normally is used for power supplies (Netzgerät), so that might be a clue ... although this is not a power supply :)
We're launching it in a few weeks, so I'll be able to talk more about it then.  Every time the FedEx driver drops off a new instrument, it feels like Christmas morning to me, so I wanted to share what (little) I could.
The following users thanked this post: Sparky, BU508A, Edison
Offline TopQuark
  • Country: hk
« Reply #12917 on: March 07, 2024, 02:42:48 am »
DMM6500   :-DMM
Offline Edison
  • Country: cz
« Reply #12918 on: March 07, 2024, 09:40:47 am »
It's nice to have more Christmas mornings with a new device during the year 🤔 I can only buy the box in which the device is packed at most 😂
Everything works as the weakest link in the chain
The following users thanked this post: pdenisowski
Offline Edison
  • Country: cz
« Reply #12919 on: March 07, 2024, 10:00:53 am »
DMM6500   :-DMM
Beautiful piece, congratulations 👍 I bought a  6 1/2 DMM   2015 THD last year
Offline TopQuark
  • Country: hk
« Reply #12920 on: March 07, 2024, 11:05:21 am »
DMM6500   :-DMM
Thanks! I had a second hand K2000 too, and really liked it. Though it started to slightly drift out of alignment with everything else in the lab.
Getting a full calibration done for the K2000 would cost more than what I paid for it, so I decided to bite the bullet and get the DMM6500. Very happy with it so far!  ;D
The following users thanked this post: Edison
Offline McBryce
« Reply #12921 on: March 07, 2024, 12:57:10 pm »
DMM6500   :-DMM
And you won't regret it. Other than the annoying long boot time, it's an absolute pleasure to work with.
McBryce.
The following users thanked this post: TopQuark
Online RAPo
« Reply #12922 on: March 07, 2024, 04:21:27 pm »
I've bought a Vintage Keuffel & Esser K & E: N4080-3 LOG LOG DUPLEX TRIG Slide Rule With Case from the USA.
Offline Edison
  • Country: cz
« Reply #12923 on: March 08, 2024, 12:11:27 pm »
I also bought the DMM 2015 used, but from the service of measuring technology, so I have it adjusted.
I would also buy one, but I have to replace the oscilloscope first, so I'm saving up, I'd like an SMU 2461 - but I'd have to sell my body box for organs  :palm:
Congratulations on your purchase and may it serve you well :-+
Online pdenisowski
« Reply #12924 on: March 08, 2024, 12:50:07 pm »
GPIB breakout box for a ... project ... I'm working on
