Shodge, Carlcast34770 and 9 Guests are viewing this topic.
I installed this and it seems to have worked perfectly, with one exception. I cannot get the probe to compensate correctly on channel 1. On the other 3 channels I can get the probe compensated, but Channel 1 has a hump above the peak of the square wave regardless of the probe I use. Is this something wrong with the scope, or something wrong with the hack? Should I roll back to the non-hacked version? I'm not entirely sure how to resolve this.Thanks,Steven
It should be fixed in the next firmware version: https://www.eevblog.com/forum/blog/new-rigol-scope/msg2366808/#msg2366808
Will they allow users change the resistors and honor the factory warranty?
Any word on how they intend to handle existing units with what appears to be a manufacturing/design fault?
I got one MSO5074.I though I can dump many times with high bandwidth for data aquctation.but it's not possible.
If you send it in, it might come back with some new firmware that is not hackable...
Dear All,a little help to a novice: I flashed 01.01.04.04 on my MSO5074 and while I can ping the scope, ssh gives me "connection refused"... anyone has experienced this?
