Author Topic: What did you buy today? Post your latest purchase!  (Read 2819806 times)
BennoG, Calambres, Kim Christensen and 21 Guests are viewing this topic.
Online beanflying
« Reply #12125 on: April 14, 2023, 07:51:08 am »
But can it run Doom?
Why else do you think I went for the 5600G. 500+ FPS on 640x480 I reckon while this mini will likely peak at 1-200.  :-DD
I have actually done some testing with the Ryzen at 1080P you seriously could game with it providing you keep the settings wound back, hitting 60+ FPS wasn't hard to do on slightly older titles I had on a SATA drive I dropped in for a play.
The following users thanked this post: Ed.Kloonk
Offline McBryce
« Reply #12126 on: April 14, 2023, 07:51:32 am »
I thought Crysis was the benchmark?
McBryce.
The following users thanked this post: Ed.Kloonk, Atomillo
Offline deadlylover
« Reply #12127 on: April 14, 2023, 09:42:19 am »
If those HP G2 mini units give you trouble by shutting off randomly, you can try upgrading to the 95W adaptor (still really cheap used). That's how I salvaged a couple from the dumpster, they were "faulty".
They idle at like the 8-10W mark so I used to use it for 95% of my computing before I upgraded to a M1 Mac mini. My old gaming PC (or even a modern gaming PC) still idles at something stupid like 60W or so.
Offline tautech
« Reply #12128 on: April 14, 2023, 09:42:58 am »
Wanna mini PC that can fly, try a ASRock Jupiter:
https://www.asrock.com/nettop/Intel/Jupiter%20H470/index.asp#Overview
Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz  16.0 GB RAM with a 500GB SSD and about the size of a small box of chocolates.
CPU benchmark = 16,694
Selected for the greater than others # of USB A ports plus a good # of USB-C also.
Now a year about since getting it when the company workstation went tits up in the middle of a lockdown !  :rant:
Offline veedub565
« Reply #12129 on: April 17, 2023, 08:43:53 pm »
Latest purchase('s)
HP 8341B Synthesized Sweeper, 10 MHz to 20 GHz
HP 85101C Display unit
HP 8530A Microwave receiver
HP 8511A IF Downconvertor
HP 11667A Power Splitter
HP 8003A Pulse Generator
I think I've got a problem, and an addiction to old HP gear  :scared:
Offline SiliconWizard
« Reply #12130 on: April 17, 2023, 08:58:42 pm »
Depends on which century you live in. ::)
Offline rdl
« Reply #12131 on: April 18, 2023, 12:18:50 pm »
Well, I have it running MX Linux and I can play Quake on it so I'm pretty happy with it at this point.
Online gamalot
  • Correct my English
    • Youtube
« Reply #12132 on: April 18, 2023, 12:55:04 pm »
My LiteVNA was delivered today and first impressions were a little disappointing with the details on the plastic case.
Online paulca
« Reply #12133 on: April 18, 2023, 01:30:22 pm »
I was just about to post that I bought a new Mini PC, but I see others beat me to it!
Grabbed myself an HP Elitedesk 800 G2....  not what was delivered.  An HP Prodesk 600 G3 arrived.  Almost identical spec, looks nicer, slightly more recent, better memory.  Bonus!
£115.
Idle power:  6.5W
Installing Windows 13.5W.
Supports 4K 60FPS and ultrawide IF and only IF you are using DP or a proper active DP adapter.  It wont do it through a passive adapter, as it drops to HDMI specs.  I believe the port can detect the adapter, a DP++ port.
Offline jonpaul
« Reply #12134 on: April 18, 2023, 03:23:32 pm »
Bonjour à tous
Vintage HP 1990s linear metered (analog!) dual lab power supply 0..20,40V
Was just $44
one of the classics!
Jon
Jean-Paul  the Internet Dinosaur
The following users thanked this post: Mortymore
Online jpanhalt
« Reply #12135 on: April 18, 2023, 08:48:20 pm »
Not electronics -- actually it is.  I have been waiting for the next Nikon sale to get its Nikkor Z MC 105mm (macro with stabilization and autofocus).  I hated trying to photograph my little projects with an older (Y2K) Canon point and shoot SX100.  That came to its righteous end when it fell from my tripod onto a hardwood floor late last year.  In the70's, I had acquired a Nikon F in Hong Kong and eventually got the 55mm macro for it.  Once installed, I almost never removed that lens. Of course, using 35mm film is just not practical today.
The current 55mm macro for Nikon Z doesn't have great reviews, so i popped for the 105mm   Sure, a little bit of overkill.  Attached is my first image taken with it.  Hardly any attempt was made to steady my hands, focus, or not jerk when pressing the release.  I am impressed.  VR and autofocus do work.    The center footprint is for a TQFP44 chip. BTW: For a lot less you can get a good D70 and 55mm AI lens.  Not much advantage paying for useless pixels in the D80 or D90, but the D80's are still pretty cheap.
PS: That  is a Win7 snippet.  The actual image is quite a bit sharper.
Edit: I decided to upload a little better cropped version.
« Last Edit: April 18, 2023, 08:56:01 pm by jpanhalt »
Offline alm
« Reply #12136 on: April 19, 2023, 09:29:00 am »
Congrats! I find the increased working distance of the longer focal length macro lenses very helpful for high reproduction ratio shots. With the 55mm at 1:1 I find it very hard to light the subject without casting a shadow unless using a ring light. For lower magnification shots of say an entire PCB the shorter focal length is probably more convenient.
Note that the D70/D80/D90 won't have any exposure metering with lenses without chip (autofocus or AI-P). For that you have to step up to the D200/D300/D7000 etc.
Online jpanhalt
« Reply #12137 on: April 19, 2023, 10:05:05 am »
Thanks for the added advice, alm.  I was talking about going really cheap.  I got a D70 in great condition for $25 incl shipping, and the 55mm macro can be had for $25 to $30.  I paid about $50 for mine AI with caps and like new.  They are for a semi-permanent copy stand with known lighting.  Post-exposure adjustment gives one a large range of exposures.
I did not spend that much just to post a few pictures here.  I live in the middle of a woods with a pond.  Wildlife, particularly the variety of birds I see is great compared to my big city life up until now. I like to document them and get help identifying.  Raptors, including golden and bald eagle, visit not infrequently.  Over the weekend, I saw the first Northern Flicker of the year.  What I posted here was just a trial shot to see how well those modern enhancements work.  I was impressed, and frankly, a little excited at the moment.
Offline jonovid
    • JONOVID
« Reply #12138 on: April 20, 2023, 07:45:57 am »
Baby jewellers Milling Machine
this will Mill aluminum & plastics
jewellers work
built like a lego or meccano set, So its customizable , upgradable.
coffee mug is for scale
Offline armandine2
« Reply #12139 on: April 20, 2023, 01:22:15 pm »
https://www.farnell.com/datasheets/3216100.pdf
2off Surface Mount Technology Prototyping Eurocard
Funny, the things you have the hardest time parting with are the things you need the least - Bob Dylan
Offline Gary350z
« Reply #12140 on: April 20, 2023, 07:08:32 pm »
jewellers work
Can we get make and model, or link?
Offline tom66
« Reply #12141 on: April 20, 2023, 07:38:38 pm »
Finally managed to buy an EV.  I bought this VW ID.3, a 2.5 year old model with 30,000 miles odometer.  Wanted a fully electric car for a while and the price has come down enough to justify it - still a decent expense but the man-maths spreadsheet is doing a decent amount of work to justify it.   ;D
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #12142 on: April 21, 2023, 12:47:43 am »
I found a set of slitting saws in the local bargain shop for $7, I relayed an image to a mate and he said they are $5 in a nearby store so I told him grab another set. I have a collection of larger slitting saws and arbors for the mill but not much at hand for the dremels and die grinders so these will come in handy.
Offline jonovid
    • JONOVID
« Reply #12143 on: April 21, 2023, 09:29:32 am »
jewellers work
indirect sold on  AilxE  listed as mini milling machine
Foshan XENDOLL Intelligent Technology Co.,Ltd.  China www.xendoll.com
Model   W10004M
brand   or unbranded sold under other names
Technical Parameters:
Input voltage: AC100V~240V / 50/60HZ  plug pack
Output voltage: DC12V 2A
Motor rated power: 24W
Motor speed: 18000r/min±15% of high speed motor
Low speed motor: 10000r/min ± 15%
Spindle speed: high speed motor 3000r/min±15%
Low speed motor: 1600r/min ± 15%
Spindle jump: <0.1mm
Large slider stroke(X axis): 45mm
Small slider stroke(Y, Z axis): 35mm
Vise clamp size: 50mm*60mm
Chuck specifications: ф1, ф2, ф2.5, ф3, ф3.5, ф4, ф5, ф6
Milling cutter size: φ3, φ4, φ5, φ6
Handle scale: 0.1mm/division
Packing size: 325mm*200mm*240mm
Weight: 3KG
Processing ability: It can process wood, plastic and soft metals (pure copper and pure aluminum).
Package included:
1 x Milling Machine
1 set Accessories: 3pcs Inner Hexagon Spanner (S=2\2.5\3)
                              1pc Double Headed Wrench (S=14\17)
                              1pc Cross Screwdriver
« Last Edit: April 21, 2023, 09:37:43 am by jonovid »
Offline deadlylover
« Reply #12144 on: April 21, 2023, 11:40:14 am »
I had my first AAA LSD NiMH battery go high impedance serving remote control duty, a 2009 era Maha Imedion, it fails the C9000 impedance check upon charging.
The IKEA LADDA have gone down in price on the Australian store so I bought a bunch (they jacked the price a year ag). They have much cheaper shipping for small items now only $5, it would cost me more in petrol to go there and back. Use the $15 off $50 coupon if you haven't yet, you'll find it on ozbargain.
It's a shame they discontinued the 900mAh AAA cells, you can only get the 750mAh variants now. Oh well at 2 dollarydoos per cell I'm not complaining. Fingers crossed they're still the made in Japan variant.
Offline veedub565
« Reply #12145 on: April 21, 2023, 06:57:08 pm »
HP 8903B
Marconi 2305 Modulation Meter
HP 3325B (opt 001 & 002)
Online paulca
« Reply #12146 on: April 21, 2023, 08:43:52 pm »
Hmmm.  Who do you trust?
1766315-0
This is pretty cool though.  Top is the RDTech PSU, bottom is the Aneng meter on the battery being charged.  I don't even need to leave the sofa.
1766321-1
Offline tautech
« Reply #12147 on: April 21, 2023, 08:46:02 pm »
14.45 is charge target is it not ?
Online paulca
« Reply #12148 on: April 21, 2023, 09:17:14 pm »
Yes and no.
14.45V is the required PSU output to actually produce 14.40V across the battery.  It doesn't matter with 2 amps.  Does other times.
Raising charger voltage to account for voltage drop and trusting the battery is an advanced technique not suitable for being left unattended.
The BM235 says the Aneng voltage is reporting 30mV high.  It adds margin, so I'm fine for this test and these conditions.
It's on 13.63V PSU to produce 13.60V (Aneng) and 13.57V BM235.
The current I was looking for was about 0.01C + 1.4A load.  It settled higher about 200mA higher, so I switched it to float.  Current didn't change much at all.  Continues at 2.3A - 1.4A load.  I'd say it's charged.
Next phase is finding where it bottoms out on quiescent, load following.
Why?  Why not?  Fun?  Toys?
Offline tautech
« Reply #12149 on: April 21, 2023, 10:45:09 pm »
Yes and no.
Battery chemistry in use ?
