Author Topic: What did you buy today? Post your latest purchase!  (Read 2824919 times)
0 Members and 26 Guests are viewing this topic.
Offline HighVoltage
« Reply #1375 on: May 10, 2016, 02:44:22 pm »
..and then your meter would read bang on 0 to 5 places for sure!  :-DD
Not having such a sophisticated piece of test equipment - surely the horizontal and vertical spacing are not the same so you can't plug it in SIDEWAYS?
Sure, the spacing is the same in both directions and all 4 terminals are connected with this short.
You have to use it for zero check and calibration for all sophisticated Agilent meters.
Offline AF6LJ
« Reply #1376 on: May 10, 2016, 02:58:04 pm »
 :-DD :-DD
Must have been the last box on hand.
A static shielding bag? that has to be the dumbest thing I have seen all year (so far)
 :-DD
Sue AF6LJ
Offline mmagin
« Reply #1377 on: May 10, 2016, 03:09:27 pm »
I discovered recently that my HP 3478A has 'correct' 3/4" spacing for each of the two pairs of banana jacks, but the spacing between the pairs is not the same.
Offline bitseeker
« Reply #1378 on: May 10, 2016, 03:36:55 pm »
At least they didn't use color-coded banana plugs. :-DD
Offline JPortici
« Reply #1379 on: May 10, 2016, 06:53:43 pm »
there should be a tek7704 inside
won't be home until tomorrow evening   :scared: :scared: :scared: :scared:
Online DimitriP
« Reply #1380 on: May 10, 2016, 07:40:52 pm »
If it's the Rackmount model, be prepared for a loud fan.
Online wkb
« Reply #1381 on: May 10, 2016, 09:12:12 pm »
It is a "metrology" grade part, you would want it to get damaged in transport!!!
That box was ridiculous , I sometimes think the packers grab whatever container  is closest and stuff it in.
Well, no.  Small boxes tend to get lost in a corner.  Shipping air in big boxes therefore makes sense. I've had enough 'fun' with courier services to know.
Offline Macbeth
« Reply #1382 on: May 10, 2016, 09:28:57 pm »
But that's when you get hit in the wallet for the volumetric weight!
Offline Macbeth
« Reply #1383 on: May 10, 2016, 09:31:49 pm »
I wonder if there is something on that short PCB, like maybe the tracks are laid out in some fashion that requires the directional short with the indicated HI and LO positions? I can recall the Keithley version is laid out pretty much as a "H", maybe this one is more of a "U" IYSWIM?
Offline mmagin
« Reply #1384 on: May 10, 2016, 10:43:13 pm »
I love the capabilities of 7000-series scopes, but I hate how cruddy some of the overly-complicated switch mechanisms have gotten with time.  My dream would be the mechanical aspects of a 500-series with the capabilities of a 7000-series.  But now that I have two 7000-series scopes, it's obvious I don't have any common sense.
Offline bitseeker
« Reply #1385 on: May 10, 2016, 10:45:45 pm »
Yeah, I hate that!
Offline JPortici
« Reply #1386 on: May 11, 2016, 07:33:39 pm »
THERE IT IS
Damn this is big! No wonder these got their own dedicated trolley
then i plugged my modest collection of modules, a bit of tweaking and Bingo!
It really has been a long time since i used an analog scope i have to get used to it again
Small problem: every some minutes i hear a pop, the crt switches briefly off and on. What to do? the seller did say he just recapped and recalibrated the mainframe
« Last Edit: May 11, 2016, 07:36:38 pm by JPortici »
Offline mmagin
« Reply #1387 on: May 11, 2016, 09:25:25 pm »
I'd wanted one of these for a while, maybe motivated by the easter egg.  But they usually sell for more than I'd like.  Hopefully I can get one working HP 3314A out of these two, plus some spares:
Online wkb
« Reply #1388 on: May 11, 2016, 09:36:30 pm »
Not me paying, the company was.
Offline bitseeker
« Reply #1389 on: May 11, 2016, 11:10:53 pm »
I remember a CRT monitor that would do that. Curious what it is.
Offline Richard Crowley
  • KJ7YLK
« Reply #1390 on: May 11, 2016, 11:26:43 pm »
Sounds like the high accelerating voltage is arcing-over and then recovering.
I would first check all around the CRT neck and where the high-voltage wire connects (if it is externally?) and make sure everything is really clean,
Dust, grime, etc collecting on the envelope of the tube (or around the high-voltage circuit) will create a path for high voltage to arc-over.
Offline MrSlack
« Reply #1391 on: May 12, 2016, 06:47:25 am »
1x 74hc14n
2x Pedestal fans
Interested to see how that is going to be packaged ...
Well two fans squeezed in a box with an inch spare down the side and a tiny little bag with the 74hc14n in it stuffed down the side with some big inflatable padding bubbles. No damage. Miracle!
Offline McBryce
« Reply #1392 on: May 12, 2016, 07:48:47 am »
Yup, I'll second that. Arcing on the HT. It may just be damp dust, but check for cracks in the HT cable insulation too.
McBryce.
Offline tautech
« Reply #1393 on: May 12, 2016, 08:06:02 am »
McBryce.
Thread started on the subject.
https://www.eevblog.com/forum/repair/tek-7704-pops-and-clicks-image-compressing-for-a-moment/
Link fixed
« Last Edit: May 12, 2016, 08:28:19 am by tautech »
Offline McBryce
Offline mmagin
« Reply #1395 on: May 12, 2016, 06:53:37 pm »
One seems to just work (didn't do a full performance check yet) and has a noisy fan.  The other as some self-calibration error on startup, a dead rotary encoder, a strangely loose front panel, and an even noisier fan.
At least EBM-Pabst generally still makes the fans that fit these era HP instruments.
Offline welterde
« Reply #1396 on: May 12, 2016, 07:52:31 pm »
Got this Advantest TR5822 120MHz universal counter today.
Now just need to bodge together a GPIB interface (prices on the interface modules seem to be a tad bit overpriced for what they are)..
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #1397 on: May 12, 2016, 07:56:54 pm »
Is that the pair of them that I saw on the 'bay a couple of times?  Fingers crossed that you get two working ones when you're finished.  They're surprisingly LONG, aren't they?
-Pat
Offline mmagin
« Reply #1398 on: May 12, 2016, 10:14:49 pm »
Maybe.  I sniped both of them on the same day, and still spent less than 2/3 of what I usually see them go for in total.  They're certainly no longer than my 5342A microwave frequency counter - the one that works best may get stacked on top of it.  It seems I'm acquiring quite a few transistor-era boat anchors.
Offline Cubdriver
  • Nixie addict
« Reply #1399 on: May 12, 2016, 10:34:04 pm »
Ahh.  Not the ones I was thinking of, then, and perhaps it was even another instrument rather than the 3314a - somebody had a listing for a pair of them.  And boat anchors are a fine thing (IMO) to collect.  If you got both for less than 2/3 of what one ordinarily goes for, I'd say you made out well.
-Pat
