Author Topic: What did you buy today? Post your latest purchase!  (Read 2824524 times)
Gixy and 23 Guests are viewing this topic.
Offline ChrisLX200
« Reply #4950 on: December 22, 2017, 06:02:34 pm »
Reference distribution amplifier, which I ordered weeks ago, turned up today. I'd given up hope of seeing it before Xmas (or at all even..). That's it top-right in photo.
Offline bitseeker
« Reply #4951 on: December 22, 2017, 06:36:20 pm »
That's nice and compact. Looks like it might be able to sit beside your DIY dual-counter box.
The following users thanked this post: ChrisLX200
Offline ChrisLX200
« Reply #4952 on: December 22, 2017, 07:08:43 pm »
Doesn't quite fit unfortunately  :(
Like an idiot I thought the 3014B (now a 3054B :) ) had a reference IN for its timebase - it doesn't. There's also a phase difference between the distribution amp's two banks of 4 outputs (1-4 and 5-8), but it won't make any difference for what I do (I think).
« Last Edit: December 22, 2017, 07:14:10 pm by ChrisLX200 »
Offline bitseeker
« Reply #4953 on: December 22, 2017, 07:17:26 pm »
Oh, bummer. Hard to tell in 2D.
That's odd that all the outputs aren't driven simultaneously. Well, as long as you're not timing things at critical resolution between banks, should be alright.
Offline cdev
« Reply #4954 on: December 23, 2017, 12:42:35 am »
Antioxidants will protect them. That's a symptom I think of low glutathione. You should supplement with antioxidants like n-acetyl cysteine.  BTW, UV is much worse than IR.
http://www.dailymail.co.uk/sciencetech/article-4597594/Samsung-users-say-iris-scanner-causing-eye-discomfort.html
"studies have found that the protein found in the lens of the eye is very sensitive to the infrared radiation used in the biometric and when exposed, can lead to cataract"
You'd probably die when walking by IR LED CCTV camera's then.
I feel my eyes itchy every time I incidentally look at a plate IR illiminator in a car parking.
Offline Alex Eisenhut
  • Place text here.
« Reply #4955 on: December 23, 2017, 04:25:47 am »
Yes, it's quite silly but I managed to find powerline filters in the right form factor for half the Digikey price.
https://www.ebay.ca/itm/Tyco-Corcom-EMI-Filtered-Power-Entry-Modules-6A-120-250VAC-6609000-9-F7651-6EEAP/301575132396?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Booyah!
Offline boffin
« Reply #4956 on: December 23, 2017, 10:19:51 pm »
Tek 455.
Belonged to a co-worker, who had it from his (old old) job working for DEC.  (c/w Digital Equipment Corp Canada stickers).  Price was right "Hey, it's taking up room in my basement, do you want it or should I just throw it out?"
Now the big question is:
  • Keep it (along with my Philips PM3216)
  • Keep the Tek 455, give away the Phillips
  • Keep the Phillips and give away the Tek
I'm actually leaning toward the latter of the three because I the Phillips is a tiny bit smaller, and the Tek came from a smokers' household and has a slight smokiness to it. (and no, 50 vs 35MHz, and the additional trigger options aren't really something I need)
« Reply #4957 on: December 23, 2017, 10:28:13 pm »
Tek 455.
Personally I'd keep them both and the smell of the smoke is mainly going to be in the document pouch which can be removed and thrown away, or you can treat with something like Febreze to get rid of the odour. There will a little on the 465, but can be given a good wash and clean up and I'd spray a little Febreze inside as well.
I got an Hitachi scope from a house that smoked, and no one in my house smokes but since I did that with the Hitachi I have not had a single mention about the smell of smoke, it has gone completely.
Offline GreyWoolfe
  • NW0LF
« Reply #4958 on: December 24, 2017, 12:42:49 am »
What specmaster said.  You have officially started on the path to TEA, young Padawan.  Beware of the Dark Side.
Offline bitseeker
« Reply #4959 on: December 24, 2017, 01:12:42 am »
Yes, ensure you have sufficient lighting on your bench. ;D
Offline neo
  • The specialist.
« Reply #4960 on: December 24, 2017, 01:55:51 am »
Is 5000 lumen spotlight enough?
My 10k lumen one blew up and melted the copper cord.  :-DD
Offline Terry01
  • Country: scotland
« Reply #4961 on: December 24, 2017, 02:28:27 am »
Feeltech FY3224s 24MHz function generator.
Only took 3 weeks to come from HK to UK even with all the Christmas stuff. I didn't expect to see it till after the new year so....score!  :-+
I had a quick play around hooking it up to my DSO scope earlier today and found it to be much more usable than the XR2206 DIY kit i have now and it seems to have had the live BNC jacks problem sorted that I've seen the ones reviewed on YouTube have. It came with a 3 pin UK plug as requested but still only a 2 pin figure of 8 connection into the machine itself. I'll fix that in time though.
I'll have a proper look over it after Christmas. I'm still very new in to electronics so looking forward to that.
Sparks and Smoke means i'm nearly there!
Offline GreyWoolfe
  • NW0LF
« Reply #4962 on: December 24, 2017, 03:07:18 am »
Nope.  8 foot bench, 2 10k lumen 4foot fixtures.  SWMBO complains about the sun in the house.
Offline Mr. Scram
  • Display aficionado
« Reply #4963 on: December 24, 2017, 03:17:31 am »
Maybe you should make it rain.
Offline neo
  • The specialist.
« Reply #4964 on: December 24, 2017, 04:35:55 am »
Well i didn't buy it, the wallet did as a Christmas present. 6 year old white cheddar, 5 pound block at just over a buck an ounce.
I guess she got tired of me drooling on the computer monitor  :-DD
Offline nanofrog
« Reply #4965 on: December 24, 2017, 04:47:21 am »
And how many keyboards did you end up replacing?
Offline neo
  • The specialist.
« Reply #4966 on: December 24, 2017, 04:48:41 am »
None actually, i'm a very restrained drooler.
Offline nanofrog
« Reply #4967 on: December 24, 2017, 05:13:53 am »
Hold on... You've about broken your Pavlovian programming?  :o
Please spill.  ;D
Offline neo
  • The specialist.
« Reply #4968 on: December 24, 2017, 05:21:23 am »
Please spill.  ;D
I'm sorry i'm a bit confused as to what exactly you mean?
Offline AF6LJ
« Reply #4969 on: December 26, 2017, 08:34:03 pm »
This deal has been in the works for some time now.
My labor, and parts fixing a Heathkit HL-2200 yielded these...
About 100' of 1" 5/8 hardline, and a box of connectors for same.
Then....
A Henry 3KA console amplifier, this needs work, and will be a project for this summer.
Sue AF6LJ
« Reply #4970 on: December 26, 2017, 08:38:54 pm »
Then....
If you don't mind my ignorance Sue, but what are these, are they something to do with being a radio ham? If so then thats why I'm in the dark  :popcorn:
Offline Richard Crowley
  • KJ7YLK
« Reply #4971 on: December 26, 2017, 09:11:34 pm »
Hardline is flexible waveguide. Think of it as coaxial cable on steroids. Typically used for connecting high-power transmitters to antennas, etc.  I have seen it as big as 4 inches (100mm) diameter for high-power broadcast transmitters.  I believe it goes up to 6 inches.
The power amplifier is essentially a "booster transmitter"  You can take the RF output from a "regular" transmitter (perhaps up to 100W) and it will boost it up to perhaps 1000s of watts.  That is how most broadcast transmitters work.  There is a small "transmitter" (commonly called an "exciter") which actually produces and modulates the carrier. A couple of modern UHF TV stations I work with have a transmitter (exciter) in a 1RU chassis.  But then the output of the "transmitter" is fed into one (or many) power amplifiers which simply take that RF and boost it up to the final transmitting power.
Offline AF6LJ
« Reply #4972 on: December 26, 2017, 09:41:08 pm »
Richard has it right.
The amplifier with 150W in will put out 2000W.
The hardline besides being used for high power also has much lower loss than regular coaxial cable. If you are serious about operating on the VHF and above amateur bands hardline is the preferred transmission line.  However.....
Connectors cost in the neighborhood of $70.00 US and up.
Sue AF6LJ
Offline nanofrog
« Reply #4973 on: December 26, 2017, 11:26:41 pm »
Please spill.  ;D
Sorry about that. :-[ I was reminded of Ivan Pavlov and his experiments with dogs in the field of psychology.
If you're interested, take a look at the Classical Conditioning page from wiki.  ;)
Offline neo
  • The specialist.
« Reply #4974 on: December 27, 2017, 12:08:57 am »
Please spill.  ;D
My fault for being a bit dense, that definitely is interesting.
