Author Topic: What did you buy today? Post your latest purchase!  (Read 2828701 times)
0 Members and 26 Guests are viewing this topic.
Offline SingedFingers
« Reply #2650 on: February 17, 2017, 01:21:16 pm »
I'm going to try when the dymo is delivered and let you know :)
The children escaped unfortunately. They saw it coming. So I labelled my new power supply...
Sooo.... what next. Everything!
Edit: actually my wife has stolen it and is now labelling all her books with "MY BOOK"
« Last Edit: February 17, 2017, 01:23:58 pm by SingedFingers »
Offline bitseeker
« Reply #2651 on: February 17, 2017, 06:32:42 pm »
Those labels look good. Are they easy to apply? I've tried a couple of the Brother P-Touch label printers and they are they're rather fiddly to get the backing removed from the label tape.
« Reply #2652 on: February 17, 2017, 06:45:20 pm »
They are quite difficult for me because I have banana fingers. There is a slit lengthwise down the entire reel which makes it slightly easier.
Still miss programming Intermec printers in the late 1990s. Those were much more fun :)
Offline bitseeker
« Reply #2653 on: February 17, 2017, 06:48:21 pm »
That sounds much better for getting the backing off. Thanks!
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #2654 on: February 17, 2017, 08:01:05 pm »
The Brother P-touch label maker I now have uses tape that's got the lengthwise slit on the back now, too.  Makes them much easier to apply - peel half and get it positioned, then peel the other part.  At my previous job we had one of the earlier p-touch printers with the non slit backing and they were definitely a bear to peel.
Difficult to remove or not, they're still a thousand times easier than the old Dymo labels made on the embosser.  Spin the dial, squeeze the handle, and without fail the next letter needed would be on the opposite side. Thkthkthkthkthk-click  Thkthkthkthkthkthkthkthk-click  Thkthkthkthkthkthk-click and then near the end you'd screw up and land on the wrong letter and need to start again.   |O  that and the natural curl of the tape made them want to pop off if not thoroughly stuck down to an immaculately clean surface.
-Pat
« Reply #2655 on: February 17, 2017, 08:18:18 pm »
Dymo tape, the best way to stick it down was to use solvent welding, or contact adhesive.  Otherwise after 10 years all that was there was a brittle adhesive imprint, with the label curled up below it.
Offline bitseeker
« Reply #2656 on: February 17, 2017, 08:38:13 pm »
Ahhh, the memories! Trying to get all the letters the same shade and/or evenly embossed would give you OCD if you didn't have it already.
Offline tkuhmone
« Reply #2657 on: February 17, 2017, 08:46:22 pm »
Agree with Dymo labels, I have same label writer... Sometimes I use exacto knife to grab the back paper. Dymo labels that I used in last 15 years, will turn slowly darker during longer period if eposed to warm temperature. I had few stickers on the laptop, color goes from white to brown :-)
I also do labeling of extension cords (using long piece of label around wire) with Dymo.
Timo, OH7HMS
« Reply #2658 on: February 17, 2017, 09:07:26 pm »
I got the transparent ones for this work. I expect them to yellow slightly over time.
Offline djos
« Reply #2659 on: February 17, 2017, 10:02:12 pm »
Thankfully the Epson label makers have this too.
Offline mtdoc
« Reply #2660 on: February 17, 2017, 10:13:12 pm »
Some capacitor decade substitution boxes.
2 vintage Cornell Dubiliers and 1 newer with larger value electrolytics
Offline Cubdriver
  • Nixie addict
« Reply #2661 on: February 17, 2017, 10:37:17 pm »
I don't think it even took that long!  I have sets of drawers with the loose curved labels sitting in the recess on top of the drawer pull.  At least they didn't go too far astray.   :-DD
-Pat
Offline bitseeker
« Reply #2662 on: February 17, 2017, 11:33:05 pm »
The Cornell Dubilier substitution boxes look so cool. I almost bought a whole set of them a couple years ago. They would've taken a lot of space though, as compared with the thumbwheel decade types.
Offline Vtile
  • Ingineer
« Reply #2663 on: February 17, 2017, 11:40:47 pm »
Try with sharp SMD tweezers works..
Don't forget to label the labels.
Offline mtdoc
« Reply #2664 on: February 18, 2017, 12:02:18 am »
I didn't buy them because they look cool. I  bought them because I need them. Really, I do.. ;)
Offline Cubdriver
  • Nixie addict
« Reply #2665 on: February 18, 2017, 12:56:40 am »
Shouldn't this be in the TEA thread?   :P
-Pat
Offline bitseeker
« Reply #2666 on: February 18, 2017, 01:03:41 am »
LOL, you guys crack me up.
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #2667 on: February 18, 2017, 01:08:13 am »
Run - don't walk - to this thread and get help!
Test Equipment Anonymous Group Therapy
Offline bitseeker
« Reply #2668 on: February 18, 2017, 01:32:56 am »
No worries, mtdoc is already a resident. :-+
Offline djos
« Reply #2669 on: February 18, 2017, 02:10:43 am »
I think I'll be making a trip to aldi next weekend, I need some more component shelves and the little air compressor should meet my minimal needs nicely.
Offline gamalot
  • Correct my English
    • Youtube
« Reply #2670 on: February 18, 2017, 07:26:25 am »
I like ALDI.  :-+
Offline djos
« Reply #2671 on: February 18, 2017, 07:36:31 am »
I like ALDI.  :-+
Me too, even some of their 20v (seriously marketing dept, they are 18v!) lithium tools are pretty good for the home gamer like me,  You just need to buy at least 3 of the batteries so if you are working the tools really hard, you can swap in a fresh pack when the batteries temp protection kicks in.
« Reply #2672 on: February 18, 2017, 09:41:05 am »
Annoyingly not in UK those deals :(
Offline mmagin
« Reply #2673 on: February 19, 2017, 12:56:33 am »
Incredibly cheap demagnetizer, the line cord is 0.5mm^2, the plug is one of those Chinese plugs that's like a NEMA 1-15 but not quite.  I wouldn't leave it unattended, but it did the job cheaply of demagnetizing my diagonal cutters nicely.  This is the guts of it:
Offline nctnico
« Reply #2674 on: February 19, 2017, 01:05:50 am »
I ordered a hot plate:
I hope it will help to preheat boards for assembly and rework jobs using hot air. I'll check the inside (wiring) before plugging it in.
The following users thanked this post: AF6LJ
