Author Topic: What did you buy today? Post your latest purchase!  (Read 2830567 times)
krish2487 and 24 Guests are viewing this topic.
Offline bitseeker
« Reply #2800 on: March 14, 2017, 09:53:34 pm »
I'm really going to be the MeterMeister if I ever get all of the damned things up and running!
Just don't turn 'em all on at once or the electricity meter will be the new master of your pocketbook. ;D
Offline Kjelt
« Reply #2801 on: March 14, 2017, 09:56:52 pm »
Scored a NOS weapon grade keyboard from local computer warehouse for $10, the legendary buckling spring keyboard.
The seller let it go since he claimed its no longer can be used at today's laptop anymore  >:D, but at that price as it's "branded".  ::)
PS : Anyone know how to clean the heavily tarnished 5 pins of the DIN connector without destroying the plastic housing ? (photo attached)
I thought you could attach a different cable with ps2 connector (purple small din) that should still work with an adapter on usb. Have to search but i thought i still have such a keyboard somewhere.
Online BU508A
« Reply #2802 on: March 15, 2017, 06:28:28 am »
Have you considered this?
http://thesignalpath.com/blogs/2017/02/01/deoxit-challenge-restoration-of-a-precision-decade-resistor-box/
Offline VK5RC
« Reply #2803 on: March 15, 2017, 09:14:11 am »
I would probably go with a very lightly abrasive paste like Simchrome or Brasso or toothpaste perhaps inside a piece of just slightly larger insulation - placed over the pin (one at a time)  and spun by hand - then a really good clean with IPA.
Online Messtechniker
« Reply #2804 on: March 15, 2017, 09:56:53 am »
And after that, I would verify the cleaning action by running a 4 wire milliOhms measurement across all pins of socket/plug connection. For this solder the leads from the DMM to the respective solder tabs on the plug, respectively socket. Then compare your measurement with the data sheet - which does not give any mOhms contact info.  :palm:  |O
Therefore some of my measurement results on an old and well stored 5 pin DIN connector:
Contact resistance after years of storage (slight oxidation is visible): 35 mOhm
Contact resistance after cleaning with "Kontakt 60" (a popular deoxit fluid in Germany): 7.6 mOhm.
There you go.
Yours - Messtechniker
« Last Edit: March 15, 2017, 11:18:37 am by Messtechniker »
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« Reply #2805 on: March 15, 2017, 10:47:11 am »
I have bought a lot of odd chips the past week:
* AT91SAM9260B-QU 180MHz ARM926EJ-S MPU in QFP-208
* MT48F32M16???? 64MB x16 PC-133 SDR SDRAM in TSOP-56
* K9F2G????? 256MB x8 SLC NAND in TSOP-48
* K9F4G????? 512MB x8 SLC NAND in TSOP-48
* V3s 1.2GHz ARMCortex-A7 MPU with built-in 64MB DDR2 SDRAM in QFP-128
* AXP203 system power management IC for V3s in QFN-48
* LM3671MF-1.8 1.8V synchronous buck converter in SOT23-5
* M80C88 16-bit MPU, along with the full IBM PC XT chipset, in DIP
* IS61C256AH-12 SRAM in TSOP-28, a lot of them
* SN74HC138 decoder in TSOP-16
So I basically bought parts for three SBC: an ARM926EJ-S one with 64MB RAM and 512MB NAND and 4MB NOR, a Cortex-A7 one with 64MB RAM and 16MB NOR, as well as an IBM PC XT clone with 1MB of fully static RAM
Offline BravoV
  • +++ ATH1
« Reply #2806 on: March 15, 2017, 12:26:31 pm »
Really good idea, never thought of using larger cylindrical shape plastic to clean it abrasively, thank you !  :-+
There you go.
Damn, how did you know I measure those pins with 4 wires at sub miliohms resolution ?  >:D
C'mon, that thingy probably is now considered an antique, and also collector's item. Cleaning that darken DIN pins is for aesthetically reason, not technical at all. Those dark/black coating on the brass pins will just conduct fine when inserted into the DIN socket.
« Reply #2807 on: March 15, 2017, 09:28:24 pm »
This is the situation where a KS 34465A shines. :)
Offline FrankBuss
    • Frank Buss
« Reply #2808 on: March 17, 2017, 09:07:11 am »
I couldn't resist and bought some Nixie tubes from Dalibor Farny to build my own Nixie clock. He creates gorgeous new Nixie tubes. The packet arrived today:
Bottom side:
and a quick test, it looks so beautiful :-+
The following users thanked this post: deephaven, jonovid
Offline Kjelt
« Reply #2809 on: March 17, 2017, 09:23:37 am »
They cost $145 a piece ?  :o :scared:
Well as long as you enjoy them as art  :)
Offline djos
« Reply #2810 on: March 17, 2017, 09:31:23 am »
OUCH!!!
They do look incredible tho.  8)
Offline FrankBuss
    • Frank Buss
« Reply #2811 on: March 17, 2017, 09:36:08 am »
Right, they are not cheap, but they are hand-made and I don't know any other supplier who creates such beautiful new tubes, and they come with a 10 year warranty. There are more expensive new-old-stock Nixie tubes on eBay, but you can't be sure of the quality.
Offline Kjelt
« Reply #2812 on: March 17, 2017, 09:40:52 am »
Well at least that answers my first question, why not 6 tubes and display the seconds  ;D
These tubes deserve a beautiful case, what are you planning, wood , stainless steel or perhaps a marble or granite pedestal ?
Offline FrankBuss
    • Frank Buss
« Reply #2813 on: March 17, 2017, 10:18:34 am »
Yeah, I thought about the seconds :D but then I don't really need it. I plan to use some antique big wooden clock (sold broken on eBay) to create a steampunk like clock, and two digits on each side fits perfectly.
Offline jonovid
    • JONOVID
« Reply #2814 on: March 17, 2017, 11:14:49 am »
having way too many oscilloscopes seems to be an eevblog thing  ::)
Offline razberik
  • Country: cz
« Reply #2815 on: March 17, 2017, 11:37:32 am »
Makes sense in terms of prices. And IN18 prices are ridiculous. But when you buy IN12 which are cheap and available in large numbers, these nixies are made with so damm long life time. 100 000 hours no exception. USSR made them with insane lifetime margin.
Offline technix
  • Country: cn
    • My Untitled Blog
« Reply #2816 on: March 17, 2017, 12:28:26 pm »
Maybe. I have two flanking my work area (a hacked DS1054Z and a YB4325 20MHz CRO) and I mainly use the 1054Z now. However there is something about seeing the green traces on the CRO.
Offline alank2
« Reply #2817 on: March 17, 2017, 12:35:47 pm »
Those tubes are beautiful Frank - be sure to show us the final project picture with them!!
Offline RoGeorge
« Reply #2818 on: March 17, 2017, 02:16:23 pm »
Try with pencil eraser: https://hackaday.io/project/7574-the-devil-is-in-the-details/log/26489-a-pencil-eraser-trick
Offline Kjelt
« Reply #2819 on: March 17, 2017, 02:32:45 pm »
That reminds me of my scavenger hunt last week on a fleamarket that is kept once a year and where leftovers are sold from a smt place business.
My score this year:
Panasonic SMD elco's:
330uF/16V
4u7/50V
10uF/50V
470uF/16V
TH Fujicon (is that a decent brand or should i scrap them?)
2200uF/63V
and some bags with RJ45's, Phoenix 8pin connectors, dc-dc converters,
8 pcs of AD734AN (no idea what to do with those, anyone have an idea?), DS1225, 7808s
Just to stock up for my projects the next 25 years  :-DD  if the elco's survive that long , I already have quite a collection from past years hunts.
Offline AF6LJ
« Reply #2820 on: March 17, 2017, 03:00:25 pm »
I think you are stocked up. :)
Sue AF6LJ
Offline bitseeker
« Reply #2821 on: March 17, 2017, 03:35:21 pm »
That's a great idea, Frank. I like the analog and digital combination. That clock is perfect for it. Looking forward to seeing yours with those big Nixies.
Offline FrankBuss
    • Frank Buss
« Reply #2822 on: March 17, 2017, 04:10:32 pm »
Thanks. I just opened the clock and it comes with a built-in audio device :) After all this years I still remember the sound, my grandparents had such a clock, too (each full hour: dong - dong - dong...). Will add some solenoids.
« Last Edit: March 17, 2017, 04:14:41 pm by FrankBuss »
Offline bitseeker
« Reply #2823 on: March 17, 2017, 04:14:12 pm »
Cool. You should start a thread for this for all of us clock (analog or digital) fans.
Offline rrinker
« Reply #2824 on: March 17, 2017, 04:39:08 pm »
 A nixie clock that chimes the hour with real mechanical chimes - that is AWESOME. Can't wait to see this.
