Author Topic: What did you buy today? Post your latest purchase!  (Read 2825584 times)
0 Members and 33 Guests are viewing this topic.
Offline veedub565
« Reply #11675 on: November 10, 2022, 07:12:37 pm »
Bought a few items from the latest PP auction
Weinschel 150W 10dB attenuator
2x Leica GLS 100 lamps  - They're missing the light pipes, but I fished a couple of these from a skip a while ago. So all good, assuming the bulbs aren't dead in which case may be a waste of money.
HP 8011A Pulse Generator - (sorry ICETEA) It's a nice little unit, will fit well on the bench.
Narda 150W 3dB attenuator - I do actually need this to go between the output of my 2m radio rig and the input to my amplifier.
HP 5326B Timer/Counter/DVM - I'm a sucker for nixie's
HP8662 Sig Gen - Got a bit carried away, but I do like boat anchors  ;D
HP8132A Pulse Generator - Spares or repair, this might be a nightmare/lost cause with all the custom parts inside. Hopefully not, otherwise you might see it for sale again !
« Last Edit: November 10, 2022, 07:15:26 pm by veedub565 »
Offline blackfin76
« Reply #11676 on: November 10, 2022, 08:01:20 pm »
Wandel & goltermann SPM-19
Philips PM5132 function generator, which matches nicely with my PM3225 oscilloscope.
Offline veedub565
« Reply #11677 on: November 10, 2022, 08:41:31 pm »
Ooh SPM-19 niice  :-+ I do want one of those.
Offline TheNewLab
« Reply #11678 on: November 10, 2022, 08:45:09 pm »
NanoVNA and TinySA. I am hopeless for these miniture test equipment gadgets
Offline RAPo
« Reply #11679 on: November 12, 2022, 01:03:20 pm »
An inductive amplifier for Eu1,--
Offline RAPo
« Reply #11680 on: November 12, 2022, 01:04:44 pm »
A megger but it is over voltage (should be 500V)
Offline RAPo
« Reply #11681 on: November 12, 2022, 01:07:21 pm »
A very old megger, you have to crank up the voltage manually. Doesn't work but is a nice heavy paperweight. ;)
The following users thanked this post: jonovid
Offline RAPo
« Reply #11682 on: November 12, 2022, 01:09:42 pm »
A Kyoritsu Kew Snap 5
Offline jonovid
    • JONOVID
« Reply #11683 on: November 12, 2022, 01:49:57 pm »
Megger  8)  my father had one.  get it repaired if u can.
also I want  , Philips PM5132 function generator  :-+
Offline McBryce
« Reply #11684 on: November 12, 2022, 05:20:05 pm »
@RAPo: Megger output voltages are always way off and highly dependent on the load.
I have two working versions of these vintage "crank Meggers". Unfortunately, many of them on offer on ebay are non-working, usually because some idiot saw a voltage scale and tried to measure voltages with them, which instantly destroys the coils. Inside they are extremely interesting though. They have hand wound resistors and the crank cogs are made of some sort of paper/resin mixture to isolate the generator from the crank handle. The case is usually a grained redish bakelite material which also looks cool for display purposes.
But even non-working versions can still be used as a quick and dirty HV voltage source (if accuracy isn't important).
McBryce.
One of mine....
« Last Edit: November 12, 2022, 05:21:57 pm by McBryce »
Offline Calambres
    • Piso-Tones
« Reply #11685 on: November 12, 2022, 06:34:31 pm »
I've got a newer version, the Megger WM4. It works like a charm!
(Photo stolen from somewhere in the web  ::) )
The following users thanked this post: RAPo
« Reply #11686 on: November 12, 2022, 07:00:55 pm »
No you don't, trust me you don't.
Its brother the 5131 was my first FG and I couldn't replace it quick enough with a proper AWG and then the Philips sat on the shelf for some years until someone came along that only required a very few basic features..
Want to set an accurate frequency with one of these, just forget it, no way unless you had a counter connected to it at the same time and then watch it drift !  :horse:
Really you don't want one.
« Last Edit: November 12, 2022, 08:55:40 pm by tautech »
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #11687 on: November 12, 2022, 07:03:16 pm »
Heh. No worries. For future reference: you can always drop me your username in a PM. I try not to bid against established forum members if I an avoid it. Quite possibly I might not look at the 'other guys' name in the heat of the moment but otherwise I won't bid against you.
Offline veedub565
« Reply #11688 on: November 12, 2022, 07:13:04 pm »
They seem to be about £50 to £100 on ebay, so I still got it cheap. It's a shame someone screwed a nameplate into the front panel on that one, but hey ho.  I'm going past Aunby next week anyway on my way to Fluke, so I haven't got to pay shipping.
Offline blackfin76
« Reply #11689 on: November 12, 2022, 09:45:53 pm »
I love analog function generators, lots of dials and buttons to push  ;D
The PM5132 has excellent performance for an analog signal generator and it does 30Vpp which is more than most cheap function generators these days.
The PM5132 has a short term drift that is at least one order of magnitude better than that of the PM5131. It's more like Tiny Tim.
Of course you don't use this sort of equipment for stable frequency reference, but it's acutally not that bad either.
I happen to have a counter.
Drift over 500 seconds was 0,036%, which is well within specification.
I also have a PM5193 it's the 'Big Brother' of the PM5131, PM5132 and PM5134. It has a drift that smashes the PM5132 by at least three orders of magnitude when it comes to stability.
It's all good, but sometimes you just need to whistle or need manual pulse width control and in those cases I prefer good old analog stuff.
« Last Edit: November 12, 2022, 09:47:33 pm by blackfin76 »
The following users thanked this post: tautech, exor
Offline RAPo
« Reply #11690 on: November 13, 2022, 10:53:06 am »
Thanks for your photos.
The needle of the meter is all over the place.
I have a decent new merger so I'll keep the red thingie as is  :D
Offline McBryce
« Reply #11691 on: November 13, 2022, 11:09:30 am »
The guage in these Meggers are a complicated arrangement. The needle has two coils pulling in opposite directions, comparing the current of the generator (across a resistor) to the returning current. Connecting any source to the meter will fry these coils immediately.
McBryce.
Offline nigelwright7557
    • Electronic controls
« Reply #11692 on: November 14, 2022, 01:05:33 am »
I bought a McGregor mixer amplifier off ebay.
Looked in good condition.
However all volume controls were very scratchy and speaker jack sockets were in poor condition and not making good contact.
It wasnt sold as spares or repair so I complained to seller.
He refunded me and told me to dispose of it.
It probably needs about £30 of components to fix it and maybe an hour or two of time.
So basically beyond economical repair.
I fixed the speaker jack socket and just use it in the house as its not reliable enough for gigs, pots too scratchy.
It is a pig to get open and I cant see how to get front panel out as wooden blocks in the way of removal, so poor design.
Shame as its a nice looking amp with front illumination.
Online themadhippy
« Reply #11693 on: November 14, 2022, 02:22:45 am »
That brings back memory's.Although the version i remember  had much more dirt ingrained in it and often an apprentice attached to the clips  uttering naughty words as we tried to see how fast you  could spin the crank.
Offline jonpaul
« Reply #11694 on: November 14, 2022, 08:05:46 am »
The Metrohm 7A501C Safety Tester (not really a megger)  have a wide voltage tolerance, see the instructions/specs.
They are intended to test wiring and cables, for resistance between conductors 0-50 Ohms,  and to earth, and insulation resistance 0-50 megs.
The load for voltage test is 1 M Ohm.
it uses  a ratio so exact voltage is not important.
Beware to use fresh batteries, the red rocker switch may need cleaning.
 I acquired two, at Paris Flea markets, EU 5 and EU 13!
Reading  425V and 610V with a 1000V 10 M Ohm Philips DVM.
Despite the voltage variation, both read similar R for  10M or ~ 1M test.
Great units!
Jon
« Last Edit: November 14, 2022, 10:32:47 am by jonpaul »
Jean-Paul  the Internet Dinosaur
Offline jonpaul
« Reply #11695 on: November 14, 2022, 09:15:38 am »
Rebonjour, Gigaset C530 IP  base, 2 handsets, chargers, EU 7 all.
Great IP phone, used but Like new!
Connected to 100 M fibre modem, POTS RJ13x and Ethernet RJ45X, so both landline and VOIP. Controlled by web.
Fine upgrade....found At Vide Grinier (street sale) in  Paris Sunday.
Jon
Offline PlainName
  • Country: va
« Reply #11696 on: November 14, 2022, 09:24:30 am »
Wow! That is a bargain!
Offline Black Phoenix
  • Country: hk
« Reply #11697 on: November 14, 2022, 12:04:29 pm »
Sick of my kid always stealing my tools (that then I have to search around the full house for them) to disassemble his toy cars I took initiative and:
Now he don't need to steal mine...
And before someone says, yes he is 3 years old, already know how to take off screws and put them back and no, he doesn't use then without our supervision. If he wants, he asks and we are with him while doing it at the table, so also no running with tools in the hand.
« Last Edit: November 14, 2022, 01:09:19 pm by Black Phoenix »
Offline McBryce
« Reply #11698 on: November 14, 2022, 12:51:15 pm »
  • Country: hk
« Reply #11699 on: November 14, 2022, 01:02:35 pm »
I preferred this solution.... https://m.media-amazon.com/images/I/61DueEfZwnL._AC_SL1362_.jpg
McBryce.
I tried, he have a Stanley one... It's on the corner catching dust...
