Author Topic: What did you buy today? Post your latest purchase!  (Read 2816737 times)
Calambres and 25 Guests are viewing this topic.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #5825 on: March 13, 2018, 06:43:20 am »
Nice! Do you have the link? Is it based on Austria Microsystems chips (AS5040 and similar)?
Yes I have. Do not read the product description. It's wrong.
Wait, what? So, if there's some external magnetic field, the angle data this thing gives will be wrong?
And how linear is it?
We can make digital compass chips, so why not use those with a magnet hovering directly above?
I don't know about the linearity, I should check this. Any idea how?
« Last Edit: March 13, 2018, 06:46:22 am by Jeroen3 »
Offline Kjelt
« Reply #5826 on: March 13, 2018, 07:07:58 am »
Edit @Kjelt:   thick-black, black.  What same color?  :-//
I never learned that the unit of color was mm2  ^-^
Offline tooki
« Reply #5828 on: March 13, 2018, 09:33:19 am »
I bought a 10 bit Absolute rotary encoder, from china. And it works!
But I had to take it apart to find the pinout of the connector, I can't read chinese colors.
To my surprise, I did not expect it to work with a magnet.
*note: none of the sellers on aliexpress have the correct product description.
Red thick black black green white
Punctuation is your friend.
Offline neo
  • The specialist.
Offline tautech
« Reply #5830 on: March 13, 2018, 09:56:57 am »
Bought myself a Hakko Dual Solder Reel Stand for my birthday (tomorrow).  8)
https://www.ebay.com.au/itm/Hakko-Dual-Solder-Reel-Stand/162082224563?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Have a happy birthday.
Mine was 6 days ago but it should have been today when a heap of new stock arrived.
I joined the 20+ scopes club  :) well just for a few days.........  :(
Offline VK5RC
« Reply #5831 on: March 13, 2018, 10:01:02 am »
Happy Birthday guys  :-+
Offline GreyWoolfe
  • NW0LF
« Reply #5833 on: March 13, 2018, 02:50:46 pm »
Happy Belated Birthday to you, too, Tautech.  Enjoy 'em while you have 'em!
Offline medical-nerd
  • What's that coming over the hill?
« Reply #5834 on: March 13, 2018, 03:57:29 pm »
Hiya
Probably my last on-line shop from Maplin, I just couldn't resist:
rh-21b-silver-plated-plugblock-type-yu79l
maplin-pcb-lacquer
double-ended-solder-pin-10mm-100-pack
305x203mm-fibreglass-single-sided-pcb-board x 3
ad-11-solderless-breadboard
Cheers
'better to burn out than fade away'
Offline Iwanushka
  • Country: lt
« Reply #5835 on: March 13, 2018, 06:35:48 pm »
It would be way cheaper to get 5" floppy drive and scrap it for stepper motor and a schmitt trigger and you have the best encoder (expept optical ones but they cost an arm). Main problem is finding 5" floppy drives....
When all you've got is a hammer, everything starts looking like a nail.- Attrition.
Offline bitseeker
« Reply #5836 on: March 13, 2018, 06:46:57 pm »
Happy birthday, djos and tautech.
Tautech, you should take a pic with those 20+ scopes to keep for posterity. ;D
The following users thanked this post: djos
Offline tautech
« Reply #5837 on: March 13, 2018, 07:32:26 pm »
Thanks bitseeker but they're going out the door that fast it's doing my head in.  :scared:
Somewhere in this thread there's a pic I posted of a dozen or so destined for a classroom set.
Next order that'll be bigger still might be worth taking a snap of, but they're pretty boring all in boxes.  ::)
All sounds like great fun but the gloss wears off when you need to unbox every one, ensure it boots, check and maybe update FW version, then Self Cal and check probes, compensate, assign to channel (fit color rings) and check 10x, 1x switch.
Yep all this latest lot need all that ^  each !!
More than four at a time is just tooooooo hard !
Gotta shoot off soon to deliver some and collect a demo unit.........
Offline Inverted18650
    • Test Gear Addicts
« Reply #5838 on: March 13, 2018, 08:14:34 pm »
Arrived today. So far everything seems perfectly fine. Fingers (tightly) crossed, more to come. :-/O :bullshit:
Offline bitseeker
« Reply #5839 on: March 13, 2018, 08:23:03 pm »
Kudos on the dedication to deliver a good out-of-the-box experience. :-+
Offline bitseeker
« Reply #5840 on: March 13, 2018, 08:26:56 pm »
Yep, they look good, including the batteries. Nice catch.
One of my pending projects is to make a replacement quick-connect card since my 228 didn't come with one. I've located just about everything I need except the cable retainer clamp that they use.
Alternatively, I was thinking about potentially extended the PCB a bit and put either a Phoenix connector or banana jacks, instead of the screw terminals.
Offline Kjelt
« Reply #5841 on: March 13, 2018, 08:35:29 pm »
Ah the dark brown colorsettings of the frontpanels from end 70s begin 80s, just as with homes in our country. :-+
Offline djos
« Reply #5842 on: March 13, 2018, 10:20:15 pm »
Have you seen what a 5.25" FDD goes for these days? They start @ ~$50 + shipping.
Offline bitseeker
« Reply #5843 on: March 13, 2018, 10:21:48 pm »
Hmm, does that mean my closet will become a good retirement fund? Nice.
Offline djos
« Reply #5844 on: March 13, 2018, 10:37:03 pm »
Sounds Like it  ;D
The 360kb drives in-particular are getting very expensive as the 1.2MB HD drives dont work too well with DD media (basically renders DSDD disks useless when put back in DD drives).
Offline bitseeker
« Reply #5845 on: March 13, 2018, 11:30:17 pm »
Yeah, HD drives are fine for reading DD disks and writing to DD disks to be read by HD drives, but not for writing to DD disks that are to be read by DD drives. Something I haven't tried is bulk erasing the disks and then writing them with an HD drive.
    • Test Gear Addicts
« Reply #5846 on: March 14, 2018, 02:45:27 am »
One of my units is missing the PCB insert as well. I swapped it over when I did the power up test to see if the output was functional. I am going to lay one out in EasyEda tomorrow and get them ordered ASAP. Because of their size, I will get 10 of them made in a single lot, so your more than welcome to one/two. I will make the project "public" as well so you can check my work and/or directly order replacements...I will let you know as soon as I get it done, if your interested.
Offline TerraHertz
    • It's not really a Blog
« Reply #5847 on: March 14, 2018, 03:32:17 am »
https://nl.aliexpress.com/item/Free-Shipping-10-bit-absolute-encoder-M6A2-38F10B-5C-2-5M
Linearity: Hmm. It's serial data out, so you can't just look at signal edge timing like: Put a flywheel on the shaft, drive from small motor via loose belt. Check signal timing.
Maybe: attach a long arm to the shaft, set it up with a large sheet of paper marked with the radial divisions. Or just a big protractor. Display the updating angle output, move the arm on the paper/protractor to see if the digital angle matches the actual angle, and where the resolution boundaries are.
You'd hope it wouldn't change with orientation of the unit relative to Earth's weak magnetic field.
The same setup to check for sensitivity to stronger external field. See whether the value boundaries (or even the direct value) change when you wave a magnet around near the unit.
Edit: Wow, you really have to be careful with the part number.
https://www.aliexpress.com/item/Free-Shipping-1pcs-10-bit-absolute-encoder-M6A2-38F10B-5C-2-5M/32221507202.html
That's an    M6A2-38F10B-5C-2.5M  Which is actually an optical 2-wire quad-phase unit.
Yours is an M6A2-38F10B-5C-3M   magnetic sensor and serial data out.
« Last Edit: March 14, 2018, 03:51:00 am by TerraHertz »
Offline bitseeker
« Reply #5848 on: March 14, 2018, 04:17:17 am »
Sounds great. Looking forward to it. I've been meaning to check out EasyEDA.
Offline MosherIV
« Reply #5849 on: March 14, 2018, 08:24:15 pm »
Just been to check out what is going at Maplins  :( they are going out of busines.
Just got these
An instrument case (bargin at £6)
Solar panel for keeping car battery charged (£10)
Plasma ball, always wanted one (£20)  :)
« Last Edit: March 14, 2018, 08:27:07 pm by MosherIV »
