Author Topic: What did you buy today? Post your latest purchase!  (Read 2816446 times)
w.v.s., wkb and 24 Guests are viewing this topic.
Offline kripton2035
« Reply #10625 on: August 20, 2021, 03:20:25 pm »
where did you get this ?
Offline armandine2
« Reply #10626 on: August 20, 2021, 03:27:34 pm »
if that was to me
It is bought from the maker's - Remarkable - website. It was sent promptly, no issues.
Funny, the things you have the hardest time parting with are the things you need the least - Bob Dylan
The following users thanked this post: kripton2035
Offline McBryce
« Reply #10627 on: August 20, 2021, 06:54:22 pm »
possibly due to w2aew's Mrs - I now have another way to write and draw
What is the device? I use a Sony DPT-S1 to write and draw (mainly for work though).
McBryce.
Offline armandine2
« Reply #10628 on: August 20, 2021, 07:55:58 pm »
It is called a ReMarkable 2
there are different makes - similar prices - different specs
Offline kripton2035
« Reply #10629 on: August 20, 2021, 08:14:03 pm »
I already noticed this remarkable tablet some times ago but it was not available. seems a tool to have.
now I will !
Online Nominal Animal
« Reply #10630 on: August 20, 2021, 08:38:00 pm »
If I could get full root on it, or replace the OS with one of my own, I'd be excited to get one.
Alas, it looks like they operate similarly to e.g. Allwinner, and consider copyrights to be something they can ignore but others have to respect...  All they admit is that it runs a purpose-built Linux distribution ("Codex"; never heard of it, neither has Distrowatch).
Surprising, considering it is a Norwegian company (Biermanns gate 6, Oslo, Norway).
Snif, snif.  My nose says the way the device is tied to their Cloud Service, is something the company would rather not have publicly known.  Smells like backdoors and bad security, not like "but the EULA says all your artwork belong to us".
Offline kripton2035
« Reply #10631 on: August 20, 2021, 09:29:31 pm »
you can use it without their cloud service. just have to use an usb cable to transfert to and from the computer.
Offline PlainName
  • Country: va
« Reply #10632 on: August 21, 2021, 02:11:21 am »
As mentioned elsewhere, Boox Note Air runs Android so you can install apps from the Play store. Bootloader is unlocked and if you really want to I believe you can get root.
The following users thanked this post: Nominal Animal
Offline shaohu.tang
  • Country: cn
« Reply #10633 on: August 21, 2021, 02:22:14 am »
HI, everyone,
newbie report, now engaged in instrumentation maintenance。
Offline jonpaul
« Reply #10634 on: August 21, 2021, 09:39:12 am »
Bonjour a tous:
Here is the   Keysight (ex Agilent/HP) 34465A, 6.5 dig  meter current catalog.
https://www.keysight.com/us/en/products/digital-multimeters-dmm/truevolt-series-multimeters.html
One year old,  slight cabinet dings, no IEE 488 but otherwise in CAL and super condition.
Still  discovering all its capabilities ....Web IP addr interface, data logging and screen capture.
Need to upgrade my CAL standards and Verfs....
Your thoughts?
Bon weekend
Jon
Jean-Paul  the Internet Dinosaur
Offline jonpaul
« Reply #10635 on: August 21, 2021, 11:42:22 am »
Rebonjour, a few more notes....
1/ LCD display is bright and clear but has a vibration intermittent, goes totally dark sometimes even though unit continues to run and can be controlled by Ethernet.
Perhaps a bad display or front panel PCB?
Just  returned to Keysight for warranty service.
2/Unexpected features: Freq counter, capacitance, Data capture.
3/ Options  activated in latest FW, 2M memory instead of stock 50K.
4/   IEE488 capability with added interface.
5/ Total control and data/screen capture over Ethernet.
6/   7.5 digits c display with slow acq and smoothing, but Vref would need upgrade for accuracy
7/ Checked  all my  lab standards
R (10 Ohm..100 MEG JRL, GR, etc)
Capacitance (GenRad 0.1/0.2/0.4 and 1000 pF)
DV V (, LM399AH, Yokogawa calibrator, HP 6115A)
AC Volts (TEK PG506)
every test is beyond the accuracy of my lab standards or equipment.
Any others here have Keysight TruVolt series 34460/61/65/70A?
Bon Weekend,
Jon
Offline DrG
« Reply #10636 on: August 22, 2021, 04:27:06 pm »
Someone posted a socket tester and I bookmarked it somewhere because they really liked it and, from what I remember, convincingly explained why. Naturally, I couldn't find that but did some due-diligence and this seems to be ok. Tested it out and the non-contact probe seems to work ok. The GCFI latency test seems to work as well. We will see.
- Invest in science - it pays big dividends. -
Online MarkL
« Reply #10637 on: August 23, 2021, 03:07:51 pm »
Klein has recalled about 1.6M non-contact voltage testers which look like your model:
  https://www.cpsc.gov/Recalls/2021/non-contact-voltage-testers-recalled-by-klein-tools-due-to-shock-hazard
FYI.
Offline DrG
« Reply #10638 on: August 23, 2021, 03:51:15 pm »
FYI.
Thanks much!
I checked out that link. Mine is an NCVT-3P and not the NCVT-1. There are actually other visual differences (you can see if you had in in hand rather than just the product package that I posted - also, mine has a 0121 date code. - again, thanks.
« Last Edit: August 23, 2021, 03:53:04 pm by DrG »
Online deadlylover
« Reply #10639 on: August 26, 2021, 04:28:40 pm »
Carbon steel pans came in today from Darto. Free shipping promotion for another few days, saving USD15. Of course the promotion came days after I placed my order...
I'm pleased that they work quite well on my induction hob. It's great to finally have some "beater" pans.
I finally got around to installing my high CRI LED strips, pic attached of a comparison I did for the torch enthusiasts out there. Lighting so good your heart skips a beat.  ^-^
Offline exor
« Reply #10640 on: August 28, 2021, 09:14:38 am »
NOS Belzer 2615K pliers. Or should I call these benders? Quite handy and one can have radius desired.
Offline PlainName
  • Country: va
« Reply #10641 on: August 28, 2021, 11:02:20 am »
Neat! Where did you get them?
Offline exor
« Reply #10642 on: August 28, 2021, 01:24:54 pm »
Yes, I like these! :D From evilBay. If you do search belzer 2615k there on sold items you can find the seller and ask if he has more available. He has Belzer tools for sale quite often.
Offline PlainName
  • Country: va
« Reply #10643 on: August 28, 2021, 02:24:37 pm »
Thanks. Neither ebay nor google turned up anything. I can feel a lengthy browse of Aliexpress coming on...
Ah!
'bending pliers'
« Last Edit: August 28, 2021, 02:28:41 pm by dunkemhigh »
Offline exor
« Reply #10644 on: August 28, 2021, 05:00:56 pm »
Ah!
'bending pliers'
You can find similar ones from jewelers tool shops:
https://diloytools.com/en/pliers/al826
Offline PlainName
  • Country: va
« Reply #10645 on: August 28, 2021, 06:43:57 pm »
Offline kripton2035
Offline PlainName
  • Country: va
« Reply #10647 on: August 28, 2021, 07:32:55 pm »
Gosh, that's cheap! But 2 month delivery. I went for the Ebay one which is a couple of days :)
Just noticed that's a bit different too - the external side is flat. It was the combination of internal and external curves that caught my eye originally.
Offline kripton2035
« Reply #10648 on: August 29, 2021, 07:41:09 am »
it says 2 months delivery, but (for me at least in France) if you choose aliexpress standard shipping (or combined shipping) it takes less than 15 days to come.
Offline figurativelythedevil
« Reply #10649 on: September 01, 2021, 02:04:01 pm »
Just picked up a whole bunch of tips for my ADS200/TD-200 I'd been meaning to grab, and some random bits and bobs for my lab from Amazon! I'd say one day I'll be finished with the lab, but I don't think that will ever be the case!
