Author Topic: What did you buy today? Post your latest purchase!  (Read 2816375 times)
BFX and 24 Guests are viewing this topic.
Offline Bud
« Reply #10900 on: January 14, 2022, 05:19:02 pm »
That is where a thermal camera would shine. Power the bus with a current limiting power supply like 1V 200-500mA (start with less) and look at the board. The dead part will heat up and you will see it.
Offline McBryce
« Reply #10901 on: January 14, 2022, 07:44:40 pm »
That's what I call "Lazy diagnosis" and is also what I regularly do! :) But most of my repairs are 80's digital (TTL) devices with endless rows of 74 series IC's. A Thermal camera is your best friend in those situations.
McBryce.
Offline pizzigri
« Reply #10902 on: January 15, 2022, 10:57:58 am »
A Rigol DG811 that has been promptly hacked to DG922 status. Thanks to TV84.
The following users thanked this post: Mortymore, duckduck
Offline m k
« Reply #10903 on: January 15, 2022, 01:04:40 pm »
Latest arrival.
STK-0050 clone, not tested yet.
(050DBF5G)
Advance-Aneng-Appa-AVO-Beckman-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Triplett-YFE
Offline jonpaul
« Reply #10904 on: January 15, 2022, 02:03:00 pm »
 Bonjour,   a 1940 tube radio size of a small book, with 1V miniature 7 pin tubes and   original  67V battery
RCA RB-10
Used at start  wwii by SOE 170 were shipped out from USA >>SOE<<French RĂ©sistance before the "spy sets" were deployed.
 My Grandfather had a similar Emerson, I recall from 1952
Anyone else have these old tube portable sets?
Jon
Jean-Paul  the Internet Dinosaur
Offline jonpaul
« Reply #10905 on: January 15, 2022, 02:14:19 pm »
Bonjour
Worked  telephone interconnectand patents.
Just recieved these 1970s Bell System Linemans set and tone tool like banana tracer.
Linemen's set has talk/monitor and original cloth leads and clips.
  tracers  use 9V battery like an AA cell.
All others use 9V transistor battery.
Tone generators (square and rectangular yellow) generate a talk battery and have an early LED or alternating distinctive tones high low.
Anyone else interested in vintage telephone tools or gear?
Jon
Offline rpiloverbd
  • Country: bd
« Reply #10906 on: January 15, 2022, 03:27:13 pm »
My latest purchase of electronics components was some sensors. Metal-touch sensor, Avoidance sensor, Tracking sensor, Shock sensor, Tap sensor, Joystick etc.
Offline wkb
« Reply #10907 on: January 15, 2022, 08:48:02 pm »
Two HP 59306A HPIB controlled relay boxes. 1973 era design, these were built in 1979. Complete HPIB implemented in TTL, and on fully gold plated PCBs. No cost spared  :-+
One of the boxes will house my homegrown RF power meter, the other one I left alone. Threw some Python scripts at it via the HPIB. Works fine. As a useful side effect from dismantling one: qty 18 HP binding posts  :-+
Offline TerraHertz
    • It's not really a Blog
« Reply #10908 on: January 18, 2022, 03:56:40 pm »
An HP 8770A Arbitrary waveform synthesizer. See HP catalogs
  1986 pg 450  1st mention
  1992 pg 455  OPT H12  digital data output.
  1997         Last brief mention
Relatively cheap ($160) due to dented front panel, broken off power button, and front status "error" light lit.
I'd noticed in seller's pictures the two clock loop-back cables on the rear were absent, and hopefully that would be the reason for the "Fault" light.
Fixing the bent panel and broken button switch both met difficulties. That's another story.
Once done, with the loop cables in place now it powers up without the fault light. So hopefully it's working.
Still need to set up some kind of HPIB control system, to run it. It seems to have had a few versions of software for wave generation, that ran on various platforms. Does anyone know anything about those?
I aim to do a teardown. Especially since there _might_ be a screw and nut still loose somewhere in the machine, that had worked loose from the fan mounting. Missing, no apparent rattles in the case and hopefully they are gone. But it would be nice to be sure.
This machine is another instance of a manual with schematics existing, but when you check it turns out that HP chose to omit schematics for one or more crucial boards. With the manual claiming along the lines 'Board not repairable, return to HP for replacement.'  Translated: "We just don't want to give out circuits for some boards, because secret."
« Last Edit: January 18, 2022, 04:06:08 pm by TerraHertz »
The following users thanked this post: Cubdriver, dl6lr
Offline m k
« Reply #10909 on: January 18, 2022, 04:26:12 pm »
Latest arrival.
4-wire short from China.
Delivery time 1 month, pretty fast.
Though for a reason or another customs is still processing.
My guess is relabeling.
Offline wkb
« Reply #10910 on: January 18, 2022, 04:29:55 pm »
LCR meter. Bought it via eBay JP, free shipping with Fedex, which made it significantly cheaper than buying local. Even if a customs invoice were to follow, which I currently wonder about as there was only a Fedex address slip attached to it.  :-//
Offline McBryce
« Reply #10911 on: January 18, 2022, 06:00:25 pm »
The DER EE DE-5000, great device. You should have ordered some of the attachments at the same time. Well worth having.
McBryce.
Offline Martin72
  • Testfield Technician
« Reply #10912 on: January 18, 2022, 09:03:50 pm »
Agree to it, mine came also from ebay JP with "everything" - and it was much more cheaper as when buying it extra.
My buy of the day:
Hioki Milliohm-Meter, used, handle is missing - but works perfectly  :)
The following users thanked this post: Mortymore, shakalnokturn
Offline wkb
« Reply #10913 on: January 18, 2022, 09:08:04 pm »
McBryce.
Oh, I intentionally bought it "bare", plan the create my own accesories. Because I can, no real good reason otherwise.
Nice design I think, and robust build quality.  Have seen much, much worse.
Offline Ground_Loop
« Reply #10914 on: January 19, 2022, 12:55:41 am »
Grabbed another basket case off Ebay.  Kikusui PLZ 300 seen here after a thorough cleaning, repair and tune up. Now working perfectly.
1384396-0
Other than the two digital voltmeter chips driving the displays it is entirely analog.  No keeper battery, no firmware to rev. and no digital interfacing.  The output signal is analog voltage, the display decimal points are comparator driven, switching frequency and PW is via 555s, and even the power calculation is performed by an analog multiplier chip.
« Last Edit: January 19, 2022, 05:03:15 pm by Ground_Loop »
There's no point getting old if you don't have stories.
The following users thanked this post: thm_w, exor, shakalnokturn, duckduck
Offline SpookyGhost
« Reply #10915 on: January 19, 2022, 02:17:07 am »
I got myself this "KAIWEETS" branded clamp meter for a grand total of $68. It does inrush and seems pretty accurate
Right now I don't think I can justify a Fluke for home use. This seems to do the job
Here I'm measuring inrush on my 4 Ton AC
« Last Edit: January 19, 2022, 02:58:26 am by SpookyGhost »
The following users thanked this post: Ed.Kloonk, duckduck
Offline Ed.Kloonk
  • Cat video aficionado
« Reply #10916 on: January 19, 2022, 02:20:57 am »
Give us a 1 to 10 on the range switch feel.
iratus parum formica
Offline SpookyGhost
« Reply #10917 on: January 19, 2022, 02:57:17 am »
Its not the best, but it works. Maybe a 6/10. My main gripe with it is that there isn't much grip. If you don't have it held secure, turning it can be a challenge. The action itself seems fine though. Greasy hands? Forget it.
For some, that could be a positive as there is no way you are going to bump it on in the bag though
Offline McBryce
« Reply #10918 on: January 19, 2022, 09:07:57 am »
McBryce.
I built myself some other attachments anyway (also because I could). My files here might be of use to you if you have a 3D Printer: https://www.eevblog.com/forum/testgear/de-5000-lcr-tl-21-mod/
McBryce.
Offline david77
« Reply #10919 on: January 19, 2022, 05:07:52 pm »
A nice HP6112A arrived today. I paid too much for it but I don't care. I've lusted after one for along time and they're like hen's teeth here. I'm still checking it out but so far all is well. Even all the electrolytics show perfect capacity & ESR values - nothing to do.
Now I'm back at the hen and egg problem: Who's correct HP or the Fluke? Mind you neither one has warmed up properly yet.
Ah, the joys of light volt nuttery  ;D.
Offline ChristofferB
  • Chemistry phd student!
    • My channel:
« Reply #10920 on: January 19, 2022, 10:10:00 pm »
The decade thumb wheels are a really nice idea! Makes it easy to hit the same setting every time.
I got a whole lot of PTFE stuff: Rod and a spool of wire. Very nice for high voltage/impedance/vacuum stuff!
I also got a strange vacuum assembly, just for the hardware. Turned out a bonus was hiding inside: The smallest mass spectrometer I have ever seen!
« Last Edit: January 19, 2022, 10:11:52 pm by ChristofferB »
--Christoffer //IG:Chromatogiraffery
Check out my scientific instruments diy (GC, HPLC, NMR, etc) Channel: https://www.youtube.com/channel/UCZ8l6SdZuRuoSdze1dIpzAQ
Offline Keith956
    • peardrop design systems
« Reply #10921 on: January 20, 2022, 03:22:35 am »
Scored myself a nice HP 4140B on Ebay, $290 delivered.  The last cal sticker is mid 2016.  Both voltage sources check out accurate against my K 6500 as well as their respective current limit functions.  Offsets on all ranges are in the range of +/- .003.  With a very rudimentary high resistance setup I was able to confirm current measurement functions.  Now I need proper fixtures and cables and will officially have my toe in volt nut waters.
(Attachment Link)
Nice one. Check the RIFA capacitor which you'll find near the power socket at the back - its worth replacing it before it goes phut. I also replaced the fan on mine with a quieter Papst one.
Offline DiTBho
« Reply #10922 on: January 20, 2022, 09:58:40 pm »
Chuwi Larkbook X intel "Jasper Lake" Laptop!
Not too bad, paid 300 UKP, loaded with Linux
The opposite of courage is not cowardice, it is conformity. Even a dead fish can go with the flow
Online gamalot
  • Correct my English
    • Youtube
« Reply #10923 on: January 21, 2022, 06:47:18 am »
A pair of Pomona 5291A-60-0/2 test leads, some RF shields and clips.
Offline deadlylover
« Reply #10924 on: January 25, 2022, 09:20:31 am »
Sometimes I worry that my phone will stay awake the whole night and the battery will drain before the alarm goes off.
Problem solved...? Maybe I should also buy an extra cheaper model as backup too.
