Author Topic: What did you buy today? Post your latest purchase!  (Read 2816236 times)
tszaboo, PlainName, w.v.s. and 16 Guests are viewing this topic.
Offline Martin72
  • Testfield Technician
« Reply #12800 on: January 12, 2024, 11:00:02 pm »
The following users thanked this post: tautech, audiotubes
Offline RAPo
« Reply #12801 on: January 14, 2024, 05:32:35 pm »
An Infiray P2 Pro with macro lens and usb-c female-female adapter (in order to use it on a pc).
Offline DiTBho
« Reply #12802 on: January 14, 2024, 06:22:59 pm »
Funny you should mention Cargo type wheels
Two days before xmas I was walking along a street in the center of Copenhagen, and got impressed by a yellow Cargo bicycle with 3 wheels!
The cargo-box was on the front part, while a belt internal gear engine on the rear wheel, plus a Bosh electric motor.
Tempted to buy, when I asekd for the price, the owner said that he paid something like 5K euro.
The opposite of courage is not cowardice, it is conformity. Even a dead fish can go with the flow
Offline armandine2
« Reply #12803 on: January 14, 2024, 08:57:13 pm »
After a couple of hiccups  :palm: with my SMD version I just bought a handful of these THT ammeter kits.
The SMD version back on track after refreshing my theoretical understanding.  :horse:
Funny, the things you have the hardest time parting with are the things you need the least - Bob Dylan
Online PlainName
  • Country: va
« Reply #12804 on: January 14, 2024, 09:36:39 pm »
He says it ain't worth nine bucks, but I'd like to see him buy the parts, design the PCB and have one made, all for $9. And then ship it somewhere for nothing.
The following users thanked this post: armandine2
Offline mengfei
  • Country: ph
« Reply #12805 on: January 15, 2024, 06:17:38 am »
Skyfire Flashlight that can shine light at the moon hahaha
this is one of those FL that you actually see the beam in narrow mode, it uses those massive 26650 batt's!
Offline Calambres
    • Piso-Tones
« Reply #12806 on: January 15, 2024, 07:32:16 am »
OBD2 thingie:
Offline armandine2
« Reply #12807 on: January 15, 2024, 07:03:39 pm »
yes, for my smd voltmeter/ammeter the 7 segment 10mm LEDs are £2 each - then add the 7107 ic, the voltage reference ICL8069, passives and pcbs  :palm:
https://uk.rs-online.com/web/p/led-displays/7085229
Offline cte
« Reply #12808 on: January 16, 2024, 04:02:49 pm »
Got this Toellner 7706 function generator today. Seems fully functional. Case and PCBs are in nearly mint condition.
1982917-0
Mfg date 1989
« Last Edit: January 16, 2024, 04:11:48 pm by cte »
The following users thanked this post: Alex Eisenhut, Mortymore, Peter_O, RAPo, jasonRF
Online w.v.s.
« Reply #12809 on: January 16, 2024, 06:53:47 pm »
A Keithley 2001M :-DMM
Nice! Did you already check the electrolytic capacitors? It is highly recommended to do so.
Online w.v.s.
« Reply #12810 on: January 16, 2024, 08:48:46 pm »
An approx. 10cm glass ball. I am not targeting a second career as fortune teller, but wanted to have it  ;)
Online beanflying
« Reply #12811 on: January 16, 2024, 11:15:59 pm »
Light source three mirrors and make yourself a mega Kaleidoscope for fun ;)
Offline RAPo
« Reply #12812 on: January 17, 2024, 12:37:56 pm »
I've ordered the Zoyi 703s at their store
« Reply #12813 on: January 17, 2024, 01:52:22 pm »
Do not leave where direct sunlight can hit it, those have a very common use as a helioscope, burning an image onto a piece of paper of the path of the sun across the sky.
The following users thanked this post: w.v.s.
Online w.v.s.
« Reply #12814 on: January 17, 2024, 04:30:29 pm »
Thank you for the hint! I'm aware of that, but safety hints are better mentioned a bit more often than too less.
Offline jasonRF
« Reply #12815 on: January 17, 2024, 09:45:21 pm »
Just picked up a fully functional Tenma 72-4045a power supply.  Sure looks the same as the Tek CPS250 and the BK Precision 1651, but it was less expensive on the used market.  I don't know if the guts are the same, though.  Got for $70 (US) delivered; about half the cost was shipping.
« Last Edit: January 17, 2024, 09:49:49 pm by jasonRF »
Offline pqass
« Reply #12816 on: January 18, 2024, 02:01:23 am »
Giving the old CRO a workout comparing the OCXO in the counter with my new [to me] HP 33120A.
Unfortunately, the function generator doesn't have the external 10Mhz ref. input option.
EDIT:  I've since discovered the calibration menu which allows for frequency trimming.  The counter and FG are now consistent.  So Lissajous is no longer sad.    :D
« Last Edit: January 18, 2024, 08:43:33 pm by pqass »
Offline SiliconWizard
« Reply #12817 on: January 18, 2024, 04:12:12 am »
So is this a sad Lissajous on the scope? ;D
The following users thanked this post: pqass
Offline rdl
« Reply #12818 on: January 18, 2024, 08:30:38 am »
I have never seen a Tenma version of that power supply. I have both Tektronix and BK versions. There are small differences in output specification. I don't know if those are from actual hardware differences, slight changes over the years, or maybe just Tektronix de-rating out of caution. I have never had both taken apart at the same time, but they use such jelly bean parts if there is a hardware difference it's probably the transformer.
The following users thanked this post: jasonRF
Offline Martin72
« Reply #12819 on: January 18, 2024, 11:21:39 pm »
5 pcs of BNC-Caps...
« Reply #12820 on: January 18, 2024, 11:31:13 pm »
Now you can test for scope baseline noise in AC or DC input coupling and ground coupled.  ;D
The following users thanked this post: SeanB, Martin72
Offline Martin72
« Reply #12821 on: January 19, 2024, 01:23:43 pm »
Hehe, guess why I've bought them....
Offline zapta
« Reply #12822 on: January 19, 2024, 05:35:51 pm »
I am using 3D printable covers. Non conductive but colorful. The main reason was that I was using for trigger input to be on the right and often connected CH1 to the trigger input by mistake.
https://www.printables.com/model/188788-bnc-connector-dust-cap
« Reply #12823 on: January 19, 2024, 07:25:08 pm »
You already told me and not sharing your secret.  ;)  :-X
Offline rfclown
« Reply #12824 on: January 20, 2024, 11:40:38 pm »
So I've been stuck at home for 2 weeks recovering from COVID. Ran out of coffee (among other thing). Ordered some green so I'd not be out of fresh coffee if run out again. Hadn't roasted in a while. Roasted each of the three types I ordered into second crack. Tomorrow I'll try them drip just to taste the difference, and espresso, which is how I make my coffee regularly. When I used to roast years ago, I found that I liked the coffee better if I let it settle a few days after roasting; but I need my coffee NOW, so tomorrow I grind some. It isn't roasted as dark as it looks in the picture. When I used to roast for drip, my go-to favorite was Guatemalan Antigua, and I also liked Sumatra and Java. Knob on the popper is a dimmer in series with the heating element to lower the heat. Without it, this popper roasted WAY too fast. I made my selections based partially on low price. Not familiar with any of these, so it's a crap shoot.
The following users thanked this post: Peter_O
