Author Topic: New Rigol 16-bit function generators DG800/900 series  (Read 352626 times)
Offline TurboTom
Re: New Rigol 16-bit function generators DG800/900 series
« Reply #875 on: March 18, 2022, 11:04:14 pm »
The 9xx model may undergo a lengthier calibration procedure -- the 8xx variey isn't calibrated all the way up to 100MHz and apparently also has fewer calibration points in the low frequency region. Nevertheless, the latter perform quite nicely up to ~70MHz and show some 1.5...2dB of level drop up to 100MHz which isn't a show stopper for most hobby applications.
Offline eevin
  • Country: tr
« Reply #876 on: March 24, 2022, 05:47:34 pm »
ARC type trigonometric waveforms are specified in the DG900 manual.
These ARC type waveform icons do not exist in the "Math" menu.
Please, can someone check this out on his hacked to 992?
Offline TurboTom
« Reply #877 on: March 24, 2022, 11:38:13 pm »
@eevin - you are correct. I just downgraded my DG811++ to F/W 02.02 and found way more arbitraries in the built-in folders, among them a whole lot of ARC-Trigonometric functions. Someone at Rigol must have had a big "Oopsie" assembling the latest firmware... I guess we should pester them for a fix -- well, maybe better those who bought a "real" DG9xx  ;D
Edit: Just checked with F/W 02.05: Here's the complete set of arbitraries still available, so only the 02.06.01 version appears to be troubled by this bug...
« Last Edit: March 25, 2022, 06:09:51 pm by TurboTom »
Offline eevin
  • Country: tr
« Reply #878 on: March 25, 2022, 08:30:23 pm »
Thank you TurboTom for info. BTW could you please give a link for fw 02.05?
Edit: I have also downgraded it from fw 02.06.01 to fw 02.04 and "ARC icons" appeared and
espacially push type rotary knob is functioning properly anymore, I think it is more stable according to fw 02.06.01 now.
« Last Edit: March 27, 2022, 10:52:27 am by eevin »
Offline jscm2000
  • Country: cn
« Reply #879 on: March 27, 2022, 12:27:06 pm »
for you
Official website firmware
SardineII(ARM)Update00.02.05.00.00
https://pan.baidu.com/s/1QEBuXdNI1lWbGBG9zqRGeg?pwd=969r
Extraction code: 969r
« Last Edit: March 27, 2022, 12:29:25 pm by jscm2000 »
The following users thanked this post: eevin
Offline gogo10
  • Country: cz
« Reply #880 on: March 27, 2022, 01:41:37 pm »
To: jscm2000
Please, wouldn't it be sent somewhere to download? Thank you.
Offline Swat
  • Country: cz
« Reply #881 on: March 27, 2022, 02:23:42 pm »
Hi, you can download it here - but it's time limited.
out of order
« Last Edit: March 29, 2022, 06:18:40 am by Swat »
Offline gogo10
  • Country: cz
« Reply #882 on: March 27, 2022, 02:54:11 pm »
Thank you.
Offline Swat
  • Country: cz
« Reply #883 on: March 27, 2022, 03:40:53 pm »
Offline eevin
  • Country: tr
« Reply #884 on: March 27, 2022, 07:08:42 pm »
Thanks; "jscm2000" and "swat"   :-+
Offline jscm2000
  • Country: cn
« Reply #885 on: March 28, 2022, 03:21:05 am »
To: jscm2000
Hi! The size of the attachment is too large and cannot be uploaded here. I don't have a better network disk. But I found that the firmware sent by Swat is different, the firmware I sent is from the official website.
Offline eevin
  • Country: tr
« Reply #886 on: March 28, 2022, 10:53:36 am »
Jscm2000 could you refresh the link? Because it is expired.
I have uploaded FW (02.05) given by Swat but observed minor mistakes such as  push sensing fault of rotary knob sometimes.
« Last Edit: March 28, 2022, 11:02:19 am by eevin »
Offline Swat
  • Country: cz
« Reply #887 on: March 28, 2022, 11:12:51 am »
Hi guys,
I downloaded the firmware 02.05 from bulba99, a member of this forum, but I only used it for a partial upgrade and I immediately upgraded to version 02.06. So I didn't test 02.05 in any way. If that file isn't okay, I'm sorry, I didn't know it.
Offline eevin
  • Country: tr
« Reply #888 on: March 28, 2022, 04:13:54 pm »
Swat, it is not a problem, we are examining the device and learning. It is easy to downgrade or upgrade  :popcorn:
Could you check the "Math" menu for ARC trigonometric icons?
Because these icons disappread by the uploading of fw 02.06.01
Also please give a link for fw 02.06.00
« Last Edit: March 28, 2022, 04:16:18 pm by eevin »
Offline Swat
  • Country: cz
« Reply #889 on: March 28, 2022, 05:10:08 pm »
Ok, here is a link to the "my" 02.06 firmware file:
out of order
« Last Edit: March 29, 2022, 06:17:57 am by Swat »
Offline eevin
  • Country: tr
« Reply #890 on: March 28, 2022, 06:38:23 pm »
Thank you Swat. Uploaded and again "icons" disappered in the math menu.
Then, I have noticed that the it is written in the relase notes for fw 02.06.00.01 sent by Swat
Jscm2000 could you refresh the link? Because it is expired. :-//
« Last Edit: March 28, 2022, 06:40:28 pm by eevin »
Offline eevin
  • Country: tr
« Reply #891 on: March 28, 2022, 08:15:47 pm »
How can I activate the advanced properties of Rigol Ultra Station ? Thank you for any help from now
« Last Edit: March 28, 2022, 08:18:57 pm by eevin »
Offline jscm2000
  • Country: cn
« Reply #892 on: March 29, 2022, 03:28:19 am »
hi!
I upgraded from 02.04 to 02.06, and the situation is the same as you. Many arbitrary waves are missing from the menu, and it is normal to refresh back to 02.04.
Official website firmware SardineII(ARM)Update00.02.05.00.00 Download URL:
https://pan.baidu.com/s/1EN5SAPcvxLiBXp7Dpk2nTQ?pwd=r5mf
Extraction code:r5mf
Offline Swat
  • Country: cz
« Reply #893 on: March 29, 2022, 06:45:21 am »
After a few attempts, I downloaded the exe file from jscm2000, but it crashed when I tried to unzip it. When I tried again, only a warning came. Even the simplest Chinese seems to be too complicated for me  |O. Has anyone been successful in this matter? I just need some ordinary rar or zip!
Offline eevin
  • Country: tr
« Reply #894 on: March 29, 2022, 12:35:01 pm »
Me too, not downloaded.
If it is possible, please another link Jscm2000?
Offline jscm2000
  • Country: cn
« Reply #895 on: March 30, 2022, 03:09:35 am »
Please leave your email, I can send to your email
Offline eevin
  • Country: tr
« Reply #896 on: March 30, 2022, 08:48:19 am »
Offline jscm2000
  • Country: cn
« Reply #897 on: March 30, 2022, 11:59:27 am »
Offline SMB784
    • Tequity Surplus
« Reply #898 on: March 30, 2022, 12:05:13 pm »
[email protected]
Sent, please check your email.
Thanks for the firmware file jscm2000!
While we are on the subject, would you be willing to share how you did your special calibration technique?  If you want to share it privately and have it stay private, my email is [email protected]
Offline TurboTom
« Reply #899 on: March 30, 2022, 01:50:40 pm »
@jscm2000: I think many members here would be highly interested in this information... So please, share some knowledge!
