Oh, i see. Water to put out electric fires. That's unexpected, but it's what's been recommended:
Firefighting
USE WATER TO FIGHT A HIGH VOLTAGE BATTERY FIRE. If the battery catches fire, is exposed to high heat, or is generating heat or gases, use large amounts of water to cool the battery. It can take approximately 3,000 gallons of water (applied directly to the battery); establish sufficient water supply.
Extinguish small fires not involving the battery using typical vehicle firefighting procedures.
Always use insulated tools for overhaul.
Heat and flames can compromise some components, resulting in an unexpected explosion. Perform an adequate knock down before entering a hot zone.
There must not be fire, smoke, or heating present in the battery for at least one hour (consider using a thermal imaging camera to measure the temperature) and the battery must be completely cooled before the vehicle can be released to second responders. Always advise second responders that there is a risk of battery re-ignition.
https://www.tesla.com/sites/default/files/downloads/2016_Model_X_Emergency_Response_Sheet_en.pdfI suppose there's no way around it, as the shorted battery pack will continue to conduct and heat until it's fully discharged, so it's preferable to use water. If completely flooded, it would be like throwing every individual cell in water, right?
On the other hand, gasoline is clearly not safer, as the vapours are what catch fire. Any ignition source will ignite the whole cloud of vapours, and create a big fireball, depending on conditions like the amount of wind.
I once used kerosene to set some branches on fire, and i just poured like 300 ml of it, at most, and after less than a minute i thown a match from a distance. Just let me say that it was a good idea to leave some distance... I searched on flammability of this thing, and it seems to be very near that of gasoil. And better not try this on gasoline, as it's a lot more flammable. The "flash point" seems to be what determines this. The lower, the more flammable:
Diesel (2-D) 52 °C
Kerosene 38 to 72 °C
Gasoline
−43 °C !!!
