Author Topic: Hantek - Tekway - DSO hack - get 200MHz bw for free  (Read 2217424 times)
0 Members and 13 Guests are viewing this topic.
Offline lemon
  • Country: gr
Re: Hantek - Tekway - DSO hack - get 200MHz bw for free
« Reply #2100 on: November 09, 2013, 12:51:02 pm »
Please, can someone to feedback us about this test?
Set a waveform to screen (triangle, sinusoidal).
Move the waveform to up or down so to cut the edge of the screen.
Now invert the waveform.
What is appearing? Is it normal or the bottom of waveform is also cutting?
Here is a short video about this. https://www.dropbox.com/s/gzstblo60y50d7z/2013-11-07%2000.02.43.mp4
Offline primsam
« Reply #2101 on: November 09, 2013, 02:12:36 pm »
@lemon
i think this is the wrong section  for your problem, in the video is a owon brand device that has nothing to do with hantek/teckway/voltraft and so on ...
Offline n8ddd
« Reply #2102 on: November 09, 2013, 02:54:24 pm »
updating...here's attached log console.the mtd size of "rootfs"is 121Mb,then why the nunddump is dumping 124Mb? :-[
without -b option is dumping forever
« Last Edit: November 09, 2013, 04:22:11 pm by n8ddd »
Offline tinheadTopic starter
    • If you like my hacks, send me a donation
« Reply #2103 on: November 09, 2013, 04:10:19 pm »
this is because you dumped the data with OOB blocks (which is necessary for restore over JTAG or the method i've published)
Eaach every (and that depends n flash size and structure) about of byte there is OOB block data, so the 121Mb together with OOB block will larger, in your case 124Mb.
I don't want to be human! I want to see gamma rays, I want to hear X-rays, and I want to smell dark matter ...
I want to reach out with something other than these prehensile paws and feel the solar wind of a supernova flowing over me.
Offline vmpn
« Reply #2104 on: November 09, 2013, 04:33:39 pm »
I also see some errors about linuxrc not starting. I need to double check config for my busybox build. Meanwhile please do not replace the one on the DSO.  You can put it in another folder and run it as:
{Path}/busybox nanddump ....
« Last Edit: November 09, 2013, 04:37:44 pm by vmpn »
« Reply #2105 on: November 09, 2013, 04:57:19 pm »
there are not such issues on Tekway/Hantek, nor these others nown from Owon (with inverted and moved to top signal).
This must be firmware bug in Owon firmware, you should tell that Owon (or rf-loop, he is collecting bugs as well).
Offline n8ddd
« Reply #2106 on: November 09, 2013, 07:06:05 pm »
i've noticed that with busybox from vmpn the dump files are like this
boot.bin-1.03mb
logo.bin-2.06mb
kernel.bin-4.12mb
root.bin-124mb
and the dumped files with original busybox
boot.bin-1mb
logo.bin-2mb
kernel.bin-4mb
root.bin-dumping forever
Offline vmpn
« Reply #2107 on: November 09, 2013, 07:12:47 pm »
boot.bin-1.03mb
logo.bin-2.06mb
kernel.bin-4.12mb
root.bin-124mb
boot.bin-1mb
logo.bin-2mb
kernel.bin-4mb
Are you using -o command line parameter? In the newest busy box this flag flipped meaning. In the old version -o means exclude oob blocks. In the new version (that I built) -o means include the oob blocks.
« Last Edit: November 09, 2013, 07:44:34 pm by vmpn »
Offline JeffD
« Reply #2108 on: November 09, 2013, 07:20:46 pm »
I was wondering what the current hardware revision is for a Hantek DSO5102BM model?  Is it 10070x555583e9?  Couldn't find the info on the Hantek site and still waiting for a their response to my email.
Still reading through this thread.  Huge amount of great info here.
Offline n8ddd
« Reply #2109 on: November 09, 2013, 07:52:16 pm »
yes,i'm using -o
Offline vmpn
« Reply #2110 on: November 09, 2013, 09:23:40 pm »
yes,i'm using -o
Please create dumps without using "-o" and they should come out same size as original ones
« Reply #2111 on: November 09, 2013, 09:45:09 pm »
JeffD,
the best is to skip the first 130-140 pages :) Really. Lots of the informations are already lightyears outdated. On the first page, there are shortcuts to important topics, as well the last pages contains siome newer infomations as well.
there are no any models left with old SoC, so current BM/BMV will be for sure not hw1007 but hw101 which is alreay S3C2416 SoC based. Between B and BM/BMV models, it is only bigger SRAM and different design in CPLD (address counter with higher range. BM\BMV design does works however with B\MSO models with no issue - i'm using MSO with 2M SRAM, so can during boot chose between MSO and BMV DSO), and between B and MSO models it is only the additional PCB mounted to i/o port on the B model mainbaord (and some few passive parts necessary to enable int , etc on the extra PCB).
Only P models does use different PCB design, so they can't be upgrated to higher memory nor MSO functionality (however it seems they does have kind of i/o header, which could allow other extensions, but up to now nothign really prooved).
Offline JeffD
« Reply #2112 on: November 10, 2013, 12:34:13 am »
Thanks for the info tinhead.  That is what I figured once I got up to page 120 trying to figure out what was current hardware revision for different models.
Offline at2
« Reply #2113 on: November 10, 2013, 05:15:25 am »
Is it possible to use  the DSO-BW-Changer for the DSO 5102P to change the bandwith to 200 MHz?
« Reply #2114 on: November 10, 2013, 09:16:14 am »
yes it should be
Offline lemon
  • Country: gr
« Reply #2115 on: November 10, 2013, 12:16:58 pm »
@lemon
That is exactly answering, that I wanted.
The purpose of my question was to examine the phenomenon in another DSO oscilloscope so as to exclude the possibility to be issue of DSO scopes.
Tinhead, thanks for the respond.
Offline at2
« Reply #2116 on: November 11, 2013, 08:31:58 am »
Thank you tinhead for your fast reply. I`m going to try out and let you know.
AT2
Offline at2
« Reply #2117 on: November 14, 2013, 08:00:53 am »
 :clap: It works great. Thank you for your Support.
AT2
Offline miljume
« Reply #2118 on: November 14, 2013, 06:18:30 pm »
Hi all,
I ordered a DSO1062B just to upgrade it to 200Mhz but I get stuck at the first step when trying to do a backup
I get "firmware update failed, error: 0xfe no upgrade files detected on USB device!"  :-\
I have the following setup
[model] DSO1062B
[sw version] 2.01.1 (130129.0)
[hw version] 10020x555583e8
[serial number] DS00503381
Can someone please help me getting through?
Regards,
Mikael
Offline kafachan
« Reply #2119 on: November 16, 2013, 05:28:36 am »
Hi all,
     Thank you  .  ^-^
Regards,
Kafa.
« Last Edit: November 30, 2013, 03:20:57 am by kafachan »
Offline at2
« Reply #2120 on: November 16, 2013, 09:20:33 am »
Hello Kafachan,
i can only tell with my DSO, as i did the change and it works fine .
See on YouTube. There did Cooking Engineer the change with his voltcraft from 60 to 200 MHz.
AT2
Offline miljume
« Reply #2121 on: November 27, 2013, 06:53:57 pm »
Hi all,
I am still stuck with unlocking 200Mhz for my DSO1062B, is there a way to unlock a unit with the data below?
[model] DSO1062B
Thankful or all help I can get
Regards,
Mikael
« Reply #2122 on: November 27, 2013, 10:02:21 pm »
where you stuck? still in backup? well, then skip backup. Or stuck in the hack tool? then do it manually. Everything one need to know is on the first page of this thread.
Offline mobiletester
« Reply #2123 on: November 29, 2013, 07:13:01 pm »
I have a Hantek DSO5072P. SW 3.40.0 (130717.0)
Works the BW-Changer also on this model?
Offline artag
« Reply #2124 on: November 29, 2013, 11:34:00 pm »
This thread is way too long ! Is anybody running a forum with the topics a bit more searchable ?!
I'm looking at buying one of the hantek scopes but having trouble working out the tradeoffs. I don't think there's any saving in buying the DSO1062, and I'm not convinced 1GS/s is enough for 200Mhz mode, so I'll probably stick with 100MHz bandwidth. I've got faster analog scopes anyway.
But there's the choice of B, BM, P and MSO5120D.   :-\
B is a bit cheaper
BM has 2M memory (but does that make it really slow update ?)
MSO is useful but only 1M memory.
P is really cheap but only 40K memory (or maybe 24k?)
Of course, I'd really like the best of everything ! It seems the MSO option isn't that great and can be added fairly easily. So maybe the 2M is the best choice ?
Are there any options now with ethernet already fitted ? There seem to be some add-in boards, or I can put a wifi adapter in the USB.
