Author Topic: FPGA VGA Controller for 8-bit computer  (Read 1139756 times)
0 Members and 87 Guests are viewing this topic.
Offline BrianHG
    • LinkedIn
« Reply #550 on: December 03, 2019, 06:07:35 pm »
In 2 bit color color 2byte mode, the bg_color is swapped with the ram_byte_h.
That's the only mistake you have there.
In 8bit color mode, 2byte mode, you just pass the ram_byte_h to the output pixel_out_h.
When wired to the memory, the ram_byte_h is nothing more than a separate read port's data output.
You should be able to wire this thing into the current OSD mem output, except, only the first color mode would give you pixels if the bg_color has an appropriate value.
« Reply #551 on: December 03, 2019, 06:35:44 pm »
Oh right - I'm not used to there not being loads of things wrong with what I've written! I thought there must be something more... :-DD
Updated code below.  I'm just trying to work out how to connect the bitplane_to_raster module up in the design schematic..  ???
I'm either going to have to make design symbols for gpu_dual_port_ram_INTEL and/or multiport_gpu_ram, or do what we did in vid_osd_generator and instantiate those modules in the bitplane_to_raster code?
module bitplane_to_raster (
// inputs
input wire clk,
input wire [3:0] pc_ena,
input wire [7:0] ram_byte_in,
input wire [7:0] ram_byte_h,
input wire [7:0] bg_color,
input wire [9:0] x_in,
input wire [1:0] colour_mode_in,
input wire two_byte_mode,
// outputs
output reg pixel_out_ena,
output reg mode_16bit, // high when in 16-bit mode
output reg [7:0] pixel_out,
output reg [7:0] pixel_out_h,
output reg [9:0] x_out,
output reg [1:0] colour_mode_out
// parameters
parameter PIPE_DELAY = 3; // minimum value of 2
// internal registers
reg [7:0] colour_data;
reg [7:0] ram_byte;
// *  DELAY PIPES                                                              *
reg [9:0] dly_x [9:0];
reg [9:0] dly_ram_byte [7:0];
reg [9:0] dly_ram_h_byte [7:0];
reg [9:0] dly_colour_mode [1:0];
reg [9:0] dly_mode_bit [1:0];
always @ ( posedge clk ) begin
if (pc_ena[3:0] == 0) begin
dly_x[0] <= x_in;
dly_x[9:1] <= dly_x[8:0];
x_out <= dly_x[PIPE_DELAY-1];
dly_mode_bit[0] <= two_byte_mode;
dly_mode_bit[9:1] <= dly_mode_bit[8:0];
mode_16bit <= dly_mode_bit[PIPE_DELAY-1];
dly_ram_byte[0] <= ram_byte_in;
dly_ram_byte[9:1] <= dly_ram_byte[8:0];
ram_byte <= dly_ram_byte[PIPE_DELAY-1];
colour_data <= dly_ram_byte[PIPE_DELAY-2]; // in two-byte mode, colour_data should follow the ram_data byte
dly_ram_h_byte[0] <= ram_byte_h;
dly_ram_h_byte[9:1] <= dly_ram_h_byte[8:0];
pixel_out_h <= dly_ram_h_byte[PIPE_DELAY-1];
dly_colour_mode[0] <= colour_mode_in;
dly_colour_mode[9:1] <= dly_colour_mode[8:0];
colour_mode_out <= dly_colour_mode[PIPE_DELAY-1];
end // pc_ena
end // always@clk
// *  RASTER GENERATION                                                        *
// color_mode_in determines the operating mode for the bitplane_to_raster module
// it is a 2-bit signal, providing 4 modes of operation to this module e.g.:
// 00 =   2 colour mode - 8 pixels per byte in GPU RAM
// 01 =   4 colour mode - 4 pixels -----"------"------
// 10 =  16 colour mode - 2 pixels -----"------"------
// 11 = 256 colour mode - 1 pixels -----"------"------
always @ (posedge clk) begin
if (~two_byte_mode) begin // 8-bit mode
case (colour_mode_in)
2'h0 : begin // 1-bit (2 colour) - 8 pixels per byte
// set the output pixel color to the first 4 bits of the background color
// when the bit on the picture bitplane byte is 0 and use the upper 4 bits
// when the bit on the bit-plane byte is high
mode_16bit <= 1'b0; // update mode_16bit output to 8-bit mode
if (ram_byte[(~x_out[2:0])] == 1'b1) begin
pixel_out[7:5] <= 3'b000;
pixel_out[4] <= 1'b1;
pixel_out[3:0] <= bg_color[7:4];
end
else begin
pixel_out[4] <= 1'b0;
pixel_out[3:0] <= bg_color[3:0];
end
end
2'h1 : begin // 2-bit (4 colour) - 4 pixels per byte
// output will be 2 bits stacked, 2 copies every second X pixel, you will
// output a 2 bit color. EG pixel 0&1 output bitplane[7:6],  pixel 2&3
// output bitplane[5:4], pixel 4&5 output bitplane[3:2]
pixel_out[7:2] <= 6'b000000;
case (x_out[2:1])
2'h0 : begin
pixel_out[1:0] <= ram_byte[7:6];
end
2'h1 : begin
pixel_out[1:0] <= ram_byte[5:4];
end
2'h2 : begin
pixel_out[1:0] <= ram_byte[3:2];
end
2'h3 : begin
pixel_out[1:0] <= ram_byte[1:0];
end
endcase
end
2'h2 : begin // 4-bit (16 colour) - 2 pixels per byte
// output will be 4 bits stacked, 4 copies every four X pixel, you will
// output a 4 bit color.  EG pixel 0,1,2,3 output bitplane[7:4], EG pixel
// 4,5,6,7 output bitplane[3:0]
pixel_out[7:4] <= 4'b0000;
if (x_out[3])
pixel_out[3:0] <= ram_byte[3:0];
else
pixel_out[3:0] <= ram_byte[7:4];
end
2'h3 : begin // 8-bit (256 colour) - 1 pixel per byte
// output will be 8 bits stacked, 8 copies every eight X pixel, you will
// output a 4 bit color.  EG pixel 0,1,2,3,4,5,6,7 output bitplane[7:0],
// yes that same 1 value will repeat 8 times is the source X counter
// counts through those numbers sequentially
mode_16bit <= 1'b0; // update the mode output to show whether it's 8 or 16-bit mode
pixel_out <= ram_byte;
end
endcase
end // 8-bit mode
else begin // 16-bit mode
case (colour_mode_in[0])
1'h0 : begin // special colour text mode
// 2-bit colour 2-byte mode
// latch ram_byte as the bit plane graphic and colour_data
// as a replacement for the background default color. The
// rest should follow #1.
if (ram_byte[(x_out[2:0])] == 1'b1) begin
pixel_out[3:0] <= ram_byte_h[7:4];
end
else begin
pixel_out[3:0] <= ram_byte_h[3:0];
end
end
1'h1 : begin // 16-bit (true colour)
// taking 2 sequential bytes, like the color text mode, and outputting
// a full 16 bits parallel on the output
mode_16bit <= 1'b1; // update mode_16bit output to 16-bit mode
pixel_out_h <= ram_byte_h;
end
endcase
end // 16-bit mode
end // if (pc_ena[3:0] == 0)
end // always@clk
endmodule
« Last Edit: December 03, 2019, 06:40:23 pm by nockieboy »
Offline BrianHG
    • LinkedIn
« Reply #552 on: December 03, 2019, 08:03:31 pm »
// inputs
input wire clk,
// outputs
// parameters
reg [7:0] ram_byte;
// *  DELAY PIPES                                                              *
dly_x[0] <= x_in;
end // pc_ena
end // always@clk
end
else begin
end
end
case (x_out[2:1])
2'h0 : begin
end
2'h1 : begin
end
2'h2 : begin
end
2'h3 : begin
end
endcase
end
if (x_out[3])
else
end
end
endcase
end // 8-bit mode
end
else begin
end
end
end
endcase
end // 16-bit mode
end // always@clk
endmodule
No more symbols, everything get wired as test inside the 'osd_generator'.
You may only make symbols a separate simulator project in QIIv9.1 to see if you module works on its own.
Fix the multiple bugs in this part:
Also, why did you :
and in 16 bit color mode:
Why not use 2'h3.
and change your 'case (colour_mode_in[0])' to the normal 'case (colour_mode_in)'?
Offline BrianHG
    • LinkedIn
« Reply #553 on: December 03, 2019, 08:27:01 pm »
I'll tell you what, you may make the next module, 2 palettes plus a color pixel mixer, as it's own module outside the osd_generator block.
« Reply #554 on: December 03, 2019, 09:13:29 pm »
Yeah they're not bugs as such, the code there is placeholder copied over from the 1-byte code above it (as you'd mentioned that it would follow #1).  I'm still trying to work out exactly what to put in here - your comment here:
The rest should follow #1.
...is throwing me, slightly.
Also, why did you :
Why not use 2'h3.
No idea - I've changed it now.
I think this was because there were only two 'special' modes, so I didn't care about anything other than the LSB of colour_mode_in to select between them?
Had another go at the special colour text mode code...
2'h0 : begin // special colour text mode
end
else begin
pixel_out_h <= bg_colour;
end
end
2'h3 : begin // 16-bit (true colour)
end
endcase
end // 16-bit mode
Offline BrianHG
    • LinkedIn
« Reply #555 on: December 03, 2019, 09:34:28 pm »
Your fine, place it inside the OSD generator in place of the :
//  The resulting 2-bit font image at x is assigned to the OSD[1:0] output
//  Also, since there is an 8th bit in the ascii text memory, I use that as a third OSD output color bit
assign osd_image          = char_line[(~dly6_disp_x[2:0])];
Note that you will need to make the new 'osd_image' output into a pixel_out and pixel_out_h ports.  Call them pixel_out_top, pixel_out_top_h, and the wire 'pixel_out_top_16bit'
These 3 outputs will leave the vid_osd_generator.  For now, set single byte test mode and wire the bg_color to a spare GPU_HW_REGS.
For now, wile the 8 bits into some of the RGBs wires to the stencil, maybe 'OR' in a few rast_HV triggers for testing, like only 2 or 4 of them.
My next message will contain the palette module which goes in between the vid_osd_generator module and the vid_out_stencil module.
Offline BrianHG
    • LinkedIn
« Reply #556 on: December 03, 2019, 10:10:09 pm »
Now for the palette memory.  You will have 2 palettes.
Palette #1, specialized for the ASCII text and sprites.
On the Read only port, IE, pixel_in -to- text_pixel out, you will have:
8 bit address input, ie pixel_in[7:0].
On the data output, you will have a 16bit pixel_out[15:0].
The 16 bit output will be wired as follows:
text_pixel_out[15:12] -will be sent to- alpha_blend[3:0]
text_pixel_out[11:8]   -will be sent to- text_r[7:4] -and- text_r[3:0]
text_pixel_out[7:4]     -will be sent to- text_g[7:4] -and- text_g[3:0]
text_pixel_out[3:0]     -will be sent to- text_b[7:4] -and- text_b[3:0]
On the pixel side you will want the 'CLOCK ENABLE' feature for the address latch coming in and data latch going out.
The clock enables will be connected to the (pc_ena[3:0]==0) wire.
On the 'host' memory side, you will have a 9 bit address [9:0] and 8 bit data in and out.
The write ena will need attention as you will need to position this memory withing the system not to conflict with the main graphics memory.
You will need to generate a .mif default palette, otherwise, everything will be black.
Palette #2, specialized for the 256 color background.
Same as the text memory except the data_input will be wired to a 'graphics_data_in' and there will be a 'graphics_data_out' which will be wired like this:
graphics_pixel_out[15:11] -will be sent to- graphics_r[7:3] -and the upper bits to - graphics_r[2:0]
graphics_pixel_out[10:5]   -will be sent to- graphics_g[7:2] -and the upper bits to - graphics_g[1:0]
graphics_pixel_out[4:0]     -will be sent to- graphics_b[7:3] -and the upper bits to - graphics_b[2:0]
Don't forget to page the graphics color palette on a different page on the hose writing side.
For now, just wire the output of the
text_r[3:0] to the modules output  pixel_out_r[7:4] and pixel_out_r[3:0]
text_g[3:0] to the modules output  pixel_out_g[7:4] and pixel_out_g[3:0]
text_b[3:0] to the modules output  pixel_out_b[7:4] and pixel_out_b[3:0]
Yes, 24 bit color output, you will only pass the top 12 used bits to the pins after the stencil module.
Address generator Beta V 1 comes next, so get these working!
« Reply #557 on: December 04, 2019, 08:06:34 pm »
Right, back again - work's been keeping me busy - so, when you say 'place it inside the OSD generator', can you be just a little more specific? ???  Are you telling me to cut 'n' paste the code from bitplane_to_raster.v into vid_osd_generator.v in place of the osd_image assignment and work the new I/Os into the existing ones, or instantiate it (if that's even the right terminology?) in the same way that vid_osd_generator creates the multiport_gpu_ram instance?
Sorry about the basic question(s), but remember; a few weeks ago I knew the square root of nothing about FPGAs and Verilog...  :o
« Reply #558 on: December 04, 2019, 08:11:06 pm »
Will these palette memories be easily accessible by the host system?  I guess I'll just change the z80_bridge module to redirect reads/writes above address 16384 to the palette memory (or sprite memory or whatever else we add in)?
Offline BrianHG
    • LinkedIn
« Reply #559 on: December 04, 2019, 08:39:18 pm »
It's just more 2 port memories.  1 port dedicated to process the 8 bit pixel data into 16 bit pixel data.
The other side should be used to interface with the host.
With Cyclone, the smallest block of ram is 9kbit, or 8kbit, if 1KB. So, to save every tiny drop, even if you allocate a 256x16 bit block of ram, ie 512bytes, it would still count as a 1024bytes.
Now, I said 16 bits on the read output.  If you want to save every drop imaginable, and combine 2 palettes into 1 1024 byte ram block, you may use another of our 5 port ram and just wire the read addresses correctly to get 2x 16bit parallel port reads, ie 4 read ports in use and you still have the host port.
The saving is you get the 2 palettes in a single MK9 block inside the cyclone IV.  The easier way with separate ram blocks is each palette occupies 1x MK9 block.  You may double each the palette size in this configuration and use no additional memory.  The separate memory blocks eat less logic cells and runs a bit faster.  How you decide to mar the write address, either in parallel with a block from the existing 16kb, or somewhere outside as it is ram as well is your decision.
Offline BrianHG
    • LinkedIn
« Reply #560 on: December 04, 2019, 08:43:10 pm »
The 'memory_to_raster.v' module you just created is all on it's own a .v file included in your project.
You are only calling an instance of it inside the vid_osd_generator.  This is important as you will be calling at least 2 of them, and even more when we add sprites.  It may be possible to have 1 instance per sprite depending on architecture, so, you will have something like 10 of them inside the vid_osd_generator.
You've already called instances of our 5 port memory inside the vid_osg_generator, so, I know you know how to do this.
Offline BrianHG
    • LinkedIn
« Reply #561 on: December 04, 2019, 09:14:34 pm »
I'll leave the implementation to you.  However, remember, you may be adding multiple memories at multiple sizes.  Whatever method you choose, make sure you can easily move things around on a whim for no matter how many modules we may add.
« Reply #562 on: December 05, 2019, 09:38:48 am »
Okay, just need a little more guidance getting the bitplane_to_raster module connected up to the vid_osd_generator module.  Full code for vid_osd_generator at the bottom of this post.
Here's what I've got so far for creating an instance of bitplane_to_raster:
// * create a bitplane_to_raster instance
// * NOTE:  For testing, GPU_HW_Control_regs [10] sets bg_colour
// *                                         [11] sets two_byte_mode
// *                                         [12] sets colour_mode_in
bitplane_to_raster b2r_1(
.clk(clk),
.pc_ena_in(pc_ena[3:0]),
// inputs
.ram_byte_in( [7:0]),
.ram_byte_h( [7:0]),
.bg_colour( GPU_HW_Control_regs[10] ),
.x_in( disp_x ),
.colour_mode_in( [1:0] GPU_HW_Control_regs[12] ),
.two_byte_mode( [0] GPU_HW_Control_regs[11] ),
// outputs
.pixel_out_ena( osd_ena_out ),
.mode_16bit( pixel_out_top_16bit ),
.pixel_out( pixel_out_top ),
.pixel_out_h( pixel_out_top_h ),
.x_out( [9:0]),
.colour_mode_out( [1:0])
Firstly, hopefully the connections I've made so far are all correct?  Secondly, some specific questions:
  • What to do with x_out and colour_mode_out (if anything at this stage)?
  • Should x_out feed back into the dly_x pipeline somewhere?
  • ram_byte_in and ram_byte_h - ram_byte_in I guess is fed from char_line??  I suppose ram_byte_h is left disconnected at the moment?
module vid_osd_generator (
// inputs
input clk,
input [3:0] pc_ena,
input hde_in,
input vde_in,
input hs_in,
input vs_in,
input wire host_clk,
input wire host_wr_ena,
input wire [19:0] host_addr,
input wire [7:0] host_wr_data,
input wire [7:0] GPU_HW_Control_regs[0:(2**HW_REGS_SIZE-1)],
input wire [47:0] HV_triggers_in,
// outputs
output reg osd_ena_out,
//output wire osd_image,
output reg pixel_out_top_16bit,   // <--- new
output reg [7:0] pixel_out_top,   // <--- new
output reg [7:0] pixel_out_top_h, // <--- new
output reg hde_out,
output reg vde_out,
output reg hs_out,
output reg vs_out,
output wire [7:0] host_rd_data,
output reg [47:0] HV_triggers_out
// To write contents into the display and font memories, the wr_addr[15:0] selects the address
// the wr_data[7:0] contains a byte which will be written
// the wren_disp is the write enable for the ascii text ram.  Only the wr_addr[8:0] are used as the character display is 32x16.
// the wren_font is the write enable for the font memory.  Only 2 bits are used of the wr_data[1:0] and wr_addr[12:0] are used.
// tie these ports to GND for now disabling them
reg [9:0] disp_x,dly1_disp_x,dly2_disp_x,dly3_disp_x,dly4_disp_x,dly5_disp_x,dly6_disp_x,dly7_disp_x,dly8_disp_x;
reg [8:0] disp_y,dly1_disp_y,dly2_disp_y,dly3_disp_y,dly4_disp_y;
reg dena,dly1_dena,dly2_dena,dly3_dena,dly4_dena,dly5_dena,dly6_dena;
reg [7:0] dly1_letter, dly2_letter, dly3_letter, dly4_letter;
reg [9:0] hde_pipe, vde_pipe, hs_pipe, vs_pipe;
reg [47:0] HV_pipe[9:0];
parameter   PIPE_DELAY =  6; // This parameter selects the number of pixel clocks to delay the VDE and sync outputs.  Only use 2 through 9.
parameter   FONT_8x16  =  0; // 0 = 8 pixel tall font, 1 = 16 pixel tall font.
parameter HW_REGS_SIZE = 8; // default size for hardware register bus - set by HW_REGS parameter in design view
wire [12:0] font_pos;
wire [10:0] disp_pos;
wire [19:0] read_text_adr;
wire [19:0] read_font_adr;
wire [7:0]  letter;
wire [7:0]  char_line;
// * create a multiport GPU RAM handler instance
multiport_gpu_ram gpu_RAM(
.clk(clk),
.addr_in_0(read_text_adr[19:0]),
.addr_in_1(read_font_adr[19:0]),
.addr_in_2(20'b0),
.addr_in_3(20'b0),
.addr_in_4(20'b0),
.cmd_in_0(16'b0),
.cmd_in_1(16'b0),
.cmd_in_2(16'b0),
.cmd_in_3(16'b0),
.cmd_in_4(16'b0),
.pc_ena_out(),
.addr_out_0(),
.addr_out_1(),
.addr_out_2(),
.addr_out_3(),
.addr_out_4(),
.cmd_out_0(),
.cmd_out_1(),
.cmd_out_2(),
.cmd_out_3(),
.cmd_out_4(),
.data_out_0(letter[7:0]),
.data_out_1(char_line[7:0]),
.data_out_2(),
.data_out_3(),
.data_out_4(),
.clk_b(host_clk), // Host (Z80) clock input
.write_ena_b(host_wr_ena), // Host (Z80) clock enable
.addr_host_in(host_addr[19:0]),
   .data_host_in(host_wr_data[7:0]),
.data_host_out(host_rd_data[7:0])
defparam gpu_RAM.ADDR_SIZE = 14, // pass ADDR_SIZE into the gpu_RAM instance
         gpu_RAM.PIXEL_PIPE = 3;    // set the length of the pixel pipe to offset multi-read port sequencing
.clk(clk),
// inputs
.x_in( disp_x ),
// outputs
.x_out( [9:0]),
//  The disp_x is the X coordinate counter.  It runs from 0 to 512 and stops there
//  The disp_y is the Y coordinate counter.  It runs from 0 to 256 and stops there
// Get the character at the current x, y position
assign disp_pos[5:0]  = disp_x[8:3] ;  // The disp_pos[5:0] is the lower address for the 64 characters for the ascii text.
assign disp_pos[10:6] = disp_y[7+FONT_8x16:3+FONT_8x16] ;  // the disp_pos[10:6] is the upper address for the 32 lines of text
//  The result from the ascii memory component 'altsyncram_component_osd_mem'  is called letter[7:0]
//  Since disp_pos[8:0] has entered the read address, it takes 2 pixel clock cycles for the resulting letter[7:0] to come out.
//  Now, font_pos[12:0] is the read address for the memory block containing the character specified in letter[]
assign font_pos[10+FONT_8x16:3+FONT_8x16] = letter[7:0] ;       // Select the upper font address with the 7 bit letter, note the atari font has only 128 characters.
assign font_pos[2+FONT_8x16:0] = dly3_disp_y[2+FONT_8x16:0] ;  // select the font x coordinate with a 2 pixel clock DELAYED disp_x address.  [3:1] is used so that every 2 x lines are repeats
//assign osd_image = char_line[(~dly6_disp_x[2:0])];   <--- edited out - replaced by bitplane_to_raster instance
assign read_text_adr[10:0] = disp_pos[10:0];
assign read_text_adr[19:11] = 9'h2;        // my mistake, I has 1bit instead of 10bits
assign read_font_adr[10+FONT_8x16:0] = font_pos[10+FONT_8x16:0];
assign read_font_adr[19:11+FONT_8x16] = 0;        // my mistake, I has 1bit instead of 10bits
// *** Create a serial pipe where the PIPE_DELAY parameter selects the pixel count delay for the xxx_in to the xxx_out ports
hde_pipe[0] <= hde_in;
hde_pipe[9:1] <= hde_pipe[8:0];
hde_out <= hde_pipe[PIPE_DELAY-1];
vde_pipe[0] <= vde_in;
vde_pipe[9:1] <= vde_pipe[8:0];
vde_out <= vde_pipe[PIPE_DELAY-1];
hs_pipe[0] <= hs_in;
hs_pipe[9:1] <= hs_pipe[8:0];
hs_out <= hs_pipe[PIPE_DELAY-1];
vs_pipe[0] <= vs_in;
vs_pipe[9:1] <= vs_pipe[8:0];
vs_out <= vs_pipe[PIPE_DELAY-1];
HV_pipe[0] <= HV_triggers_in;
HV_pipe[9:1] <= HV_pipe[8:0];
HV_triggers_out <= HV_pipe[PIPE_DELAY-1];
// This OSD generator's window is only 512 pixels by 256 lines.
// Since the disp_X&Y counters are the screens X&Y coordinates, I'm using an extra most
// significant bit in the counters to determine if the OSD ena flag should be on or off.
if (disp_x[9] || disp_y[8])
dena <= 0; // When disp_x > 511 or disp_y > 255, then turn off the OSD's output enable flag
else
dena <= 1; // otherwise, turn on the OSD output enable flag
if (~vde_in)
disp_y[8:0] <= 9'b111111111; // preset the disp_y counter to max while the vertical display is disabled
else if (hde_in && ~hde_pipe[0])
begin // isolate a single event at the begining of the active display area
disp_x[9:0] <= 10'b0000000000; // clear the disp_x counter
if (!disp_y[8] | (disp_y[8:7] == 2'b11))
disp_y <= disp_y + 1'b1; // only increment the disp_y counter if it hasn't reached it's end
end
else if (!disp_x[9])
disp_x <= disp_x + 1'b1;  // keep on addind to the disp_x counter until it reaches it's end.
// *** These delay pipes registers are explained in the 'assign's above
dly1_disp_x <= disp_x;
dly2_disp_x <= dly1_disp_x;
dly3_disp_x <= dly2_disp_x;
dly4_disp_x <= dly3_disp_x;
dly5_disp_x <= dly4_disp_x;
dly6_disp_x <= dly5_disp_x;
dly7_disp_x <= dly6_disp_x;
dly8_disp_x <= dly7_disp_x;
dly1_disp_y <= disp_y;
dly2_disp_y <= dly1_disp_y;
dly3_disp_y <= dly2_disp_y;
dly4_disp_y <= dly3_disp_y;
dly1_letter <= letter;
dly2_letter <= dly1_letter;
dly3_letter <= dly2_letter;
dly4_letter <= dly3_letter;
dly1_dena   <= dena;
dly2_dena   <= dly1_dena;
dly3_dena   <= dly2_dena;
dly4_dena   <= dly3_dena;
dly5_dena   <= dly4_dena;
dly6_dena   <= dly5_dena;
osd_ena_out  <= dly4_dena; // This is used to drive a graphics A/B switch which tells when the OSD graphics should be shown
// It needs to be delayed by the number of pixel clocks required for the above memories
end // ena
end // always@clk
endmodule
Offline BrianHG
    • LinkedIn
« Reply #563 on: December 05, 2019, 10:23:17 am »
Yes, for now we are not touching the dly_x_out of the new module.
Sticking the module into 1 bit mode, normal 8 bit with an appropriate background color should create visible test on screen if you feed the new image out into the vid_out_stencil.  I would 'or' in 2 or 4 appropriate HV triggers as test margins.
Get rid of the doctored color_sel.  Next you will need to decide on the simple palette ram, or the complex 5 port ram method I listed above.  The simple one may use 1 additional M9K block, but uses a fraction the gates.  You decide where and how to map the memory.  Remember to protect the main system memory if you are going outside the 16k boundary.
« Reply #564 on: December 05, 2019, 10:57:26 am »
Hmm... okay, here's where I am with the internal connections:
.clk(clk),
// inputs
.ram_byte_in(char_line),
.ram_byte_h(8'b00000000),
.x_in( disp_x ),
.colour_mode_in( GPU_HW_Control_regs[12][1:0] ),
.two_byte_mode( GPU_HW_Control_regs[11][0] ),
// outputs
.x_out(), // disconnected for moment
.colour_mode_out() // disconnected for moment
And replace it with...? I'm a little lost as to what we do with the 8-bit (and potentially 16-bit) output from vid_osd_generator now.  The stencil doesn't have an 8-bit wide input - even color_sel doesn't - speaking of which, you want me to get rid of that completely?
Offline BrianHG
    • LinkedIn
« Reply #565 on: December 05, 2019, 02:29:05 pm »
.clk(clk),
// inputs
.x_in( disp_x ),
// outputs
Just tie the upper bits of '.pixel_out( pixel_out_top ),' to R,G,B.
We don't need snow or color settings from the debugger.
« Reply #566 on: December 05, 2019, 03:19:50 pm »
Hokay, well clearly there's a timing issue I need to sort out, though:
Full project files attached so you can view the wiring in the design as well as the code. (Though the project files attached may have pixel_out_top incorrectly wired to the stencil - I've got pixel_out_top[3..0] connected to r_in, g_in and b_in now.)
EDIT: Better image, although it's not aligned to the screen properly (missing a column on the left and some of the top row - that's just the screen misaligned.)
« Last Edit: December 05, 2019, 03:33:12 pm by nockieboy »
Offline BrianHG
    • LinkedIn
« Reply #567 on: December 05, 2019, 06:21:17 pm »
Shouldn't you be using  'dly6_disp_x'.  Remember, since the first 'disp_x' has been used, there have been 6 pixel clock cycles until the '.ram_byte_in(char_line),' has a valid value.
Your 16 bit text mode doesn't look like the 8 bit text mode.  Copy the 8 bit mode and replace the 'bg_color[]' with the 'ram_byte_h[]'.
How did you move the OSD text across by 5 pixels?  An odd number...
Isn't osd_ena_out being set somewhere else.
Also, I don't see a disable mode in the current 6 modes.  Also in a disable mode, you should also '0' the 2 data outputs.
I haven't a clue about the 5 pixel (ahem 4 pixel delay once you fix an obvious thing).
I turned back on the HV_triggers test lines so you may count the error pixels.
I've attached the first fix only, plus turned back on the 'HV_trigger cursors so you may count the error pixels.
I've also attached the 'Quick-load' for the RS232 debugger which contains the cursor positions.
Offline BrianHG
    • LinkedIn
« Reply #568 on: December 05, 2019, 06:34:19 pm »
What in the world are all those delays for in the 'bitplane_to_raster' module?
Why would you want to add delay anywhere?
You are also missing a 'pixel_in_ena' and it's related function...
« Reply #569 on: December 05, 2019, 07:30:54 pm »
Was fairly sure I was following your advice - the code hasn't changed for the last few times I've posted it up here..  ???
Ah yes it is.  Fixed that.
Is this mode selected by the pixel_ena line you want me to connect to the raster module?
Fixed it - looks like the delays I've erroneously added to the bitplane_to_raster module were causing the problems.
884976-0
I added them when I was creating the bitplane_to_raster module - you'd mentioned that signals had to be delayed, so they were the first things I created in that module.  Probably a misunderstanding on my part.  ::)
This pixel_in_ena - as I asked above, does this set the disable mode in the bitplane_to_raster module?
Offline BrianHG
    • LinkedIn
« Reply #570 on: December 05, 2019, 07:37:56 pm »
Your pixels are still off by 1 or 2 according to the image I see.
The original code has 0 delay on the bit selection.  This new code has 1, so long as you remove all the internal delays.  You need the other modules to take that into effect.
Also, the pixel enable input should also mute the output pixels when it low and it should be fed by the original 'osd_ena_out' wire.
You want a disabled mode, and an ability to mute out the non-display area of the OSD text window.  So, both are needed.
You should have the original image, other than the text being blue, exactly if everything is done ok.
« Reply #571 on: December 05, 2019, 10:40:37 pm »
Right, fixed that by changing the x_in input to the bitplane_to_raster instance from dly6_disp_x to dly5_disp_x.  :-+
Done.  :-+
Okay, so what enables the disabled mode, if you'll excuse the oxymoron?
Like this then?
Updated project files attached.
Offline BrianHG
    • LinkedIn
« Reply #572 on: December 06, 2019, 12:12:59 am »
 |O  Arrrrrrggg, how did you do that?  You found a different, yet perfect solution to a weird problem I never thought would end up like this....
Ok...  Fine...  Great...
Next, the 2 palettes.
Now, I'm telling you this so you could construct 2 real palette .mif files...
For the text mode/sprites, the data in the 16 bit output goes like this:
1                                0
6                                0
AAAA RRRR GGGG BBBB
The RGB are 12 bit color data like you are used to.
The A     is a 4 bit translucency value.  0 being 100% opaque, 15 being completely translucent to the graphics mode beneath.
The text colors are as follows:
0 through 15 = The outline color, or, pixel data = 0 color.  Whenever a font has a 0 bit, depending on your character color background selection, one of these 16 colors will be used.
16 through 31 = The pen color, or, pixel data = 1 color.  Whenever a font has a 1 bit, depending on your character color foreground selection, one of these 16 colors will be used.
(When making a default VGA palette, for now, the foreground and background colors may be mirror or offset values.  Whatever mimics VGA's 16 text color settings)
For the graphics palette, colors 0 through 255 are used in order, however, the 16bits hold the color differently:
1                               0
6                               0
RRRRR GGGGGG BBBBB
This is known as 565 color, being 5 bits red, 6 bits green, 5 bits blue.
I would look for an old VGA paint software palette to close as close as possible for the 256 color palette truncated to the 565 standard while for the text, look for the standard 16 colors used by VGA.  Copy those to the text palette in 12bit color, plus, use 0 for the alpha channel except for background color 0.
The palette module should be external between the OSD and Stencil.  It should pass through the HDE,VDE,HS,VS with appropriate internal delay to match the speed of the palette memories.
You will need a host port to read & write to the palette as well.
The palette should have 2 inputs, the text top layer and graphics bottom layer feeding the 2 palettes.  The output for now will just be the text layer palette.  We will do the translucency mixer math after the line address generators as they are needed to feed the graphics bottom layer.
Offline BrianHG
    • LinkedIn
« Reply #573 on: December 06, 2019, 12:32:19 am »
Well, you have 4 current modes, why not 7 modes and reserve a number for 'OFF'.
« Reply #574 on: December 06, 2019, 09:11:49 am »
Right, why didn't I think of that? ???
Okay, I've made colour_mode a 3-bit signal now - the 3rd bit enables/disables the output but can be changed later if more modes are created.
 :-//  Sometimes I almost make it look like I know what I'm doing, but not often...  :-DD
Okay, will get back to you soon on these...  :-/O
