Ok, I am having difficulty with the hack. First off, I am a Mac user and have rarely used Windows in the last five years. I am also not very knowledgeable in the command line interface. I have access to a windows 8 laptop and tried to follow the directions Mike posted bellow but was not able to get CRC01 to run. I assume that all I have to do is enter "CRC01" and then hit return, if this is not the correct procedure what is the correct procedure (so about being so daft). I also tried just running the expanded file on the desktop CRC01 but that did not work either. I did a quick search on google for procedures but have not really found what I am doing wrong. ![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/xfacepalm.gif.pagespeed.ic.EBDwh1hCfo.png)
HELP!
- open explorer (win+e)
- navigate to the folder where the uncompressed hack resides (if zip still compress, decompress it by using the right click menu)
- SHIFT-right click on the folder, you'll have additional options available - one is to open a command window in this folder - do so
- you see a new window with black background -> that's the command line interface, ensure that the shown path contains crc01.exe (issue a "dir" command)
- use notepad++ if mistrusting notepad.exe - follow the regular hack instructions
if crc01.exe is not in the "path", then that command will fail.
