Thanks, Mark. You are correct. One problem I notices was that at 12 Volts (DC) track voltage, I could not get it to move until the speed control was around 25 MPH. However, when I changed it to a pack with 16 Volts, I got better slow speed control. Now I can get it to move around 15-18 MPH on the control. My thought was that the "old" 3 pole motor did not have enough torque to get it moving. I did not want the track to be too high as I want to be able to run other locos without burning the motors going over 12 Volts.
So now, I must play with the settings as you mentioned to get better slow speed control. Yes, I too like things to move slow so that it looks more realistic. I think I have a lot more to experiment with this contraption. Thanks again for the pointers. Much appreciated.
