Author Topic: Choosing between entry-level 12-bit DSOs  (Read 548151 times)
Offline tggzzz
Re: Choosing between entry-level 12-bit DSOs
« Reply #650 on: April 30, 2024, 07:39:16 pm »
With respect to some of this recent discussion ... would it be correct to say that a year ago, when it was a choice between 8-bit, 1Gs scopes (i.e., the SDS1104X-E or the DS1054Z), neither would be able to capture / render the finer details of a rapidly rising pulse? Or is there more to this than just the sampling rate?
The only important parameter is the analogue bandwidth. Advertising a samples/s figure much higher than 2.5*BW figure is marketing wank; it merely eases some implementation details inside the scope.
The other issue is the number of bits. 30 years ago I used top-end HP DSOs to measure sub-nanosecond risetimes; they were 6bits at best.
The number of bits is more important if you want to look at the frequency domain version of a signal, since they translate into the noise floor and spurious interpolation products. Here again there can be a lot of marketing want (that's why my .sig is there :) ). The key figure is the ENOB, the effective number of bits. Here 12 is usefully more than 8.
More than 8 bits can be useful in other circumstances, but not really for signal integrity. A beginner is unlikely to require 12 bits for time domain measurements.
« Last Edit: April 30, 2024, 07:42:39 pm by tggzzz »
Offline awakephdTopic starter
« Reply #651 on: April 30, 2024, 07:41:57 pm »
The latter, though, can be achieved with both the scopes we're discussing here. Both are good value, even without adding "for the money". Which of them is better overall? I wouldn't venture to say, even after all the comparisons of the interpolation details and all. Would I want to replace my DHO800 with SDS800X HD? No! I would now only agree to change it to something that has at least 4 Gsps and 500 MHz or better 1 GHz BW to make it a worthwhile replacement :).
But which of the two would I buy now, after my experience with the DHO800, if I had to choose one and both would have the same price? I am not sure. I would be struggling to make a choice. But I have to say that I have no problem agreeing to hack a device to change things I don't like. That's an important point when you consider the DHO800.
Those are very intriguing statements, especially in light of Josh's reminder about your dislike of the UI. In one sense, of course, this doesn't help at all! But in another sense ... I do feel a tiny bit better to hear someone with more experience say that you too would struggle with the choice. :)
Offline shapirus
  • Country: ua
« Reply #652 on: April 30, 2024, 07:45:18 pm »
BTW @awakephd, Dave Jones has received a SDS800X HD (along with one of the 1000x HD series) for review. I would suggest to hold your purchase for a little bit more until he gets better and films that review. I belive it may help in making a decision. He also reviewed the Rigol some time last year, make sure you watch that one too.
Offline shapirus
  • Country: ua
« Reply #653 on: April 30, 2024, 07:53:18 pm »
The key word here is "require". Yes, true, 12 bits are hardly required, in the strict sense.
However, having 12 bits of vertical resolution (assuming other parameters equal) simply makes the experience of using the scope more enjoyable: less pixelation and all, you know what I mean. That's important. Tools that are more pleasant to use encourage the user to spend more time with them and thus learn more and become more proficient.
Offline KungFuJosh
  • TEAS is real.
« Reply #654 on: April 30, 2024, 08:23:26 pm »
Not only that, the scopes are so cheap there's no point in getting an 8bit scope unless there's some advanced features or specs needed. Even still, the 12 bit stuff available now is really competitive.
Best Continuity Tester Ever
Best Continuity Tester Ever...Got Betterer!
Offline 2N3055
  • Country: hr
« Reply #655 on: April 30, 2024, 09:03:20 pm »
Hypothetical:
Your scope is stolen, and your insurance gives you $500 to cover the loss. Do you still buy the same scope?
I believe I would add another something and buy a more advanced one. But if I had only those same two options, then I'm still not sure. If it were the only option, I'd buy the DHO800 again any time. But if we add the Siglent to the list... I would have to give it a test drive to decide, I think.
That is a good, smart answer.  :-+
Dr. Richard W. Hamming
Offline tggzzz
« Reply #656 on: April 30, 2024, 09:04:58 pm »
Pixelation is inevitable with digitizing scopes and digital displays :)
Someone interested in scopes will use any scope regardless of pleasantness.
Someone not interested in scopes will use it for the minimum possible time.
Only a few people are TE addicts :)
A beginner can be overwhelmed by complexity; without a deep interest in the subject, the overwhelmed tend to quickly move elsewhere. Simplicity and a gentle learning curve can pay dividends.
Offline tggzzz
« Reply #657 on: April 30, 2024, 09:06:54 pm »
If cost is a dominant concern, then there are much cheaper alternatives than 8bit scopes.
Offline KungFuJosh
  • TEAS is real.
« Reply #658 on: April 30, 2024, 09:12:42 pm »
You can get a 2 channel 12 bit scope for $390, or 4 channel for $440. True, for some that price is too high, and they'll stick with less expensive 8 bit scopes. But that's a pretty small percentage on the grand scheme of things.
A few what? Million? 🤣
I don't know how many people are on this site, but I know a lot of them are either addicts, or they're addicts in denial. 😉
Offline tggzzz
« Reply #659 on: April 30, 2024, 09:41:13 pm »
I was thinking of more extreme constraints and radically different solutions.
Offline Harrow
« Reply #660 on: May 01, 2024, 01:07:52 am »
Which square wave do you prefer? Figure7, or figure8?
<ignorance alert>Help me to understand what I am seeing in these two diagrams? I don't know enough to predict which is from which scope, or why one is better than the other.</ignorance alert>
I'll take a guess that the two diagrams represent the displays of two oscilloscopes with slightly different bandwidths...Figure 8 being the higher. The point being that since the Fourier series of a square wave is 1 x fundamental + 1/3 x 3rd harmonic + 1/5 x 5th harmonic + 1/7 x 7th harmonic...etc., then you need a very high bandwidth to accurately display a square wave (or step function) of only modest frequency. When you don't pick up those higher frequencies, that shows in the corners of the trace and the difference in what is displayed by an oscilloscope that samples 60% faster than another is not worth worrying about. If you want an accurate display of a square wave or pulse I'd say you want to talk about how many MULTIPLES faster your sampling is....2X, 5X, 10X, etc, as 60% extra just isn't going to make that much of a difference.
« Last Edit: May 01, 2024, 04:44:24 am by Harrow »
« Reply #661 on: May 01, 2024, 01:11:01 am »
As with any new technology to them, analog or digital.
A scope is a scope is a scope and a DSO is no different to drive yet offers a massive amount of additional features which is entirely up to the user whether they use them or not.
To not have a decent feature set is a significant handicap, if not immediately certainly in the future when skill and knowledge develops.
The following users thanked this post: pdenisowski
Offline Harrow
« Reply #662 on: May 01, 2024, 03:14:37 am »
Or perhaps you think the Nyquist limit only applies to sine waves? Hint: it doesn't.
I think a better way to describe it is that Nyquist is about sinewaves and that all other waveforms can be constructed by a Fourier series of sinewaves. Then you think about what those other waveforms look like when the higher frequency components of the Fourier series are attenuated or removed. Having someone understand this goes a long way to them realising why their traces look like they do.
« Last Edit: May 01, 2024, 03:39:14 am by Harrow »
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #663 on: May 01, 2024, 05:01:43 am »
I agree that the machine tool analogy proved to be less than helpful.
Maybe I should give up on trying to generate analogies ... I think I'm going from bad to worse!
That frequently happens with analogies :( Analogies are often dangerous :)
analogies is good to broaden our perspective. imho awakephd's analogy is valid from his perpective. try to learn to see the world from other people's eye.
The other issue is ensuring thold requirements are met. Those are fixed for a given logic family, are <<tclock, and reducing the clock frequency doesn't help (unlike tsetup).
whats your point? those are specifications available in datasheet. they can add variables into the equation. better set the scew setting in scope right first. with BW limited scope, risetime will be "smoothen" anyway.
You don't need to.
Connecting four 1Hz signals with transition times <2ns is sufficient.
OK, discussion has been changed from sine waves and Nyquist limits to pulses just for me... got it.
No, the discussion hasn't been changed.
practically for square wave, Sinc interpolation failure is to plot only on transition edge. square wave misplot (Gibb's artefacts) is a lot less confusing than sin/analog misplot. if you know what i mean.
It's about observing short pulses, or intermittent glitches, or debugging signal integrity issues and visualizing transitions in digital circuits in general, where having to correlate one signal (e.g. clock) to another one or several is a legit and common use case: it requires both looking at transitions and having multiple inputs enabled at the same time.
Exactly.
It repeatedly surprises me how difficult it is to get people to recognise that.
Is the Rigol's inability to properly display such waveforms fatal? No, by no means it's not: after all, it doesn't fail to display them completely, so you will see it if there is something. Will it prevent the job from being done? No it will not, at least as long as the user is aware of these edge case (pun intended!) shortcomings.
Yup. Any scope is better than none, and you always have to be aware of the limitations of your tools.
A key use case w.r.t. signal integrity is verifying that a received clock signal is monotonic and without overshoot etc. That requires bandwidth plus good probing technique, and nothing else.
For data signals... Well some people claim they aren't repetitive, but clearly such people don't understand eye diagrams. They are much better at detecting signal integrity issues than "repetitive" signals.
And once the signal integrity has been verified, it is often better to flip to the digital domain and use a logic or protocol analyser.
what you type is true but inapplicable if you want to use it on BW crippled scope like both dho800 and sds800x. dho800 maybe less crippled, but can show incorrect signal. with sds800x, you wont see any glitches or overshoots on transition edge due to "proper" BW limiting. anyway, trying to do signal integrity at sub ns risetime, you need more expensive tool. signal integrity is about risetime specification is met, and also no excessive overshoot or reflection, and also prog. delay and jitter etc... imho you need at least 10 points for each ns, and thats 10-20GSps, none dho800 nor sds800x can provide. they only suitable for checking 10-20ns risetime logic, i guestimate 5-10Mbps, "signal integrity" wise. dont think nor expect too much.
fyi, recently i managed to figure out (rev.eng) which one is which on 14 bit DAC lane from FPGA clocked at 150-170MHz with just 4CH scope Rigol DS1054Z. with all the theories, opinions and philosophicals here, i shouldnt be able to. ymmv.
are you talking about sds800x? you opinion is partly true but saying its marketing wank is too much imho. trying to ease implementation also can means trying to represent true signal on screen and trying to be honest.
i cannot brain this... afaik signal integrity, you need more bits and more sample rate because we try to look in analog domain, not digital domain. and super many overlapping traces. if you want to look at digital domain alone, 1 bit scope / LA is enough. and 12 bits is not just for your logic family's application, other people use it for other things like audio? and FFT, so dont assume we are the only batch of breed on earth. and err... whats the cost of your top-end HP DSOs back then? and its equivalent price today?
is this what's in your mind? £6 24MHz 8 Channel USB Logic Analyzer 8 CH Logic Analyzer for Arduino MCU this imho is good enough for logic families (but not for signal integrity mind you). please try to be specific instead of open pop quiz statement. this is electronics forum, not philosophical forum.
here you demo that at some setup Sr / 2.22, sds800x is unable to reconstruct signal properly? from the look of it, yes it is.
Not correct. What I've shown is the behavior at SR / 2.04, not 2.22. The input signal was a 490 MHz sine.
but you have the capture title saying 450MHz (now i see you edited it), anyway in my earlier post above you, i said i stand corrected...cheers.
not to mention he keep confusing beginners that will read this thread with his 70's era's opinion. no insult nor ill-mean intended to him, i only reply to what are ambiguous/confusing, not just from him. cheers.
« Last Edit: May 01, 2024, 05:22:11 am by Mechatrommer »
Offline DimitriP
« Reply #664 on: May 01, 2024, 05:13:14 am »
"Not owning a car is a significant handicap, if not immediatelly certainly in the future when you are old enough to reach the pedals and get a license to drive"
Got it!
  • Country: my
« Reply #665 on: May 01, 2024, 05:28:11 am »
Got it!
countering argument with wrong analogy, strawman fallacy? got it!
« Reply #666 on: May 01, 2024, 06:42:01 am »
"Not owning a car is a significant handicap, if not immediately certainly in the future when you are old enough to reach the pedals and get a license to drive"
Got it!
Likewise owning a bicycle like the many CRO's I've had and never going back there thanks. Not for anyone and the last scruffy old non working HP I have is to be given away for Defpom to try and fix and make vids doing so.
Rightly these old CRO's belong in the last millennia or with collectors.
Offline gf
« Reply #667 on: May 01, 2024, 06:52:53 am »
You are seeing two imperfect reproductions of a square wave as you might see them on a scope. I'm not asking to speculate about the exact differences between them, I'm just asking for a subjective vote on which one you prefer. I'm not even asking why you prefer the one or the other. The question was primarily addressed to @shapiros, in response to his statement I quoted, but of course everyone is welcome to vote.
Offline shapirus
  • Country: ua
« Reply #668 on: May 01, 2024, 07:17:39 am »
That's a bit strange way of putting it. I would not exactly "prefer" either of them. They are both non-ideal reconstructions, and I would have to interpret either of them given all other circumstances such as the scope's bandwidth and sample rate, probing technique and setup in use, etc., and understand that there is some extent of uncertainty between the actual wave (after it passes the bandwidth limiting filter) and what's displayed on the screen. I would think that the amount of this uncertainty is lower in the second waveform.
Offline gf
« Reply #669 on: May 01, 2024, 08:36:47 am »
Then it seems that you intuitively prefer the softer, Rigol-like interpolation filter. At least in this particular context. And I think my vote would be the same. I do not see what additional useful information I could obtain from figure7.
To clarify the context: It is a 10MHz square wave with steep edges (like you would get it from a Bodnar pulser), passed through a 4th order maximally flat filter with a -3dB bandwidth of 250 MHz (simulating a frontend), sampled at 312.5 MSa/s, and then interpolated with two different reconstruction filters in order to obtain the two plots. Figure7 uses a sharper filter (more like Siglent) and figure8 uses a softer filter (more like Rigol). The traces calculated for different sampling phases are aligned at the trigger point and overlaid.
« Last Edit: May 01, 2024, 08:43:00 am by gf »
The following users thanked this post: awakephd
Offline tggzzz
« Reply #670 on: May 01, 2024, 09:25:44 am »
Yes, it applies to any new technology.
That doesn't change certain important considerations as to whether an instrument is more or less complicated and the scope of the learning curve:
  • more controls => more difficult
  • all controls immediately visible => easier
  • some "internal" controls to be discovered and used after multiple user interactions => more difficult
  • evident difficulty many people have understanding the core sampling and reconstruction theory => more difficult
  • more tools in one box => more difficult
Of course there are compensating advantages; if there weren't tautech would have a much smaller market for his products.
An engineer chooses tools based on their suitability for a specific purpose. Different purposes can lead to a different choice.
For a completely off-topic analogy, consider learning to fly. Modern gliders have high performance laminar flow wings, with flaps, many instruments, radios, navaids, and in a few instances engines. Nonetheless nobody learns to fly in those. Beginners always learn to fly in gliders without flaps, without radios, navaids, engines, and with only an altimeter, ASI and vario[1]. (The 1930s Luftwaffe learned to fly on gliders without fuselages; some are still flying :))
The reasons for learning on simple machines should be obvious - and certainly will be if you learn to fly.
Ditto the reasons for using complex machines for long-distance flights.
Too often salesmen manage to get newly qualified pilots to buy machines that are too complex; the mortality rate amongst middle-aged doctors/lawyers is higher than expected.
[1] It is also good practice to demonstrate flying with all those instruments covered up :)
« Reply #671 on: May 01, 2024, 09:28:47 am »
Since eyesight is a thing you mentioned, I will say the ONLY benefit to you for the Rigol is the HDMI out.
The way the text is rendered makes a huge difference.
Offline tggzzz
« Reply #672 on: May 01, 2024, 09:30:06 am »
My comment should be read in the context in which it was written (this isn't stackexchange nor edaboard: multilevel quoting is possible).
Apart from that, while your statements are correct, clearly too many people don't understand them. Hence the preponderance of "cargo cult engineering statements" about 5*frequency, and similar.
Offline Antonio90
« Reply #673 on: May 01, 2024, 09:40:42 am »
I get your point, but I'm not sure it's good advice without someone knowledgeable to help you. My experience wasn't good with analog CRT scopes, even though it's purely anecdotical, might be useful.
When I was just starting out I bought a Tek 466 "untested" (LOL). Unsurprisingly, it did not work. After a long time studying the service manual, I traced a couple failures, on the PSU. The big caps were letting through all the ripple after the rectifier, a couple transistors were blown, and one or two blue "teardrop" caps (tantalum?) were shorted. I did a lousy repair job with my lousy soldering iron and skills.
A few hours later, no trace at all on the screen. I can't remember the details, but I think i traced the failure to the high voltage part on the bottom board, next to the PSU. And that's where the repair ended.
No skills and no HV tools, with my not-too-strong conservation instinct barely holding up.
Next was (I think) a Tek 2465B. Sold as working, and it did work as long as the readout was deactivated. If you activated it, some kind of digital signal appeared to ride on top of the trace, and the readout numbers were "pushed" upwards. After opening it, I saw liquid damage, corrosion and grime, and a resistor was open just before a pair of transistors driving the readout position on the screen. I, again, did a terrible job of removing the opened resistor with my cheap-ass soldering iron. The fact that the liquid damage had left some lime-like residue that could not be cleaned up with isopropanol did not help. Thankfully, I didn't break the pads. Then I found I did not have the right value resistor with the right power rating, but tested it anyway, and everything worked well.
Later on, I found on this forum the usual problems with the Dallas NVRAM, and the custom IC that gets way too hot. Replacing the NVRAM would have meant a desoldering gun (nothing under €100, even second hand), another dallas (€20? plus shipping), and a programmer (~€120 minimum). Plus the €120 of the 'scope. I ended selling it for what it did cost me.
Last try was one of the latest HAMEGs CRO, full SMD. It did cost me 10 bucks, but no schematics and it had been canibalized.
I reckon I made a lot of mistakes, but bear in mind I did know next to nothing about electronics. I learned a lot, too, one of the main ones being that if you need a tool, buy a properly working and supported one. All of this would, most likely, have ended differently if I had someone experienced guiding me a bit, but I didn't and still don't.
Take all of this with a grain of salt, of course, but if you don't have experienced hobbyists/engineers near you willing to help, my recommendation is do not buy an analog CRO. They are proper tools and the service manuals are a thing of beauty, but most of the people recommending them are experienced engineers that know their way around HV and these complex devices.
Offline shapirus
  • Country: ua
« Reply #674 on: May 01, 2024, 09:41:42 am »
I'll disagree with these two.
1) as long as sane defaults are used, that is not true: the user doesn't need to touch the unknown controls until they become required for a specific task;
2) again, the user can use only the familiar tools, keeping the rest aside until it's time to use them.
Then again, we're talking about an electronics test and measurement instrument, the mere fact of using which assumes that the user has at least basic understanding of school-level physics and electricity and can read, and that means that the user can make use of the instruction manual that comes with equipment, which will resolve most of the confusion that may arise from seeing all the controls and menu options.
