What's the deal with this positive terminal design?
Seems like something they have bodged into working, and marketed as some wizz-bang material tech?
https://battlebornbatteries.com/blogs/articles/technical-note-on-the-safety-and-design-of-the-battle-born-100ah-positive-terminal/
Holy moly, they actually released a mycrimes.txt
They keep referring back to UL/Intertek certification as if that somehow excuses the various criticisms. Such certifications basically just ensure that the thing won't explode or burst into flames under normal or single fault conditions,
and when the product has been manufactured correctly. That last bit is critical, if your quality control is crap (i.e. someone sets the wrong torque when fastening those bolts, or forgets to apply loctite correctly), then good design and safety certs are basically meaningless.
Perhaps if Intertek had specifically tested this "protective mechanism" then the certification would have some meaning. But Intertek would only conduct such a test if prompted to by Battleborn. I'm assuming they didn't do so, for obvious reasons.
Though I don't think that they just have a quality control issue. Their explanation of the working principles of this "protective mechanism" is really bad. Specifically, they suggest that a few nanometers of oxide are going to interrupt current in the presence of substantial vibration (the kind of vibration which is expected in normal use). In theory, if the entire terminal/busbar assembly were kept perfectly rigid (preventing any wiping between contact surfaces from bypassing/disrupting the oxide), this might have a chance at working. But it won't work because:
1. They suggest that the plastic case and thermal epoxy around the terminal is sufficient to "fix" the terminal assembly in place. There's no way this is rigid enough to keep that oxide stable during normal use.
2. Even if the terminal was kept perfectly rigid, the busbar would also need to be fixed similarly. But their own document states that the contact pressure will decrease during the fault condition. This means the contacts will be more mobile, making the oxide less effective as a current interrupter.
I could keep beating the horse, but I don't see the point. It's clear they're grasping at straws to excuse an obvious design flaw. I guess at least we can use this as a case study in bad design (and also bad business).
