Author Topic: What did you buy today? Post your latest purchase!  (Read 2848109 times)
Offline VEGETA
  • Country: jo
  • I am the cult of personality
    • Thundertronics
« Reply #6025 on: April 03, 2018, 09:18:52 am »
Two probes, ESD mat with leads and wristband.
can you please share link and price for it?
« Last Edit: April 03, 2018, 11:19:11 am by BU508A »
Offline Trisc
« Reply #6027 on: April 03, 2018, 01:09:06 pm »
Finally, a decent meter :) Just as well the seller packed it really well because the box had a 4" hole in it - box handed to me on the doorstep with the hole underneath so I wouldn't spot it... Thankfully the meter survived though.
Chris
Can I ask how much you paid?
I’m in the market for a new meter too.
Tossing up between an old keithley or a new(ish) Agilent, but the prices are a bit painful for the home lab!
Ps: nice workspace!
I paid £360, which is probably about the going rate for these in good condition.
Yeah, that’s about the going rate I’m seeing too ;)
Enjoy!!!
If it hasn't blown up at some stage during development, you're doing it wrong.
Dream big, think big, stick at it & youll achieve greatness.... one day....
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #6028 on: April 03, 2018, 01:23:29 pm »
Little NVMe SSD...  :o
Offline ChrisLX200
« Reply #6029 on: April 03, 2018, 02:50:00 pm »
On expectation of delivery of 5 Raspberry Pi's (from TopLoser on here) I bought a load of extra stuff - small keyboard & mouse, L298N driver boards, and too many other small bits to mention. Also 3D printing some pi cases and a tracked robot I will be making.
...and the printer working on robot bits (apparently slow because it's currently on the outer shells which are done at reduced speed). Two 3Kg PETG spools loaded (black and white) onto my home-made spool rollers.
https://youtu.be/iAYbggRa-tM
« Last Edit: April 03, 2018, 03:10:20 pm by ChrisLX200 »
Offline boffin
« Reply #6031 on: April 04, 2018, 02:55:48 am »
A couple of 2m power bars that were getting tossed from the data centre.
« Reply #6032 on: April 04, 2018, 03:33:34 am »
A sample book of SMD Inductors to go with last weeks arrival of an assortment box of through hole ones.  :-+
Also a couple of High Voltage 'Spark Generators' Honestly Occifer I didn't know they were st......s  >:D
Offline DC1MC
« Reply #6033 on: April 04, 2018, 07:35:56 pm »
Some crimpy sockets (BNC, N, SMA)  for RG174 and a crimping tool, along with a strange BNC socket for with screws. Also some protectors for RG174.
Btw, does anybody know if there are different dies available for this model of crimping tool ?
 Cheers,
 DC1MC
Offline Kjelt
« Reply #6034 on: April 04, 2018, 08:03:48 pm »
Can you remove the dies from the tool in just a sliding movement or clicking then probably yes.
If it is stuck as it looks like then probably not.
Offline DC1MC
« Reply #6035 on: April 04, 2018, 08:19:33 pm »
Yes, they slide and are hold in place by a screw, please observe the picture, if anybody know the model or specifier, if any,  will be very glad to know.
 Thank you,
 DC1MC
Offline Kjelt
« Reply #6036 on: April 04, 2018, 08:47:48 pm »
Offline DC1MC
« Reply #6037 on: April 04, 2018, 09:09:33 pm »
But why did you then not buy the complete kit ?
Not sure if this is identical but sure looks like it
https://www.ebay.com/itm/Insulated-Cable-Connectors-Terminal-Ratchet-Crimping-Wire-Plier-Tool-Kit-w-Dies/401287695957?hash=item5d6e9c4e55:g:m9IAAOSw~AVYv-mV
True, I was searching for the coax crimper, but now I've found bot individual dies and sets.
Thanks for the hint.
 Cheers,
 DC1MC
Offline hscade
« Reply #6038 on: April 04, 2018, 09:13:10 pm »
i bought one from conrad for RG58,RG147 and most important RG316 for approx. 80€. works well and comes with a case for the whole stuff.
« Reply #6039 on: April 05, 2018, 02:04:52 am »
Random purchase just because it could be fun  :scared:
Some uncrustificatuon and tlc before adding some volts!
So it works  >:D
https://youtu.be/aGucgApUb64
« Last Edit: April 05, 2018, 07:09:18 am by beanflying »
Offline Harb
« Reply #6040 on: April 05, 2018, 04:58:10 am »
Hello, is that you Michele........I am sure you started this thread.........whats for dinner tonight.... :-*
Offline HecticZA
« Reply #6041 on: April 05, 2018, 07:02:27 am »
Lol, that would be cruel.
:D
Sent from my SM-N950F using Tapatalk
Offline ChrisLX200
« Reply #6043 on: April 05, 2018, 12:04:06 pm »
Agilent 82357B USB/GPIB interface arrived, looks well made (cloned). Also a used set of Fluke DMM probes, and a bunch of Raspberry Pi's.
I can now complete my little robot using the Pi, still needs tracks printing though and waiting on delivery of more bearings (4 each side and I ran out). I want to add a camera too.
Offline Mr. Scram
  • Display aficionado
« Reply #6044 on: April 05, 2018, 12:13:58 pm »
Why do you use GPIB over RS232?
Offline ChrisLX200
« Reply #6045 on: April 05, 2018, 03:14:48 pm »
Faster response - up tp 1k smaples/sec. I didn't reckon on the distance it sticks out the back though, a bit inconvenient.
Offline Mr. Scram
« Reply #6046 on: April 05, 2018, 03:24:07 pm »
Does it work, and where did you buy it?
I'm currently outfitted for RS232 communications, but faster readings are a plus.
Offline ChrisLX200
« Reply #6047 on: April 05, 2018, 03:59:21 pm »
Dunno yet :) Will check it out later tonight.
https://www.ebay.co.uk/itm/Agilent-HP-USB-GPIB-Interface-82357B-GPIB-USB-High-Speed-USB-2-0-Connector/132164958310?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
Offline paulca
« Reply #6049 on: April 05, 2018, 07:54:55 pm »
I know this is the where the electronics porn watchers hang out so I thought I'd share a bit of Andonstar magic.  All should be linkable to the full 12Mpixel originals.
Symmetry.
Remember, power LEDs can do interesting things is you let them:
I got away with this... the chip shifted during reflow!  (The bridged pins are actually meant to be (they are linked through the pads with no solder mask):
Another shift.  Lesson learnt, the board MUST be level when it reflows, I was holding the board in pliers at an angle.
