Author Topic: What did you buy today? Post your latest purchase!  (Read 4919333 times)
grumpydoc, MarkL and 306 Guests are viewing this topic.
Offline ahnuts72
« Reply #12000 on: March 10, 2023, 11:53:35 pm »
Not today but in the last week
Long time away but getting back into everything after traveling all over the country for work.
The SA was to good to pass up at $330 Yankee bucks had align now align all error but no unlock and the clock was all wrong so took a chance it just needed the battery replaced and all is right in the world now once it has the backlight is replaced.
The counter was buy it now for $40 so thought I would take a chance as my only other one stops at 100MHz and it works.
Hooked to my leader sig gen and they both match as close as I can tell with my counter on my tm500 mainframe and the hardware counter in my tek 2467
Also have an HP437b coming was $49 and lister said it passed self test so decided why not.
« Last Edit: March 10, 2023, 11:56:44 pm by ahnuts72 »
Online Martin72
« Reply #12001 on: March 11, 2023, 11:57:37 pm »
A work light, a cable knife and needle nose pliers from Lidl.
All in a surprisingly good quality, especially the light.
« Reply #12002 on: March 12, 2023, 04:42:36 am »
Several lb's of unobtanium (locally or ex Asia) Copper and a little Hafnium from an unhelpful US supplier who after 3 messages over a week couldn't be bothered replying as to shipping the other two items in theory not shippable to Oz because 'reasons' unlike the third which they already in theory allowed :palm:
Did a little due diligence in what seems to be a complete Snake Pit of on forwarder services which seem to vary from gangsters and standover merchants to spinning the wheel of non delivery and black hole shipping :o
Final result looks like I will about break even on the numbnuts listing postage price and the items (paid with Paypal) have left and are headed to Stackry who also takes Paypal for a little extra security. Because also for 'reasons' internal USA shipping was 'free'.
What they are is low Current Plasma tips for an 80A machine cutting Torch.
Now I wait  :scared:
Offline Jeff eelcr
« Reply #12003 on: March 12, 2023, 06:34:06 pm »
 An eval PCB for the tektronix 100MHz to 500MHz DSO 2400 series scopes.
Jeff
Offline armandine2
« Reply #12004 on: March 13, 2023, 09:57:55 am »
just getting started with surface mount and now have an RS Pro 4 piece SMT Tweezer Set .
Gold Capacitor Prize - 2025
Offline PlainName
« Reply #12005 on: March 13, 2023, 04:50:19 pm »
Cheap and nasty (except it isn't) calculator:
https://www.aliexpress.com/item/1005004974428274.html
Seems to work fine, and the stylus needs wrestling from the case (a change to having them spontaneously eject and get lost). Only real problem is that the 2nd function legend applies to the keys below but is printed right up against the keys above. Takes super-human effort to remember to press the other key...
Anyroad, got this for the garage where I didn't want to trust a decent calculator to fate and/or a ham fist, and the sketch pad seemed like it might be useful for reminding one what the calculation is for.
Offline hli
« Reply #12006 on: March 13, 2023, 05:27:44 pm »
A CR2025 coin cell for my Keysight scope (because of https://www.eevblog.com/forum/testgear/keysight-dsox1102g-system-concerns-detected-325237/). Why do they try to save 10 cents on a 1000EUR scope by not using a 2032? Its not that they needed the space or so :-(
Offline PlainName
« Reply #12007 on: March 13, 2023, 06:02:30 pm »
Sometimes a CR2032 will fit in the CR2025 holder if they use long spring contacts where it slides in.
Offline exe
  • self-educated hobbyist
« Reply #12008 on: March 13, 2023, 06:59:26 pm »
How does scatchpad work? Is it really an lcd screen, or it's a purely mechanical thing? Can you please share a real photo of the scatchpad in action?
Offline PlainName
« Reply #12009 on: March 13, 2023, 07:25:20 pm »
It's not an LCD - I think it works on the same principle as an Etch-A-Sketch (that is, it's an electrostatic screen). And just to confirm that I took the battery out and could draw on the screen, and, as expected, the button didn't erase it. So the battery appears to be only used to erase (the E-A-S equivalent of shaking it inverted).
The stylus is only there to prevent you using a sharp implement (like an real pencil). You can draw with a fingernail, but the stylus has a decently large radius to prevent scratching.
The following users thanked this post: exe
« Reply #12010 on: March 14, 2023, 12:23:50 am »
Cool toy so I did a little looking in the reviews, seems there is two batteries just to confuse the users  ;D
Offline PlainName
« Reply #12011 on: March 14, 2023, 01:11:14 am »
Yes, you can still draw (rather, erase it) when the calculator has died. Or vice versa. Solar power would have been nice, though.
The hinge might come apart, so could be useful having the two parts separate. The two batteries would allow that, but I bet it wasn't designed for that possibility.
« Reply #12012 on: March 14, 2023, 01:23:23 am »
There is several different versions it seems from basic Calcs to solar backup ones to the one you linked. On my wish list for a moment of madness  >:D
Offline exe
« Reply #12013 on: March 14, 2023, 09:15:39 am »
How is the contrast? I've watched a few videos on such writing pads, and they all looked dim to me.
Offline PlainName
« Reply #12014 on: March 14, 2023, 10:29:36 am »
Yes, a bit dim. Well, non-contrasty. And it depends on how hard you press (presumably how thick the line ends up as, since it has no gradient). The screen is matt reflective, so the sketch can be washed out by your overhead lights if you hold it wrong. Other than that it is very much like eink, except lime green on black.
Oh, viewing angle isn't too hot. Probably about 120 degrees or so for the full effect. Frankly, I wouldn't buy one of these screens by itself if only because you can't selectively erase (or undo). But as an adjunct to the calculator to, say, jot down a series of results or whatever, it's a useful gimmick.
Offline RAPo
« Reply #12015 on: March 14, 2023, 12:03:05 pm »
A Peak ESR70 Gold, together with an SS-02 engineer desolder pump, will arrive this afternoon.
Offline DC1MC
« Reply #12016 on: March 14, 2023, 09:02:28 pm »
Chinesian day, so enabled by some other forum member and the small price, I've got the ceramic screwdrivers, sadly, in the set are three flat and one Phillips, but I'll hunt for a square and hex as well and maybe a star:
https://www.aliexpress.com/item/1005003944841422.html
also when I was ordering the screwdrivers I've seen some wolfram tipped scratchers, and I've got two for a song:
https://www.aliexpress.com/item/1005003234527797.html
They're absolutely BRUTAL, the tip scratches everything I've tested with, from an old sapphire watch glass, to a real chrome-vanadium tool, PCB and other stuff is like butter.
Enjoy the pictures,
DC1MC
« Reply #12017 on: March 15, 2023, 01:26:39 am »
Purchased another bit of "Fakita" tm garden kit. My baby 4" (brushed) one I got 18 months ago is still going great but I have two or three larger bits to chop. The Blower (brushless) I got 6 months ago is doing well so time to go for something that can really do some personal harm  :-DD
Only 12" Bar and I would prefer some sort of anti kickback protection so if you buy one play safely or just don't buy one if you haven't used a chainsaw before. Also not a thing to chop down a forest or firewood for winter but for the odd larger stump in a garden should be more than up to the job.
$67 AUpesos or less than $45 USD with Tax and delivered  :o eBay auction: #363961652723
Offline Swainster
  • Country: sg
« Reply #12018 on: March 15, 2023, 02:00:32 am »
Enjoy the pictures,
DC1MC
Goot are a well established Japanese brand - I wonder if these are original or fake? Seems like a strange thing to bother counterfeiting. By coincidence I just received a set of Philmore trimmer tools from Amazon US. I wasn't able to find the equivalent tools locally or on AliE, and the Amazon price seemed reasonable. The set seems to have almost everything except the 'screwdriver' type tips, so would make a good complement to the set you bought... in fact, I think I will put your set on my next AliE order as I've only got one ceramic trimmer (the one that looks like a chopped off phillips).
The 'scratcher' looks good. In English it would tend to be described as as a tungsten scriber, not really sure why we dont call it wolfram, especially given that its technical symbol is W.
Offline Black Phoenix
  • Country: hk
« Reply #12019 on: March 15, 2023, 02:35:47 am »
Believe me that if there is money to be made they would fake it. Heck they even fake the Casio F-91W or Swiss Stainless Steel tweezers (just a case of changing the laser engraving design).
Offline McBryce
« Reply #12020 on: March 15, 2023, 07:30:07 am »
It seems to have been an English thing to have their own names for elements: Potassium (K) is Kalium in German and Sodium (Na) is Natrium in German.
McBryce.
« Reply #12021 on: March 15, 2023, 08:01:55 am »
McBryce.
Blame some Swedish German for it and some other Germans for not seeing to it's loss of general usage. For 'once' it seems not to have been the English Language at fault  :-DD
History
In 1781, Carl Wilhelm Scheele discovered that a new acid, tungstic acid, could be made from scheelite (at the time called tungsten).[39][40] Scheele and Torbern Bergman suggested that it might be possible to obtain a new metal by reducing this acid.[41] In 1783, José and Fausto Elhuyar found an acid made from wolframite that was identical to tungstic acid. Later that year, at the Royal Basque Society in the town of Bergara, Spain, the brothers succeeded in isolating tungsten by reduction of this acid with charcoal, and they are credited with the discovery of the element (they called it "wolfram" or "volfram").[42][43][44][45][46]
The following users thanked this post: Swainster
Offline unknownparticle
« Reply #12022 on: March 17, 2023, 03:27:36 pm »
Being a bit of a vintage test gear nerd, I scored these beauties which arrived today!!
For new players and those that are not familiar with UK test gear brands, these are the legendary Avo 8, possibly the best analogue multimeter ever made.
First pic is the Mk4, dated 1972, in mint condition, I doubt it has ever been used!  Complete with leather case, leads, probes and destructions!
Second pic is the Mk5, dated 1973, same condition and accessories.
I've been after both versions, in this condition, for years!  They weren't cheap, but then again not expensive considering what they cost new!
The Mk5 was £500 in it's day!  So my Avo collection nears completion, I need a model 9, which is extremely rare, a Mk6 and a Mk7, those not so rare but difficult to find as new. The 7 was the last Model 8 made when production ceased in 2011, list price then was just shy of £800! According to Megger, the company that produced Avo meters then, production only stopped because certain parts could no longer be produced, demand was actually still there!! They didn't have the extra high voltage range though, evident by the lack of extra terminals at the top of the front panel. The Mk5 could read upto 3KV!! One of my favourite things about these meters is the test leads, thick, flexible, heavy duty, and very high quality!  Even though they have never been silicone they have always been so flexible, even in cold conditions!
« Last Edit: March 17, 2023, 03:36:37 pm by unknownparticle »
DC coupling is the devils work!!
The following users thanked this post: duckduck, w.v.s.
Offline PA0PBZ
« Reply #12023 on: March 17, 2023, 03:36:30 pm »
Those are true beauties, congratulations!
Offline wkb
  • PA1WBU
« Reply #12024 on: March 17, 2023, 04:02:46 pm »
McBryce.
And in Dutch the same. Hardly surprising.
