Author Topic: What did you buy today? Post your latest purchase!  (Read 2852237 times)
eutectique and 43 Guests are viewing this topic.
Offline Detlev
« Reply #12200 on: May 10, 2023, 01:30:42 pm »
Today a new attenuator arrived for my SA. Safety first :)
This post is "Made in Germany" 😎
Offline paulca
« Reply #12201 on: May 11, 2023, 01:04:10 pm »
Got one of these.  And here ends my short phase of buying cheap multi-meters.
https://www.owontechnology.eu/product/1362517/owon-b41t-4-1-2-digit-digital-multimeter-with-bluetooth
I like it, nice size, feels nice, screen look gorgeous.  I haven't really tested it out that much.  I tested it's resistence at the lower end with a 0.1Ohm resistor and it wasn't exactly accurate registering between 120mOhm and 200mOhm.  The ESR meter says the resistor is 96.4 mOhm.
I like the 5th digit, even if it's not totally accurate enough, but for working with slowly moving voltages like battery charging, having the extra digit a bit like the seconds hand on a clock is nice just to look at.
You can disable the auto power off, but annoyingly, like so many DMMs it does not disable the back light timeout.  I think out of 5 meters I have bought only one of them has that feature, the Aneng 9000 the backlight stays on if you disable auto power off.
Another negative on "useability".  The backlight button doubles up with "HOLD".  If you press and hold the button to turn the backlight on, it also enables HOLD, which is easy to miss.  Has to be disabled with a short press after the long for backlight.
« Last Edit: May 11, 2023, 01:07:00 pm by paulca »
Online RAPo
« Reply #12202 on: May 11, 2023, 04:03:50 pm »
This weekend an HP204D audio oscillator will arrive at my doorstep.
Online RAPo
« Reply #12203 on: May 11, 2023, 04:45:53 pm »
I bought the Dorsal experimenterboards (from kectronix.com) in order to steer my flipper zero more to electronics.
Online shapirus
  • Country: ua
« Reply #12204 on: May 11, 2023, 07:31:32 pm »
Just received the Aneng MH-13 megohmmeter. Very decent device for reasonable money, listed at $57 at the time of purchase, but with all the discounts active at the time I paid only $55 total for the MH-13 and the Aneng A3008 pen-style multimeter that I decided to buy for the sole purpose of satisfying the irrational desire of getting yet another multimeter.
What an awesome toy a megohmmeter is!
This model can test at up to 2.5 kV and measure resistances of up to 200 GOhm. Now I can easily blow up trashy multimeters and create beautiful blue sparks across narrow gaps between two conductors!
For the slightly more practical application, I can now do proper testing of e.g. flux conductivity and dielectric strength of PCBs. For example, I found out that a typical Chinese Green Double-Sided 2.54mm Protoboard™, when tested unused out of the box, withstands 1kV, starts to conduct an occasional spark at 2 kV and allows a sustained spark discharge at 2.5 kV between two adjacent pads.
One downside is that it is powered from eight AA batteries. I would much prefer a built-in Lithium battery. But there is sufficient room in the battery compartment to fit 3 x 14500 or flat Li-Ion cells, should I really want to do that. Will see how quickly it drains the AAs first.
Offline Martin72
  • Testfield Technician
« Reply #12205 on: May 11, 2023, 07:50:39 pm »
Arrived today:
Ersa Icon-1 in mint condition for small money..
Now several tips are on their way. 8)
« Reply #12206 on: May 13, 2023, 01:14:26 am »
Pretty sure I've measured seriously high temperatures in external cases when doing backups, hence my preference for one with a fan. Maybe I'll join your thread and run off some new measurements :)
I would avoid multibay enclosures.  I have a 5 bay.  I replaced the 120mm fan in it's base with a Noctua silent fan.  I am now going to buy single bays for all but the two raid backup drives.  Why?  The controllers in those multi-bay units try and do their own power saving by spinning down all the drives.
Are we talking the same thing? My comment, on temperatures with externals, was about M.2 SSDs but yours seem to be thinking rotating disks.
Having said that, I wonder if such external multi-drive cases would be available for the SSDs (other than the two-drive ones). It would be very compact in comparison.
Blatant OT thread promotion   >:D https://www.eevblog.com/forum/general-computing/portable-storage-devices/msg4859144/#msg4859144
The following users thanked this post: PlainName
Offline DiTBho
« Reply #12207 on: May 16, 2023, 05:09:18 am »
Campagnolo Zonda 90s wheels for my road bicycle  :D :D :D
The opposite of courage is not cowardice, it is conformity. Even a dead fish can go with the flow
« Reply #12208 on: May 17, 2023, 12:24:21 am »
Your front wheel is likely worth more than I paid for my Merida Roady  :-DD
Today is finally the day to get rid of my HP I3 Clunker workstation. Jonsbo MATX case was a great price and stil plenty of room for a GPU and a couple of extra cards I need to fit in it as well.
Offline DiTBho
« Reply #12209 on: May 17, 2023, 05:42:40 am »
@beanflying
A NOS Campy Zonda wheels 8speed (90s old new stock) set ~ 450 euro
A NOS Campy Shamal wheels 8speed (90s old new stock) set ~ 1000 euro
my Zonda wheels are secondhand, paid 120 UKP, not too bad  :o :o :o
I don't like carbon forks, only steel forks on a 90s titanium frame, but I needed something more comfortable than my old Mavic X wheels (very cheap, paid ~60 UKP secondhand) for longer bike rides.
Now I'm thinking of disassembling the Campagnolo Zonda wheel and mounting the Zonda rims on Mavic hubs.
Kind of hybrid Campy Zonda-Mavic wheels.
Online RAPo
« Reply #12210 on: May 17, 2023, 05:52:23 pm »
The trip to memory lane was extensive but not expensive. Got several slide rules/nomographs (including a long wanted Fiber Castel duplex with double logarithmic scales and a scale to multiply sine directly). Two HP Voyagers (one with badly leaked batteries) and a Mitutoyo micrometre. All for < Eu 100,--
Online RAPo
« Reply #12211 on: May 17, 2023, 05:59:42 pm »
Also, this weekend anHP204D arrived, and a Philps Pm2525 joined the collection
Online RAPo
« Reply #12212 on: May 17, 2023, 06:12:18 pm »
And a set of piping standardgraphs were added to the box.
Offline DiTBho
« Reply #12213 on: May 20, 2023, 06:06:24 pm »
A Mars 9000 rear derailer (made in Germany)
Offline TopQuark
  • Country: hk
« Reply #12214 on: May 21, 2023, 02:00:07 am »
Nintendo Switch OLED for the new Legend of Zelda game, worth it.
The following users thanked this post: DiTBho, Atomillo
Offline tautech
« Reply #12215 on: May 21, 2023, 01:22:04 pm »
120GB Kingston SSD for another PC build after both of the old 60GB OCZ SSD's I had didn't wanna function with a W10 install.  :rant:
Some 30NZD was cheaper than pissing around with them!
Offline jonpaul
« Reply #12216 on: May 21, 2023, 03:19:24 pm »
______FR_____
Bonjour a tous.....Aujourd'hui au Marché au Puces Porte du VANVE, , j'ai trouvé
1000:1 clamp on current transformer AOIP 82
glass syringe (  pour  alcohol)
Luxo lamp mount
Fabrication à la France.....
Tous....  €5!
Bon dimanche
Jon
_______EN____
Hello to all.....Today at the Flea Market Porte du VANVE, I found
glass syringe (for alcohol)
Luxo lamp mount
Made in France.....
total   €5!
Good sunday
Jon
Jean-Paul  the Internet Dinosaur
The following users thanked this post: rsjsouza, TizianoHV
Offline armandine2
« Reply #12217 on: May 22, 2023, 02:11:33 pm »
arrived today from Mouser
1206, 1210, 1812 Wurth MLCC capacitor kit 885 080 version 2.0
had got previously from RS Wurth's 0603 kit
some NP0 caps in amongst the X7R and X5Rs  :phew:
Funny, the things you have the hardest time parting with are the things you need the least - Bob Dylan
Offline tautech
« Reply #12218 on: May 24, 2023, 08:48:16 am »
In transit to a lunch date with member hendorog....after collecting an urgent FedEx shipment < Siglent stuff for a customer.
PPE, new radio earmuffs and Hygiene kits for 2 quite old PELTOR earmuffs < now as good as new.
500ml can of ROCOL RTD < fantastic metalworking compound.
10 pk of 125x22mm 1mm cutoff discs.
230V 125mm Bosch grinder at a price it couldn't be left on the shelf.
And lunch, with good company !
Offline jonovid
    • JONOVID
« Reply #12219 on: May 24, 2023, 06:42:45 pm »
hope to do the same.
 the reviews for zelda tears of the kingdom are excellent for this one!
an improvement on Zelda Breath of the Wild, that is saying something.
Offline DiTBho
« Reply #12220 on: May 24, 2023, 11:43:28 pm »
a weird ESR-tester :o :o :o
Offline vk6zgo
« Reply #12221 on: May 25, 2023, 01:55:34 am »
Sounds like a well spent day, Rob! :-+
Offline tautech
« Reply #12222 on: May 25, 2023, 04:23:30 am »
And we should do the same one day in Dec Bryan, lunch that is.
Member c47 not far from you was keen for us all to get together...... a pub lunch ?
Offline vk6zgo
« Reply #12223 on: May 25, 2023, 05:24:31 am »
Sounds good, Rob.
Closer to the day, I will have to check if SWMBO is all good with it.
She is a bit immobile, so won't be able to come, & I am her "primary caregiver".
Don't get me wrong, she "has all her marbles" & physically can do quite a lot, but she needs assistance with some things.
She will almost certainly say "go for it", but I don't like to leave her in the lurch if she needs assistance.
What with her condition, then the Covid episode, we have both become a bit reclusive.
Online Vgkid
« Reply #12224 on: May 25, 2023, 08:00:55 am »
A microvolt rms calibrator , some hakko chp-170 side cutters , and a few Diablo carbide tipped 12in pruning blades.
