Author Topic: What did you buy today? Post your latest purchase!  (Read 2852298 times)
jonpaul and 31 Guests are viewing this topic.
Offline w.v.s.
« Reply #12250 on: June 10, 2023, 12:20:50 pm »
Soldering pincers with interchangeable quartz points. Will be interesting to see the benefits. Did anyone reading this work with these in the past? They were made for dental applications, but sometimes tools from other disciplines can be quite helpful. I think a melting temperature >1700°C is beneficial, when you are soldering at high temperatures with flames, what we typically avoid when soldering components onto PCBs.  :)
« Last Edit: June 10, 2023, 01:35:14 pm by w.v.s. »
The following users thanked this post: DiTBho
Offline w.v.s.
« Reply #12251 on: June 10, 2023, 12:25:59 pm »
My video endoscope had a broken display, when I took it out the box which I stored in the cupboard after using it the time before. Maybe the camera pressed onto the foil in front of the display, when it was in its box. However, I decided to buy a replacement 5.5mm endoscope and the new one has a second camera looking to the side and a better image quality.
« Last Edit: June 10, 2023, 02:28:04 pm by w.v.s. »
Offline PA0PBZ
« Reply #12252 on: June 10, 2023, 01:43:54 pm »
the new one has a second camera looking to the side a better image quality.
Is it a second camera or just a smart placed mirror?
Offline w.v.s.
« Reply #12253 on: June 10, 2023, 02:26:27 pm »
Manufacturer calls it "Dual Camera" and I think that is true. I can see two lenses and I guess the sensors are cheap enough to not share them. The endoscope units without display are rather cheap (about 10€). The "dual camera screen endoscope" is approx. 50€.
The following users thanked this post: PA0PBZ
Offline McBryce
« Reply #12254 on: June 11, 2023, 09:38:47 am »
Have you a link to where you bought it?
McBryce.
Offline DiTBho
« Reply #12255 on: June 11, 2023, 11:14:13 am »
different kind of lens, but I seriously need a microscope
my eyes are too bad for checking smd components :o :o :o
The opposite of courage is not cowardice, it is conformity. Even a dead fish can go with the flow
Offline tautech
« Reply #12256 on: June 11, 2023, 11:34:42 am »
There are solutions
https://www.aliexpress.com/item/1005005614000500.html?
Offline w.v.s.
Offline coppercone2
« Reply #12258 on: June 12, 2023, 02:56:38 am »
I thought glass is not ESD safe lol, they charge up glass rods IIRC. Rub a textile furthing on a glass rod or a plastic rod and it holds a charge.
Kind of wonder about ceramic tweezers too, I bet they should be made out of nitride or something conductive
« Last Edit: June 12, 2023, 02:58:33 am by coppercone2 »
The following users thanked this post: w.v.s.
Offline w.v.s.
« Reply #12260 on: June 12, 2023, 03:10:20 pm »
The following users thanked this post: bingo600
Offline exor
« Reply #12261 on: June 13, 2023, 06:46:18 pm »
AVO Mk4
« Last Edit: June 13, 2023, 06:47:49 pm by exor »
Online Calambres
    • Piso-Tones
« Reply #12262 on: June 14, 2023, 07:45:00 am »
Siglent SDG1032X Arbitrary Waveform Generator:
Not yet received though...
The following users thanked this post: tautech, DiTBho
Offline DiTBho
« Reply #12263 on: June 14, 2023, 12:01:48 pm »
I visited a craftsman's workshop and was introduced to his master
And brought home a wonderful handmade 700cx25 steel fork weighing only 600g!
(Sujami-Bressan steel fork, to be chromed)
Usually, a steel fork is 900-1000g, this one is special as it's as light as aluminum but much stronger!
cost:
  • Industrial chromed steel fork: 50 euro, 1000g
  • by a craftsman handmade chromed steel, 300 euro, 700g
  • by a master craftsman handmade chromed steel, 500 euro, 600g
Better than Vetta's, better than Columbus's
my Sujami-Bressan chromed fork is the Hattori Hanzo of every steel forks  8)
« Last Edit: June 14, 2023, 12:09:26 pm by DiTBho »
Offline tautech
« Reply #12264 on: June 14, 2023, 08:16:55 pm »
Is he related ?
Offline Kim Christensen
« Reply #12265 on: June 15, 2023, 12:35:32 am »
Is he related ?
Probably more like this guy:
Offline twospoons
« Reply #12266 on: June 15, 2023, 04:39:19 am »
3d printer nozzle with a polycrystalline diamond insert. Because why not?
https://www.trianglelab.net/products/zsd-diamond-copper-alloy-nozzle?VariantsId=11179
Harder than any abrasive filament, and PC diamond has better thermal conductivity than copper. Supposed to be low friction too.
Offline Mr.B
« Reply #12267 on: June 15, 2023, 04:55:41 am »
3d printer nozzle with a polycrystalline diamond insert...
Thanks for that.
I might try one.
My carbon fibre reinforced PETG eats nozzles.
They are pretty expensive though.
If it lasts longer than 4 of my hardened steel ones, then it will be worth it.
Offline DiTBho
« Reply #12268 on: June 15, 2023, 10:21:25 am »
Is he related ?
LOL  :-DD
more like Pai-Mei  :o :o :o
Offline DiTBho
« Reply #12269 on: June 15, 2023, 10:42:11 am »
qty=2, Raidon RAID box, s/ATA disks, SCSI U320 interface
qty=10, Seagate Barracuda disks, (8 to use, 4 on each RAID box, two spare)
qty=1, IKEA metal shelving, to be used to accommodate the two RAID units
despite they are Hardware RAID{0,1,5}, you can switch to "bow-mode", this way on the interface you just see four disks, so you can use software kernel RAID functions.
The following users thanked this post: Ed.Kloonk
Online RAPo
« Reply #12270 on: June 15, 2023, 03:36:16 pm »
A set of analogue meters
The following users thanked this post: Mortymore
Offline DiTBho
« Reply #12271 on: June 15, 2023, 05:19:02 pm »
A set of analog meters
me too, 16 minutes ago  :D
two analog amperometers, 0-6A (rare to find), in white plastic, to be mounted on a panel.
do you know if there is a way/kit to backlight this kind of meter?
I need to install one of them inside a box, so if backlighted it would make it more easy to read  :-//
Offline erdos
« Reply #12272 on: June 15, 2023, 05:44:10 pm »
I bought a used Hp 42S calculator earlier this month in good condition.
« Last Edit: June 16, 2023, 12:00:37 am by erdos »
The following users thanked this post: oilburner, cncjerry
Offline Neepa
  • Mechanic by trade Electronics enthusiast by choice
« Reply #12273 on: June 15, 2023, 06:01:14 pm »
A whole lotta screws for my HP4145A and 7225B Plotter. The former is missing some and the latter needs new ones as someone once upon a time managed to bend nearly all 4-40 UNC ones on it.
SUB-D 25pin Connectors and symetrical cable. To convert the Centronics 24pin interconnect cable between the 4145A and its Test Fixture to SUB-D. Trying to convert a HP-IB cable to straight Centronics 24pin proved to be just a headache.
TWO Network Analyzers. Wandel&Goltermann SNA-62. One functioning fine and the other with seemingly several problems. Local Oscillator doesn't seem to swing and some brain rot. Might be BootRom, RAM or some other digital problem. The functioning one will repair the other one after using it as an Troubleshooting aide.
A project for the Winter though. After cleaning and inspecting the functioning one.
Need to get a Operator Manual for it too.
HP3577A Operators Manual. It was cheap and available. A picture book for grown ups essentially. And a sad reminder how great Manuals once were in decades past.
Turbojet Mechanic playing EE.
Online RAPo
« Reply #12274 on: June 15, 2023, 06:18:33 pm »
Don't know, but you can always add a light on its own battery.
