Author Topic: What did you buy today? Post your latest purchase!  (Read 2855851 times)
Offline coppercone2
« Reply #12375 on: August 13, 2023, 06:36:19 am »
1/2 inch brass bolt
Offline tautech
« Reply #12376 on: August 13, 2023, 07:49:53 am »
1/2 inch brass bolt
To fix a welder ?
The exact reason I keep some brass threaded rod on hand.
It seems these things are put together by limp wristed folk......never trust the work of a sparky with a limp handshake.
Offline RAPo
« Reply #12377 on: August 13, 2023, 10:12:26 am »
A Zeeweii Dso3d12.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #12378 on: August 13, 2023, 11:44:19 am »
Kingst LA2016 from AliExpress for $116.
Works for my budget, skill. Software runs on my linux laptop as well.
Congratulations! I have been using the Kingst for several years. Albeit limited, it works very well for my purposes.
The following users thanked this post: RAPo, porter
Online PlainName
  • Country: va
« Reply #12379 on: August 13, 2023, 04:13:43 pm »
RJ45 crimp tool.
Already got one but I acquired that before the recent trend for through-hole RJ45 plugs (as shown in the pix) so it doesn't cut off the wires like this one. Got fed up of slicing a finger when trying to trim them manually.
There are many of these, hence why I haven't posted a source, ranging from 'gosh, that's a good price' to 'they have to be joking'. I imagine they are all the same and have the same faults - cable stripping is useless, the supplied trimming tool even worse. But they do crimp and cut off the wire ends, which is all I care about. And a bit smaller but still very usable than the traditional style of crimpers.
The following users thanked this post: Smokey
Offline Smokey
  • Not An Expert
« Reply #12380 on: August 14, 2023, 01:51:59 am »
RJ45 crimp tool.
Nice!  that's way better than the "jam the wires in the blind holes and hope they all went in far enough" type.
« Reply #12381 on: August 14, 2023, 03:35:43 am »
A 4th 3d printer  ::) To go with the two Ender3's and CR10S an Ender3 V2, filament dryer, three rolls of filament and a printer tent for $200 aussie pesos ($130 usd)
Car boot exchange at the Supermarket so not dodgy at all  ;D
Offline coppercone2
« Reply #12382 on: August 14, 2023, 03:46:05 am »
1/2 inch brass bolt
To fix a welder ?
for DIY lug attachments for resistance brazing
Offline RAPo
« Reply #12383 on: August 14, 2023, 12:19:52 pm »
My set of Wavetek XT multimeters is now complete with the addition of a DM28XT.
Offline u666sa
  • Country: ru
« Reply #12384 on: August 14, 2023, 06:40:13 pm »
Best 200 Mhz handheld oscilloscope in multimeter format, there are better tablets.
It only cost me 22,247 rubles. Which is $225 todate. This same scope is $309 on U.S. market, plus 6% tax. At that price I wouldn't get it, but this low, $225, yes, I want it, I need it.
The SDS1104X-E I bought in the U.S. for $413 plus 6% tax, people will bring it to me in September. Here it costs over $700.
Thus far, the impressions are good. I like it.
Shipping time is ordered August 8, received today August 14. Shipping from Moscow by Shenzhen Shengtai Tools Mall from Aliexpress.
The following users thanked this post: Mortymore, Martin72
Offline GreyWoolfe
  • NW0LF
« Reply #12385 on: August 14, 2023, 08:32:16 pm »
RJ45 crimp tool.
I picked up a Klein from Home Depot for the pass through RJ-45 connectors.  I could care less about stripping or trimming, I just need it to crimp and cut clean, which it does. I actually like making my own cables now.  Still have my 2000 vintage crimpers, I keep it for nostalgia.  ;D
Offline Bud
« Reply #12386 on: August 14, 2023, 09:17:16 pm »
"I like it" does not cut it on this forum  :D
Have you tested the 200MHz bandwidth claim?
Offline u666sa
  • Country: ru
« Reply #12387 on: August 15, 2023, 02:02:33 am »
I don't have a capability to test that claim. But there are plenty of youtube videos, 380 Mhz seems to be the last usable frequency --
430 Mhz is the frequency at which signal can't be distinguished from noise.
Offline jonovid
    • JONOVID
« Reply #12388 on: August 15, 2023, 06:41:50 am »
some camera accessories for my cheap handycam.
this lot had better quality then I expected.
wide angle lens made with aluminum housing & glass optics.
feels solid in the hand. with twin plastic lens caps.
note- telephoto lens accessories is also available for the same handycam.
mic has its own rechargeable battery in its all plastic housing
with switchable modes. usb cable.
cons- cheap all plastic camera mounting ring on mic.
The following users thanked this post: Ed.Kloonk
Offline AndyBeez
  • Country: nu
« Reply #12389 on: August 15, 2023, 02:51:05 pm »
Set of mobile phone sized screwdriver heads. Including 1mm torx. Bargain at under ten Brit pounds. Somehow I feel that screws are just getting smaller and smaller. Said Alice...
The following users thanked this post: Jeff eelcr
Online kripton2035
« Reply #12390 on: August 15, 2023, 05:22:01 pm »
not sure any of these heads under 3mm will last very long ... you need very high quality bits on these small size.
Online kripton2035
« Reply #12391 on: August 15, 2023, 05:24:08 pm »
bought a festool TCL6 charger today, as my 8 years TCL3 charger suddenly died today.
opened it hopping to fix it. alas ... the whole thing is under a black resin... absolutely not fixable, even for some capacitor or mosfet dead.
Offline RAPo
« Reply #12392 on: August 15, 2023, 07:47:55 pm »
5 times an hk3258 1Hz led blinker
Offline armandine2
« Reply #12393 on: August 17, 2023, 01:17:10 pm »
Metcal SMTC-114 on order, in lieu of a Pace hot air station  :palm:
Funny, the things you have the hardest time parting with are the things you need the least - Bob Dylan
Offline RAPo
« Reply #12394 on: August 18, 2023, 03:48:42 pm »
Finally, a Roxon KS2 multifunctional tool with a large pair of scissors arrived.
Offline gamalot
  • Correct my English
    • Youtube
« Reply #12395 on: August 21, 2023, 11:04:01 am »
HP E4418A + Agilent 11730A + Keysight N8481A  :popcorn:
Offline DiTBho
« Reply #12396 on: August 21, 2023, 01:55:39 pm »
no dobut yours has a better Mhz/Price ratio, however, considering quality and reliability, with only 60Mhz of bandwidth, the best handheld oscilloscope in multimeter format is the MP720015 EU-UK  :D
(edit: attached datasheet and user manual)
Bought one for my "mobile lab".
Paid 300 euro shipped with all the accessories and the DSO in a sturdy metal suitcase.
« Last Edit: August 21, 2023, 02:00:33 pm by DiTBho »
The opposite of courage is not cowardice, it is conformity. Even a dead fish can go with the flow
Online PlainName
  • Country: va
« Reply #12397 on: August 21, 2023, 05:36:36 pm »
the MP720015 EU-UK
I would want a huge discount to put up with that colour  >:D
The following users thanked this post: DiTBho
« Reply #12398 on: August 22, 2023, 11:50:09 am »
RJ45 crimp tool.
Ordered one of them as I have a small lot of cables to do with a new 10Gig run to the shed (buying that one already made, gel filled & shielded 6A) but then 2.5Gig so moving from 5e to 6 mainly. Locally patch cables or mid length ones are not a thing so a roll of CAT6 is coming too.
Also added a tester because it sounds good 'in theory' TDR and NCV are a few things I don't have and if they work then it is still a fairly cheap tester. None of the cheaper ones appealed and the Klein tools stuff is a chunk more for less locally. https://www.aliexpress.com/item/1005004831870128.html?https://www.aliexpress.com/item/1005004831870128.html?
Online PlainName
  • Country: va
« Reply #12399 on: August 22, 2023, 01:23:03 pm »
The TDR and POE features would sell it to me (assuming they worked!) had I not already got a Fluke.
