Author Topic: What did you buy today? Post your latest purchase!  (Read 2853336 times)
gamalot and 4 Guests are viewing this topic.
Offline tautech
« Reply #75 on: June 04, 2015, 09:17:46 pm »
Does getting my first analog oscilloscope and The Art Of Electronics 3rd ed count? Just upgrading my home lab a bit this summer..
Pics?
Offline signalTopic starter
    • Personal Website
« Reply #76 on: June 05, 2015, 02:06:15 am »
Laboratory Manual for The Art of Electronics
National Instruments myDAQ complete with LabView and MultiSim licenses
    • Personal Website
« Reply #77 on: June 05, 2015, 02:07:10 am »
And also A few Elenco projects, the Resistor Substitution Box and the XP-720K Power Supply.  I also followed some other members advise and picked up some really nice pots and knobs for the power supply and I will be picking up some low ESR high quality caps to use when I build it.
Offline Mr.B
« Reply #78 on: June 05, 2015, 02:35:09 am »
Just ordered today... Recommendation by tautech.
http://www.smarttweezers.com/
Offline Halcyon
  • Global Moderator
« Reply #79 on: June 05, 2015, 02:36:34 am »
Not so much a purchase, rather a rescue from the garbage believe it or not!
2x 24-port Cisco Catalyst 3750 v2 POE Switches complete with a set of stack cables and 4x 1Gbit multimode fibre GBIC modules. Both work perfectly, just erase the config and off they went.
The copper ports are only 10/100 but still more than adequate for most purposes (including HD video).
    • Personal Website
« Reply #80 on: June 05, 2015, 02:54:09 am »
Wow, I can't believe someone would toss a 3750G with PoE.  Great catch, I would be returning to that dump for sure!
Offline Halcyon
  • Global Moderator
« Reply #81 on: June 05, 2015, 03:07:11 am »
It's fairly common among big enterprise and Government departments. When they do a network refresh, especially if they've sat inside a protected network, rather than being erased and reused or sold, they just bin or shred them (literally). They don't care. The cost of disposal is factored into their budgets.
It pays to be friendly with IT guys :-)
« Last Edit: June 05, 2015, 03:12:05 am by Halcyon »
Offline Mr.B
« Reply #82 on: June 05, 2015, 03:34:45 am »
Not just Big Enterprise and Govt.
We are fairly small by those standards and we simply destroy the equipment and bin it.
It costs too much to erase securely and then go to the trouble of selling, or even giving it away.
Desktops and Laptops are way more hassle than things like switching equipment, but we just do the lot.
Offline lapm
« Reply #83 on: June 05, 2015, 06:23:45 am »
Pics?
No pictures yet sorry, need to clear out space for my corner for it first. After that i will consider posting in home-lab picture thread.. But its Hitachi V665 60MHz, 2 Ch.. Arrived this morning and had it run throw usual tests, passed all with flying colors. Had to buy probes separately, so had to calibrate those as well.. Not bad priced considering i live in Finland where everything is usually expensive. Old piece of gear, but still fully working.
Electronics, Linux, Programming, Science... im interested all of it...
Offline lincoln
« Reply #84 on: June 05, 2015, 08:00:27 am »
A copy of my first o-scope, with out the cart though:
Offline smjcuk
« Reply #85 on: June 05, 2015, 12:32:50 pm »
Nice! Proper scope. Can we get some teardown photos please - the older Tek stuff is marvelous inside.
Offline Circuitous
    • Corgi-Tronics
« Reply #86 on: June 05, 2015, 01:36:50 pm »
Those are great.   I also got the curved tips,  which make it a lot easier to pick up and place SMDs for me.
I did a short video on it,  as part of a series on tweezer LCRs.
One nice feature is being able to change the display to be lefthanded.
    • Personal Website
« Reply #87 on: June 05, 2015, 03:59:43 pm »
Menda 6oz ESD safe alcohol dispenser.  I use to use these in the military, you basically can just dip your acid brush in them and clean away at your PCB.  Isopropyl Alcohol is what I plan to put in mine.  A bit pricy but good quality:
Offline lincoln
« Reply #88 on: June 05, 2015, 05:05:12 pm »
I will see what I can do, It definitely needs some cleaning inside.
Offline tautech
« Reply #89 on: June 05, 2015, 06:36:57 pm »
Several links to cleaning methods used in this thread:
https://www.eevblog.com/forum/repair/vintageclassic-renovation-techniques/msg592523/#msg592523
For you OLD Tek fans:
https://www.eevblog.com/forum/testgear/vintage-tek-restoration-pictures-by-martin/
Offline nanofrog
« Reply #90 on: June 05, 2015, 07:36:17 pm »
FWIW, I found that Kleen Strip's SDX Denatured Alcohol is a cheaper alternative (~50/50 mix of ethanol & methanol; denaturing agent, MIBK, is also a solvent). Locally, it runs $15.98 per gallon in Home Depot.
Offline Deathwish
  • Country: wales
« Reply #91 on: June 05, 2015, 08:05:44 pm »
Electrons are typically male, always looking for any hole to get into.
trying to strangle someone who talks out of their rectal cavity will fail, they can still breath.
God hates North Wales, he has put my home address on the blacklist of all couriers with instructions to divert all parcels.
Offline BFX
  • Country: sk
« Reply #92 on: June 07, 2015, 11:54:28 am »
Something new to lab  8)
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #93 on: June 07, 2015, 01:13:34 pm »
Nice scope but the Hardinge HLVH in the background is even nicer. Mine has made many video appearances on my channel below :)
Offline Mr.B
« Reply #94 on: June 10, 2015, 09:05:48 pm »
Smart Tweezers arrived yesterday afternoon.
Accurate, fast and very easy to use.
Very pleased with them.
Offline mtdoc
« Reply #95 on: June 11, 2015, 03:09:38 am »
After missing the first round of closures, my local "Shack" got put on the close list a couple of months ago.  I ponied up for one of their component cases but had to wait until it had emptied out before picking it up. They called me yesterday so I stopped by to get it .  That thing is heavy!  Definitely made to last.
While there, with everything 70-80% off, I couldn't help buy some uneeded things, including 2 of their "top of the line" multimeters.  6000 count true RMS and PC interface for $21 each (marked down from $70).  The last thing I need is another multimeter but for the price I couldn't resist.  One will probably end up as a Xmas present for my 9 year old son, but the other? --  I haven't decided yet.
    • Personal Website
« Reply #96 on: June 11, 2015, 03:13:05 am »
So how much did the shack let that thing go for?  Any idea on how to find out which ones are closing, what are the tell-tale signs?
Offline mtdoc
« Reply #97 on: June 11, 2015, 03:32:33 am »
$175 :-[  I hemmed and hawed about the price but I do think it is worth it. It is one of those lasts-a-lifetime pieces of gear - likely passed on to my kids.
Tell-tale signs?  Well, in the case of the store here a large sign appeared outside saying  "Store Closing".
I've been stopping by once a week or so since they announced it. Each week or so new signs show up on the windows -- 30-50% off then 40-60% and so on until now 70-80%.
I've picked up a few things along the way as the stock was whittled away.  The exact close day is top secret but the manager told me that they'll but a sign up that says "last 10 days" when the time comes.
I've got my eye on a few more things if prices drop more, I'd love to pick up a boat load of rechargable NiMH batteries. They've go a ton of them in stock but at 70% off their still a bit pricey.
Offline Carl_Smith
    • MegaMicroWatt - Carl Smith's Blog
« Reply #98 on: June 11, 2015, 04:09:32 am »
The manager at my local Radio Shack says they will be open until the end of the month.  There isn't much left but a ton of batteries and headphones (mostly ear buds).  Oh, and HDMI cables.  A wall full of HDMI cables.  He also said that for their last 10 days they plan to have a bag sale.  Buy a bag for $10 and stuff it full of anything that fits.   I'm wondering what will be left and if I should stuff the bag with things for myself or things I can unload on eBay like cell phone cases and phone batteries.  I'm thinking I'll have to be there on the first day of the 10 days to get anything good.
With as many ear bud headphones as I have had go bad, the wire breaking at the plug, I should fill a bag for myself and quit spending time on re-soldering the plugs.
As for my purchases, last time I got a crappy clip on smartphone microscope that doesn't even work.  Shows an image about the size of a dime in the middle of my 5 inch phone screen.   Previous trip I picked up 4 rolls of kynar wire wrap wire and a tube of somewhat conductive ink for less than $10.
Offline smjcuk
« Reply #99 on: June 11, 2015, 09:33:46 pm »
I just finished "Calculus For the Practical Man" after a year so to reward myself with more toil, I bought Feynman Lectures on Physics volume 1, some 0.5mm Rotring leads and The Songs of Distant Earth (CD version) by Mike Oldfield.
The most fun you can have for £30 these days.
