Author Topic: What did you buy today? Post your latest purchase!  (Read 2853373 times)
Offline Supercharged
« Reply #800 on: January 16, 2016, 08:38:06 pm »
yes the equivalent of 6 US dollars (The seller is moving and wanted it gone)
Science is about what is, engeneering is about what can be.
-Neil Armstrong
Online McBryce
« Reply #801 on: January 16, 2016, 09:28:44 pm »
Plus the six dollars a month in rent it cost you bcause it occupies a full square meter of you apartment? :D
Really nice device though.
McBryce.
Offline rrinker
« Reply #802 on: January 17, 2016, 01:00:13 am »
McBryce.
 I was going to say the electricity use but that's probably way more than $6/mo.
Indeed, nifty old classic. The picture almost makes it look like the trace is sweeping around the circle like a radar screen.
« Reply #803 on: January 17, 2016, 03:24:15 pm »
McBryce.
You won't need a Heater anymore tough
Ps: radar screen would be cool but it has a great, normal display:
-Neil Armstrong
Offline Addicted2AnalogTek
« Reply #804 on: January 17, 2016, 04:15:55 pm »
WOW!!!  That is beautifully sharp for a vintage CRT!    I can only hope that I manage to land a vintage tube-type scope with as crisp of a display as that...
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
« Reply #805 on: January 17, 2016, 06:09:00 pm »
the wave is from a Wandel&Goltermann?  :)
@Addicted: If you need a extremly sharp vintage screen look for a 565 or 502A
565
greetings
Martin
« Last Edit: January 17, 2016, 06:17:15 pm by Martin.M »
Offline AF6LJ
« Reply #806 on: January 18, 2016, 03:11:40 pm »
Way Nice. :)
Sue AF6LJ
Offline Martin.M
  • in Tek we trust
« Reply #807 on: January 18, 2016, 04:43:57 pm »
I have found a C Tester in the bay  8)
Offline rrinker
« Reply #808 on: January 18, 2016, 04:49:09 pm »
 Won me a Fluke 45 on eBay, after seeing a bunch go for way too much ($300USD +). This one I got for $150, and is guaranteed working, pictures show a nice bright display, and it comes with the power cord and probes. Who knows if they are the actual Fluke probes, but one can never have too many probes laying around. Pictures when I get it, shipping delayed one day by the Federal holiday in the US today, bummer.
 Guess I really need to get started on building my bench so I have a place to put this stuff.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #809 on: January 19, 2016, 03:01:47 am »
Go vertical - collecting it gets addicting, and stacking is space efficient.   :-+
And Martin, that Tek 565 is a thing of beauty! It's been said before but bears repeating - your restorations are nothing short of amazing!
-Pat
Offline rrinker
« Reply #810 on: January 19, 2016, 03:14:03 am »
 It's no so much as stacking as literally having no place to use this stuff. The 8012A is still packed up from moving, almost 2 years ago. My new Siglent 1102 is sitting on the floor. When I say I need to get starting on building a bench - it's not adding bench space, it's making a bench in the first place. I have a good idea of what I want to do, even drew it up, at least the base tables, in CAD. I need to take a weekend and just build the darn thing, then I can set u0 my equipment and actually start working on some projects.
And indeed, that 565 is a classic and absolutely art-like. I want to touch all those knobs and just fiddle, it's equipment porn at its finest. Perhaps a classic analog scope should be my next acquisition - though I do need a power supply or two.
Offline miguelvp
« Reply #811 on: January 19, 2016, 05:55:49 am »
Pre ordered an Intel RealSense Camera waiting for their upcoming Android support so I'm in no hurry until that is available.
http://click.intel.com/intel-realsense-developer-kit-r200.html
What is it? Laser IR time of flight with visual as well. It can digitize 3D up to 4 meters
Specifications
- Longer range** (up to 3-4 meters indoors, longer range outdoors)
- Depth/IR: 640x480 resolution at 60fps
- RGB: 1080p at 30fps - USB 3.0 required
- Developer Kit Dimensions: 130mm x 20mm x 7mm
- Supports Microsoft Windows* 8.1 (64-bit mode), Android* support coming soon.
More info:
https://software.intel.com/en-us/articles/realsense-r200-camera
So pretty much a beefier Kinect with supporting SDK.
Offline miguelvp
« Reply #812 on: January 19, 2016, 08:01:02 am »
Yes, it's not for thermal imaging, it's for 3D scanning computing time of flight of the NIR laser light pulse bouncing back to the NIR dual cameras.
Edit: adding picture:
Edit: and it's stereoscopic 3D scanning btw.
Edit again: the middle image is fake, has to be. I did modify plenty of cameras to filter out visible and only seeing NIR and that black shirt should be totally white.
« Last Edit: January 19, 2016, 08:44:36 am by miguelvp »
Offline miguelvp
« Reply #813 on: January 19, 2016, 10:10:32 am »
It's more like the ZCam that Microsoft acquired 7 years ago to do their current kinect generation:
https://en.wikipedia.org/wiki/ZCam
But on stereo and using laser pulsing for more accuracy.
Offline artag
« Reply #814 on: January 19, 2016, 02:10:54 pm »
Not so much bought as arrived ..
A couple of months ago I saw there were an unusual number of a6302 current probes on ebay. They're usually a bit rare and expensive, more often you see the amplifier modules. I scored one of the cheapest ones at about £70 but had no amplifier .. and they'd suddenly become difficult to find. No doubt because of all the probes !
Then a few days ago I saw an am503/tm501, again about £70. To my surprise, nobody else bid .. and it arrived today. So finally I can test the probe .. and the combination works!  I've been slowly accumulating current probes recently, adding various AC and DC varieties but I've been after one of these good ones for a while. Very pleased (and relieved I haven't got two items to fix!).
Offline Zbig
« Reply #815 on: January 19, 2016, 04:33:29 pm »
I got myself a Wacom Bamboo Spark. It's a folio-type digitizing notepad. You write on a real paper with real ink using a special electronics-filled ball pen that otherwise looks and feels ordinary. Each pen stroke gets recorded in internal memory for later transfer using Bluetooth LE. Just got it yesterday but I hope it to prove very handy for quick ideas, sketches, EEVbLog forum posts, etc. Think DaveCad on steroids :) Now, if only I could handwrite anymore...
Offline mtdoc
« Reply #816 on: January 19, 2016, 08:54:04 pm »
Sounds like a score!.  I've had poor luck recently with my attempts to begin accumulating some Tek series 500 modules. On 2 of the 5 so far have been functional.
I saw this TM502/AM503b/A6302 current probe combo today.  A good deal IF it is functional. I'm too gun shy now to take the risk.
Offline 0xdeadbeef
« Reply #817 on: January 19, 2016, 08:57:21 pm »
Help me, I'm addicted...
Offline krivx
  • Country: ie
« Reply #818 on: January 19, 2016, 09:05:28 pm »
are these really any use for measure capacitors in-circuit like that?
Offline 0xdeadbeef
« Reply #819 on: January 19, 2016, 09:14:44 pm »
With the obvious restrictions of course. Then again, admittedly this was mainly for the better looks ;)
Measuring tiny little things on the table doesn't look so impressive - still it's what I'll use it for most of the time.
Offline artag
« Reply #820 on: January 19, 2016, 09:19:53 pm »
It does say 'For parts or not working'.
But yes, definitely a newer and better deal than mine if you can get it working without too much trouble.
I did feel happier going for a 503 rather than an 503A or 503B - although they're not as nice, comments elsewhere on this board suggested they might be easier to repair (if necessary).
Offline Richard Crowley
  • KJ7YLK
« Reply #821 on: January 19, 2016, 10:15:39 pm »
I just got a couple of Tek TM-500 plug-in power supply modules. PS501-1 and a PS501-2
And I got a PC board holder that looks reasonably nice...
http://www.amazon.com/gp/product/B00Q2TTQEE
And I have one of those Smart Tweezers on its way.
Actually the high-price one like @0xdeadbeef got, plus a cheap knock-off for comparison.
« Last Edit: January 19, 2016, 10:26:01 pm by Richard Crowley »
Offline Zeecue
« Reply #822 on: January 19, 2016, 11:04:57 pm »
I got my Rigol DS1054Z today, and already used the online keygen, for the additional bandwidth, seems like a really nice little scope, with 4 channels. And so much faster to set up than the PC based scope I'm used to at work(automotive).
I also got a free Uni-T DMM with the Rigol, a small handy model, perfect for car fuse checking and such things.
And ordered some bnc to banana adapters, so I can use the original break out cables with my scope, and a hand full of BNC end plugs, to protect the unused ports from dirt.
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #823 on: January 19, 2016, 11:19:30 pm »
Rigol DSA815-TG.  :clap:
Offline 0xdeadbeef
« Reply #824 on: January 19, 2016, 11:40:45 pm »
This model has 0.25V mode, which is lower than Vf of a silicon PN junction or even a schottky junction.
Trust me, this thing worths every penny if you work with lots of SMD parts.
PS. There are some minor firmware bugs that should not be there considering it is a $400 device, but no big deals at all.
Admittedly, this is only the slightly lower end "LCR Reader", not the ST5. Then again, the diode tester is not that useful anyway and this costs only half of the ST5 for only slightly lesser specs.
For comparison of models:
http://www.smarttweezers.us/LCR-Reader-ST-comparison.pdf
