Author Topic: What did you buy today? Post your latest purchase!  (Read 5271543 times)
0 Members and 230 Guests are viewing this topic.
Offline Addicted2AnalogTek
« Reply #875 on: January 26, 2016, 02:43:49 am »
There wasn't much wiggle room towards the back or front of the scope in the packaging, so my guess is they pre-pressed the foam over the knobs.  I can't help but wonder if they would have bothered to do so had I not asked.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #876 on: January 26, 2016, 02:45:21 am »
I'll go with 'Probably Not' for $400, Alex...
-Pat
Offline Richard Crowley
  • KJ7YLK
« Reply #877 on: January 26, 2016, 06:33:41 am »
I just got one of my Kickstarter "rewards", an Nscope.  It is a small PC board that plugs into the end of a standard plug-in "breadboard"  It connects to your computer via USB and provides + and -5V to the breadboard power rails. It is a signal generator for a couple of channels, and a 4-channel oscilloscope. With open-source API so you can code your own interface, etc.  Pretty cool, IMHO.  I can't wait to play with it when I get home from work tomorrow.
Offline MrSlack
« Reply #878 on: January 26, 2016, 06:39:21 am »
I'd blow that up or melt it within an hour :)
Wire and fire school of thinking here :)
Offline Brumby
« Reply #879 on: January 26, 2016, 07:34:40 am »
Very nice.  Compact and useful, it seems.
Please let us know what you think of it.
Offline mtdoc
« Reply #880 on: January 26, 2016, 08:04:53 am »
4 channels of input is nice. Too bad bandwidth is not higher. Still, looks very useful. Software quality will be key.
Offline MrSlack
« Reply #881 on: January 26, 2016, 09:49:52 am »
You can use sampling to increase the bandwidth even if it's cheating a bit :)
Offline MrSlack
« Reply #882 on: January 26, 2016, 10:21:40 pm »
2.5 litres of 99.7% pure isopropyl alcohol.
http://uk.rs-online.com/web/p/precision-cleaners-degreasers/0448180/
Yum :)
Offline bitseeker
« Reply #883 on: January 27, 2016, 01:43:28 am »
Racal Dana 1992 Universal Counter. Looks like it's one of the military contract models with high-stability OCXO (option 04E).  :-+ I'll know for sure when it arrives and I "take it apaaart". It probably also needs a recapping.
Offline Len
« Reply #884 on: January 27, 2016, 04:29:23 am »
750 ml of 13% ethanol. Red.
DIY Eurorack Synth: https://lenp.net/synth/
Offline tautech
« Reply #885 on: January 27, 2016, 07:09:07 am »
IMDES MINI CONDENS-IT vapor phase reflow soldering oven + 1l of galden LS230. My IR oven is too uneven for larger boards, will see how it performs when it arrives. In theory should be awesome results.
New thread? or an update to this one:
https://www.eevblog.com/forum/projects/vapour-phase-soldering/
Offline mtdoc
« Reply #886 on: January 27, 2016, 07:25:08 am »
 :-+  As the saying goes - "Better a bottle in front of me than a frontal lobotomy..."
Online DimitriP
« Reply #887 on: January 31, 2016, 12:10:20 am »
From 5300 miles away and two weeks later my silicone cable from Antex arrived!!!
Offline Muxr
« Reply #888 on: January 31, 2016, 12:33:22 am »
'nother scope:
Arrived yesterday. Loving it so far.
Offline MrSlack
« Reply #889 on: January 31, 2016, 09:46:27 am »
Wera socket set, trolley jack, axle stands, stinking great big can of WD40, full set of brake discs and pads for my Fiat. Cheaper to buy the tools and do it myself than all the local garages. Plus now I own lots of nice tools :)
Offline crazyjim30
« Reply #890 on: February 01, 2016, 12:47:01 am »
Components:
Resistors, capacitors, inductors, and diodes. Some jumper wires as well. More when my next paycheck arrives.
Sent from my SM-G900V using Tapatalk
Offline VK5RC
« Reply #891 on: February 01, 2016, 09:48:27 am »
An fleabay purchase marked as a HP5253B and doesn't power on. I got the 5245L as well and with one fuse later it lives!
Some work on those BNC, using robrenz's techniques, a bit of panel cleaning, one loose capacitor (the bakelite base cracked- don't make them like they used to) and hopefully it will look pretty good.
Offline MrSlack
« Reply #892 on: February 01, 2016, 10:09:25 am »
That HP5245L is a thing of beauty.
Offline Richard Head
« Reply #893 on: February 01, 2016, 10:15:39 am »
That R&S scope looks like an awesome unit. I wonder what it set you back?
Offline AF6LJ
« Reply #894 on: February 01, 2016, 03:14:20 pm »
Nice looking 5245  :-+ :-+
Sue AF6LJ
Offline Cubdriver
  • Nixie addict
« Reply #895 on: February 01, 2016, 03:59:28 pm »
Buy a plug-in, get a free frequency counter to hold it.  Sweet!   :-+
-Pat
Offline BloodyCactus
    • Kråketær
« Reply #896 on: February 01, 2016, 07:41:41 pm »
NTS-200 time server! works. I'm locked out tho, and cant find a null modem cable (so I got one coming from amazon) for good old rs232.
if I can get into the console I can reset whatever needs resetting...
Works like a charm, got 4 satellites tracked. now I need to figure how I'm going to run the cable to the outside :/ doh!
-- Aussie living in the USA --
Offline MrSlack
« Reply #897 on: February 01, 2016, 09:13:58 pm »
We have a similar device. The antenna went through a hole literally straight up from the machine room and through the subroof and roof. Bathroom caulking was used to seal it up. No leaks (yet) :)
Offline McBryce
« Reply #898 on: February 02, 2016, 09:41:38 am »
My Pomona 6341 probes just arrived. Wow, I could open a Tattoo Studio with the points on the end of these!
My DER EE DE-5000 LCR meter also arrived yesterday, having spent the last five weeks relaxing in the local Customs clearance office.
McBryce.
Offline BFX
  • Country: sk
« Reply #899 on: February 02, 2016, 11:46:22 am »
Kikusui 4502 and HV probe  8)
