Author Topic: What did you buy today? Post your latest purchase!  (Read 2842483 times)
Offline BFX
  • Country: sk
« Reply #1075 on: March 25, 2016, 07:46:33 pm »
Nice Agilent 4263B  8)
Offline Circuitous
    • Corgi-Tronics
« Reply #1076 on: March 25, 2016, 10:14:11 pm »
@BFX  Nice LCR, that has great specs.  Something like that is on my list, but they aren't cheap!
Offline rx8pilot
« Reply #1077 on: March 25, 2016, 10:25:00 pm »
I would love to have one of those on my bench. Nice.
Sent from my horrible mobile....
Offline BFX
  • Country: sk
« Reply #1078 on: March 26, 2016, 07:45:43 am »
Yes it's wasn't cheap but in this case price 950EUR was acceptable for me because it's looks in good condition.
Offline Hobby73
« Reply #1079 on: March 27, 2016, 03:13:11 am »
Picoscope 2205 25mhz USB oscilloscope.  Purchased "pre-owned" on eBay at a nice discount.
Will use for checking power supplies used with low power DC microprocessors (Raspberry Pi) and microcontrollers (Arduino).
« Last Edit: March 27, 2016, 06:25:16 am by Hobby73 »
Offline TiN
  • Country: ua
    • xDevs.com
« Reply #1080 on: March 27, 2016, 03:15:59 am »
Agilent 4142B (HPAK version of Keithley 4200SCS), should be on it's way to me today or tomorrow :)
Offline DiodomanX
« Reply #1081 on: March 27, 2016, 04:23:37 am »
I get it for close to nothing, and i will use the DASU as bench DMM, at least for a while.
Enviado desde mi XT1563 mediante Tapatalk
Offline rx8pilot
« Reply #1082 on: March 27, 2016, 04:51:39 am »
HP 6624A 4 channel Linear PSU. $65. Ch 4 needs some help, but I think it will be an easy fix.
This is going in my growing automated QC system rack.
« Reply #1083 on: March 27, 2016, 09:22:16 am »
Bought one of these then joined the Feel Tech thread over in Test Equipment.
« Last Edit: July 19, 2017, 10:40:50 am by med6753 »
Offline Sbampato12
« Reply #1084 on: March 28, 2016, 04:39:38 pm »
Bought this one, received today, for about US$50,00.
Sold as working, unfortunatelly arrived non working. Will talk with the seller.
Offline McBryce
« Reply #1085 on: March 28, 2016, 08:03:50 pm »
It may just be a connector that has shaken loose in the post. I'd check it first before you give the seller a hard time.
McBryce.
« Last Edit: March 29, 2016, 09:12:27 pm by McBryce »
Offline Sbampato12
« Reply #1086 on: March 29, 2016, 08:55:44 pm »
It was only the display intensity that was turned all the way down. But it is located in the rear of the equipment, so I took some time to realize.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #1087 on: March 29, 2016, 10:48:32 pm »
Glad to hear it was something simple and easily corrected!   :-+  Doubtless a huge relief to you as well.
-Pat
Offline AF6LJ
« Reply #1088 on: March 29, 2016, 10:48:56 pm »
Glad to hear you have it working now.  :-+ :-+
Sue AF6LJ
Offline mojoe
« Reply #1089 on: March 30, 2016, 02:30:22 am »
Traded for an HP 3456A. Stuck buttons making the display read crazy. Before I started pressing buttons, the display looked normal, so there is hope that there isn't much wrong with this. I need to take apart the front panel to clean and repair all the switches. I'm suffering thorough the flu, so I don't feel like doing too much right now.
The 3456A is quite deep, so finding a place for it will be a challenge. However, it will be nice to have another 6.5 digit meter to compare with my 3457A which was recently calibrated.
Offline VK5RC
« Reply #1090 on: March 30, 2016, 08:06:10 am »
re the buttons on a 3456A did you see the post about the stuck enter button ? https://www.eevblog.com/forum/repair/hp-5335a-non-working-enter-key/
There is also a link to a video and some other useful tips in that post.
I have pulled apart my 3456A to fix some non-detenting (but still working buttons) and found some of the metal strips floating around the inside and some missing, I have just bought some spring steel strip to try to repair, no luck so far with a bit of steel tape measure (too stiff) nor stiff plastic. I bought 0.05mm thick strip (the same thickness as the springs)
Offline mojoe
« Reply #1091 on: March 30, 2016, 09:42:41 am »
Yes, I had bookmarked that thread for later. Thanks.
Offline Sbampato12
« Reply #1092 on: March 30, 2016, 02:17:29 pm »
-Pat
Sure I felt a little dumb after that, but yes, a relief!  :-+ tnks!
Offline Cubdriver
  • Nixie addict
« Reply #1093 on: March 30, 2016, 03:17:37 pm »
Who would think to look for an intensity control on the rear panel?  I doubt I would.  (Well, NOW I might, but prior to reading this...)
-Pat
Offline Sbampato12
« Reply #1094 on: March 30, 2016, 05:28:38 pm »
-Pat
At least it isn't only me.... :)
Offline wkb
« Reply #1095 on: March 30, 2016, 05:50:38 pm »
-Pat
Hehe... I had one of these LA, albeit the monochrome screen version.  It had me confused on occasion.
BTW: have you paid close attention to how this 'color' CRT works..?  <teaser question>
Offline TheSteve
  • Living the Dream
« Reply #1096 on: March 30, 2016, 06:45:12 pm »
Agilent 6553A 0-35 volt 0-15 amp supply for $70.00 shipped - powers on, maybe works, maybe doesn't. I will only know for sure when it arrives.
« Last Edit: April 13, 2016, 04:35:51 am by TheSteve »
VE7FM
Offline rx8pilot
« Reply #1097 on: March 30, 2016, 07:17:35 pm »
Agilent 6553A 0-35 volt 0-15 amp supply for $60.00 shipped - powers on, maybe works, maybe doesn't. I will only know for sure when it arrives.
I have two of the 6653A's (don't know the difference, but they are nearly the same). Daily hard use, no issues. Love 'em. $60 shipped is about as good as it gets. I think mine were around $200-ish.
Offline Cubdriver
  • Nixie addict
« Reply #1098 on: March 31, 2016, 04:05:32 am »
Sweet!  Nice to see that someone here got that power supply.  I was planning to bid on it, but got caught up in life and was out and about when it ended.
-Pat
Offline Vgkid
« Reply #1099 on: March 31, 2016, 04:57:08 am »
Nice, I still need to get back to troubleshooting mine. It is working(not correctly) but in pieces.
