Poll
0-2000
7 (16.7%)
2k-4k
5 (11.9%)
4k-8k
15 (35.7%)
8k-16k
8 (19%)
7 (16.7%)
Total Members Voted: 39
Author Topic: Handheld meter robustness testing  (Read 1184580 times)
Offline exe
  • self-educated hobbyist
« Reply #1975 on: October 28, 2017, 12:26:28 am »
There's this:
I know about it, it's horrible (imho). There are reviews on youtube. But it is not even autoranging... Although, I can't name anything better for the price.
Online joeqsmithTopic starter
« Reply #1976 on: October 28, 2017, 01:11:54 am »
I've had a few people ask me about the CEM DT-9989.   A member here was posting about their bad luck trying to buy one.  UNI-T has something as well but seems again that I have not seen anyone who thought it was useful.
I have a need from time to time for a small battery powered scope and ended up with a couple of old Fluke 97s.  These are basically a meter and scope combined.  They work alright for what they are but there are no parts available for them.
Offline kalel
« Reply #1977 on: October 28, 2017, 02:15:14 am »
The meter I linked above mentions 10 kHz, but can't even DSO138 work with faster signals? Okay, it's not a multimeter... but it is small, cheap, and can work on batteries (I guess). It didn't get too many shining reviews (at least the ones I've seen). Getting the unsoldered version is riskier, as it would be hard to be absolutely sure or prove that there wasn't an issue with soldering the kit together if something doesn't work.
« Last Edit: October 28, 2017, 02:17:32 am by kalel »
Offline bitseeker
« Reply #1978 on: October 28, 2017, 05:55:55 am »
Yeah, looks nice, but only 10kHz? Might as well get one of these:
For $21, DSO150, nice enclosure, assembled, 200kHz. Pair it with a nice, safe, DMM.
Or for $46, get a DSO-112A,  2 MHz, 5 Msps.
« Last Edit: October 28, 2017, 06:04:40 am by bitseeker »
Offline totalnoob
« Reply #1979 on: October 28, 2017, 02:17:45 pm »
Thank you Joe, I will have to look into those.
Paul
« Reply #1980 on: October 28, 2017, 04:12:41 pm »
I've seen a few of these used in videos.   They seem to require an external power source.  Maybe someone makes a case with a battery pack for it.  Then is still is a scope, not a multi-meter.   The UT81 was a bit faster.  When I  was looking for small scope, I thought about getting one but did not see anyone say it was a good investment.
I started a thread on the old  Flukes.  They can't read current or temperature directly and there is no capacitance mode.
https://www.eevblog.com/forum/testgear/old-philips-fluke-97/
Offline bitseeker
« Reply #1981 on: October 28, 2017, 05:54:01 pm »
Yeah, it was just in response to the comments that the ET201 is only 10kHz and rather inadequate as a DMM. So, if a single instrument isn't a deal-breaking requirement, for not much more money, one might be able to do better with separate handhelds for DMM and scope.
The DSO112A has a built-in rechargeable battery. I think I saw it in operation on Marco Reps channel. I'm not that keen on having a touch screen, but the device seemed to show wiggly lines OK. ;D
Anyway, back to the combo handheld scopemeters.
Offline exe
« Reply #1982 on: October 28, 2017, 07:00:29 pm »
There is also Velleman WFS210 for 20 quids discussed in https://www.eevblog.com/forum/testgear/vellerman-wfs210-wireless-oscilloscope-for-only-20-!/ . It's a battery-powered portable wifi oscilloscope. Software seems to be crap, I haven't decided if I want it to buy or not.
For isolated measurements I use my MicSig TO1104, but 1) sometimes I forget to disconnect power 2) it's my main scope, I need one more isolated from it (preferably a tiny device as my bench is small). That's why I asked about options. Also, measurements on the scopes I've seen are imprecise. I mean, I know there is only 8bit ADC, but looks like I get even less steps, even with averaging (firmware issue?).
« Reply #1983 on: October 30, 2017, 04:31:22 pm »
CEM offers an AT-9996 automotive scope meter.  They also have the AT-9995 which  is a 4000 count.  Tach will work with 2-10 cylinder engines.  The dwell supports 2,5,6 & 8 cylinder engines.
Mastech has a MS6230, 2000 count.
Someone did show the internals of the BM-319s with some sort of review.
https://www.eevblog.com/forum/testgear/brymen-bm319s-automotive-dmm-teardown-small-review-tme-supplier-feedback/
Of the ones I have seen, I am leaning towards the CEMs and the Brymen.   CEM does not appear to have the manuals available.
Offline 3db
« Reply #1984 on: October 31, 2017, 12:36:09 pm »
Joe
How would you feel about doing a tour of your lab and,or your Fluke calibrator ?
3DB
« Reply #1985 on: October 31, 2017, 04:27:58 pm »
Joe
3DB
I have a old Fluke 731B reference standard that I show in several videos.  Besides that, I am not sure what you are referring to.  Most of the equipment has been used in various videos.
I ended up picking up an automotive meter to play with.   Don't expect me to unbox it and talk about how great it is for an hour.
https://youtu.be/q_89qoFMivg
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #1986 on: October 31, 2017, 06:05:41 pm »
Joe, good tests - thanks for sharing. At first glance I could confuse it with a Hioki - it has a somewhat close appearance.
The display susceptibility to high voltage could be a coupling between the input terminals and the Holtek IC - they are physically close. As you mentioned, the fact the buttons still beep is revealing the main chipset is still going its merry way - further apart from the input terminals.
The susceptibility to RF/interference is quite bad as well... I would expect automotive meters to be fully wrapped in shielding.
« Reply #1987 on: October 31, 2017, 10:30:00 pm »
Towards the very end, you may have noticed with nothing connected to the meter it would reset.   If you have worked on problems like this, you are aware it may have nothing to do with the inputs.   Maybe they will make a better version down the road.
After seeing the BM235 reset, I am not sure about their automotive products.  In the manual they spec 3V/m.  That's nothing.
Offline bitseeker
« Reply #1988 on: October 31, 2017, 11:01:27 pm »
Oh, thank goodness. :phew:
Offline bitseeker
« Reply #1989 on: October 31, 2017, 11:38:08 pm »
No worries. I knew you wouldn't suddenly change your style. :-+
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #1990 on: October 31, 2017, 11:40:08 pm »
This was an excellent video and a good reminder to people that these types of products can be susceptible to all kinds of external influences. As no real destructive tests were conducted you should probably box this one back up and either make a claim or send it back because it was not as described, If you don't then the seller will not get the message that this practice as well as the meter itself is completely out of order.   >:(
Many thanks for your great efforts, it reminded me of how much I now miss my Suzuki, on a side note a mate came around once and saw that I had one and said "I didn't know you were into bikes", I replied "I'm not really, just hospitals and nurses".   :)
Offline xcube
« Reply #1991 on: November 01, 2017, 02:16:57 pm »
CEM AT-9995 :
Manual
There are some more from CEM
CEM AT-9955:
Manual
CEM AT-9906DIS:
Manual
Nice review on ALL-SUN EM135 Digital Automotive Meter, many thanks for this.
I have a quick look at the teardown picture form BM235, BM257 and BM319.
It seems to me that BM31x will based on BM25x and have a little more shielding when a BM235.
But only your tests will show if it is true.
Offline bitseeker
« Reply #1992 on: November 01, 2017, 06:54:10 pm »
Joe, that engine emulator is awesome!
« Reply #1993 on: November 02, 2017, 12:20:39 am »
I suspect the RPM with the Brymens would be limited to 10K in this application.  The were very responsive as usual.   I ended up providing them the link to the video starting where I had the 869s on the jig.  They can at least watch their little meter reset.   lol.  I may get one but like the Fluke people have been pointing out.  Wonder if it would die like the 87V.
Thanks.  These little projects are what makes electronics such a fun hobby. There is always so many things to learn.  People who are bored with electronics as a hobby must have a really limited skill set.
« Reply #1994 on: November 02, 2017, 12:55:31 am »
Which isn't of much use if you want to tune a chainsaw. <sigh>
There's not much decent available for high RPM engines other than a genuine Husky tacho, but the $$.  ::)
http://www.baileysonline.com/Chainsaw-Parts/Repair-Tools/Tachometers-Ammeter/Husqvarna-502-71-14-01-OEM-Pulse-Engine-Tachometer-502711401.axd
Still, I guess they're are cheaper than these that we used 40 years ago:  ::)
http://www.baileysonline.com/Chainsaw-Parts/Repair-Tools/Tachometers-Ammeter/Oregon-Wireless-Tachometer.axd
« Reply #1995 on: November 02, 2017, 01:38:03 am »
Looks like they may not have read the datasheet.  I think the meter's susceptibility could be improved with some very minor changes.  If I can get it to survive some basic levels without a shield, I'll look into changing the front end.
« Reply #1996 on: November 02, 2017, 01:47:41 am »
I shift around 10,500 and go through over 11,000 running 160MPH or so.   Not to say that chainsaws are not fun.  They most certainly are!!
Nice. We've chatted about drags some time back.
How long have you had the logging Joe ?
BTW, the column for Nitrous is blank.... WTF.  ;D
Offline bitseeker
« Reply #1997 on: November 02, 2017, 04:44:32 am »
Yeah, same goes for those who say they're bored because they're retired. Having to work for a living is my limiting factor!
« Reply #1998 on: November 03, 2017, 01:53:02 am »
We don't all reach for the foil to solve every EMI problem.
https://youtu.be/uuaRUWcrZRk
Offline Crumble
« Reply #1999 on: November 03, 2017, 10:58:40 am »
I may be a rare breed but I love working far too much to retire.  One day that may change.
I love that attitude. However, personally I find that when I'm not working I do tend to loose focus on what to do and how to do it and progress gets slower. I respect you for keeping on doing your thing and doing it thoroughly, keep it up! :-+
