Author Topic: Advice on solder flux/paste  (Read 755 times)
Offline sacentreTopic starter
  • Country: sg
« on: June 20, 2023, 02:53:35 pm »
I've been using these low-cost rosin based soldering fluxes for years (see photos) with the traditional 60/40 solder for general electronics assembly - mostly just hobby kits, occasional repair work and recently some smt assembly etc (I haven't yet tried using solder paste with hot air for soldering ICs).
Since I'm about to order a fresh supply, I thought I'd ask first if anyone had any views about "better" alternatives. I see a huge range of prices  for flux pastes and liquids etc. I'm assuming there's a reason for this and wonder if there's anything to be gained from paying more for a different type or brand.
Right now though I've no idea exactly what advantage a "better" flux would offer since my experience is limited - improved flow? cleaner joints?
Can anyone advise?
TIA
Online David Hess
  • DavidH
Re: Advice on solder flux/paste
« Reply #1 on: June 20, 2023, 04:22:20 pm »
Some work better than others, but there is no way to know which without testing.
Kester's 44 (now 1544?) flux in liquid and paste is excellent but no longer generally available.
The following users thanked this post: sacentre
Offline thm_w
  • Non-expert
« Reply #2 on: June 20, 2023, 09:14:35 pm »
I don't know about "better" but its more convenient to have the paste flux in a syringe. I use either the generic noclean amtech clones or the MG chemicals paste.
https://mgchemicals.com/products/soldering-supplies/soldering-flux/soldering-flux-paste/
https://www.aliexpress.us/item/4000258887808.html
Big clive mixes up his own liquid version with IPA in a little dropper bottle. Thats probably the cheapest liquid option.
Online asmi
« Reply #3 on: June 21, 2023, 03:20:31 pm »
I use this flux: https://www.chipquik.com/store/product_info.php?products_id=310004
Highly recommend, works like charm, and is easy to wash away after soldering!
Offline tooki
« Reply #4 on: June 22, 2023, 06:57:01 pm »
Can anyone advise?
TIA
The Felder flux you show is NOT for electronics! Zinc chloride fluxes are for coarser electrical and mechanical work only. Do not use them on stranded wire.
Offline wraper
  • Country: lv
« Reply #5 on: June 22, 2023, 07:37:18 pm »
Good fluxes for electronics never come in tin jars. Either not good or not suitable for electronics at all.
Offline wraper
  • Country: lv
« Reply #6 on: June 22, 2023, 07:43:05 pm »
https://www.felder.de/products/metal-construction-industry/soft-soldering/fluxes-for-cu-cu-alloys/loetfett-243100501.html
Flux based on zinc chloride and ammonium chloride with pasty consistency for soft soldering of copper and copper alloys for copper pipe installations, radiator construction, plumbing, dip soldering, fitting manufacturing and other solder works.
And even on pipes you still need to wash it off to avoid corrosion. As of electronics, zinc chloride is nearly impossible to wash off entirely as it penetrates PCB substrate.
Offline tooki
« Reply #7 on: June 23, 2023, 08:52:14 am »
Yep. Though they used to! (I still have a tin of Kester 44 from the early 1990s.) :P
