Author Topic: Pick and Place Machine TVM802A / TVM802B  (Read 463873 times)
0 Members and 57 Guests are viewing this topic.
Offline ManuFerHi
Re: Pick and Place Machine TVM802A / TVM802B
« Reply #750 on: December 11, 2017, 06:38:05 am »
Try install Microsoft Visual C++ 2010 Redistributable Package (x64)
https://www.microsoft.com/en-US/download/details.aspx?id=14632
Offline HHaase
« Reply #751 on: December 11, 2017, 01:55:21 pm »
I'll give that a try tonight.   Would be nice to build up a list of requirements for the software,  considering it's not really documented at all.
I'm also waiting on a reply from Qihe to see if they have a hardware/software requirements list.
The other piece of the puzzle that was required was .net framework 3.5
Thankfully that self-identified and was easy to install after making sure the Win10 was fully updated.
Offline HHaase
« Reply #752 on: December 11, 2017, 10:24:40 pm »
Unfortunately adding the C++ redistributable didn't help in my case.   Tried all the versions that are on my main PC (which can open the software), with no success.
Also tried an earlier revision of the surface mount program.  Again, no success.
Waiting on a response from Qihe as well.
I may still end up having to grab a crusty old Win7 machine after all.  Which would be unfortunate as a mini-PC could fit inside the pick and place and give me a real clean result.
-Hans
« Last Edit: December 12, 2017, 12:13:16 am by HHaase »
Offline HHaase
« Reply #753 on: December 12, 2017, 01:39:44 am »
Qihe got me sorted out.   It requires the C++ 2010 Redistributable Package 32bit,  not the x64
You were definitely on the right track there, definitely appreciate it.
Took me a bit to get the vision drivers all sorted out but it's running now.
Also turned off the packet coalescing as well.
-Hans
Offline astropower
  • Country: il
« Reply #754 on: December 14, 2017, 10:01:01 am »
my machine (TVM802A)  is equipped with the Juki nozzles and came with software v3.03
I wonder what the latest changes have been.
Can you share screenshot of the software please ? i have 2.36V
Offline HHaase
« Reply #755 on: December 14, 2017, 07:52:16 pm »
I'll see what I can do,  it's not on my main network.   Any particular feature you'd like to see?
I also have a rev change log that shows the changes in the 3.XX series up to this point.
As I understand it,   there were some hardware changes and older version machines can't run this version software.
The following users thanked this post: astropower
Offline Yellofriend
  • Country: hk
« Reply #756 on: December 28, 2017, 03:01:20 am »
V3.03? Qihe send me the latest one just today and it's according to what they send V2.37.
The RAR pack now has a change log in docx format (I made it PDF)
TVM802C - now with OpenPnP
T962A
The following users thanked this post: whiteshavedchocolate
Offline Yellofriend
  • Country: hk
« Reply #757 on: December 29, 2017, 09:42:49 am »
Quick question: how you do the offset between the fiducials and the parts? Seems I forgot how to do that.
T962A
Offline HHaase
« Reply #758 on: December 31, 2017, 10:53:30 pm »
Apparently there was a hardware change,  and v2.3x would be the branch for the older hardware, while the 3.0x is for the newer hardware.
I haven't pulled mine apart yet to see what's on the inside.
Offline thommo
« Reply #759 on: January 09, 2018, 07:58:12 am »
TVM920 FOR SALE
Melbourne Australia
see comment in TVM920 Forum in the EEVblog
Offline Yellofriend
  • Country: hk
« Reply #760 on: January 16, 2018, 08:13:32 am »
How do you do panels with that PnP?
My PCB has 4 panels, I setup the fidicials on the PCB setup, I enabled the 4 PCBs. The PnP gets parts for 4 PCBs - but places all parts in PCB #1.
What did i do wrong?
T962A
Offline ManuFerHi
« Reply #761 on: January 16, 2018, 08:49:01 am »
There are two types of coordinates, MARK and REAL, mark is the coordinates in cad design pcb software and real is the own pick and places coordinates. In mark field (PCB1, PCB2, etc.) there should always be the same value and you just have to change the real coordinates of p&p. See the picture.
Offline Yellofriend
  • Country: hk
« Reply #762 on: January 16, 2018, 09:15:46 am »
Mhm, in 'Mark' I put the location of the 4 individual fiducials on each of the 4 PCBs, and in REAL I put the real location of on each of the 4 PCBs. Not correct?
T962A
Offline ManuFerHi
« Reply #763 on: January 16, 2018, 10:26:05 am »
Not correct, all mark fields must have same coordinates, and in the real coordinates i see some errors too.
Offline Talia
  • Country: cn
« Reply #764 on: January 17, 2018, 03:59:47 am »
Thanks for share, good information ;D
Offline Yellofriend
  • Country: hk
« Reply #765 on: January 19, 2018, 08:57:26 am »
I still don't get it. Now I set all gerber mark points to PCB1 - now the PnP finds the 4 PCBs in the panel - but now the X has about 5mm offset, even though the real PCB mark points are found very accurate.
T962A
Offline ManuFerHi
« Reply #766 on: January 19, 2018, 09:16:56 am »
Show me the PCB coordinates sheet please.
Offline Yellofriend
  • Country: hk
« Reply #767 on: January 19, 2018, 09:30:47 am »
That's the coordinates according to Gerber.
T962A
Offline ManuFerHi
« Reply #768 on: January 19, 2018, 10:43:38 am »
No this, the PCB tab.
Offline Yellofriend
  • Country: hk
« Reply #769 on: January 19, 2018, 11:14:47 am »
Yes, so what coordinates you mean? That is it the actual placement of the parts.
T962A
Offline ManuFerHi
« Reply #770 on: January 19, 2018, 12:35:13 pm »
This, the coordinates of PCB config tab.
Offline harry4516
    • www.dj0abr.de
« Reply #771 on: February 10, 2018, 05:34:11 pm »
I'm now working with the TVM802B for almost 2 years and have manufactured several thousands of boards.
From my experience the machine is mechanically very well done. Even after 2 years all is working well.
The big problem is the camera which does not detect all parts as good as required.
This could be improved by an additional field in the parts list: an X and Y correction-offset for CAM1.
Maybe the responsible Chinese people take this as an idea for future software releases.
Harry
Offline Conjure
« Reply #772 on: February 24, 2018, 10:53:13 am »
Does anyone have a link to QiHe Vision Mounter 2.37 (or whatever the newest version is)?
I just purchased this machine and I'm wondering (and hoping) it can place SOT-45 with no issues. My design relies heavily on them. Does anyone have experience with SOT-45 using the TVM802?
Thanks!
« Last Edit: February 24, 2018, 11:01:04 am by Conjure »
Offline harry4516
    • www.dj0abr.de
« Reply #773 on: February 24, 2018, 11:25:35 pm »
to be honest, I never have seen SOT-45 case.
Can you please give us the part number of this component.
As a general rule of thumb, the TVM802 can please components in 0603 size quite well.
Its not ideal for smaller components, in which case you will need to correct it under the microscope before soldering.
Offline Conjure
« Reply #774 on: February 26, 2018, 12:57:18 pm »
Apologies, I meant SC-74/SOT-457
https://www.digikey.com/product-detail/en/nexperia-usa-inc/BCM857DS115/1727-4884-1-ND/2531388
