Author Topic: SMD stencil printer  (Read 10338 times)
Offline davorinTopic starter
    • LinkedIn Profile
SMD stencil printer
« on: March 10, 2025, 03:35:51 pm »
Good afternoon (o;
Is someone aware of an affordable manual SMD stencil printer like this model, which isn't currently in stock?
Price range around up to Euro 300 and available in the EU/Germany.
So far I used custom 3d printed PCB holders but stencil was never flat and close to the PCB therefore solder paste was running out under the stencil and smearing the solder pads.
muchas gracias
richard
Online voltsandjolts
Re: SMD stencil printer
« Reply #1 on: March 10, 2025, 04:46:03 pm »
That one you have pictured is in stock A4 size for 230euro
https://portal.multi-circuit-boards.eu/Shop/Index/SMD-Stencil-Printer?Sprache=en
    • LinkedIn Profile
« Reply #2 on: March 10, 2025, 04:52:11 pm »
This is odd....
When I visited this site today in the afternoon it said it will be on stock in around 2 - 3 weeks....
seems the delivery just came in (o;
Thanks for the refresh ;-)
BTW: Any tips for avoiding solder paste squeezing under the stencil? Tried today several times but the paste smeared between all TSSOP and ESP32 pads....
    • LinkedIn Profile
« Reply #3 on: March 10, 2025, 04:57:06 pm »
Ah bugger...
They don't deliver to private person...only companies, schools and the like...
Offline meshtron
« Reply #4 on: March 10, 2025, 07:49:28 pm »
I have this one and have had great luck with it - I always use framed stencils though also.
https://www.alibaba.com/product-detail/ZHENGBANG-High-Precision-Manual-Solder-Paste_1600261854286.html
    • LinkedIn Profile
« Reply #5 on: March 10, 2025, 07:57:40 pm »
The shipping costs are almost that high as the stencil printer itself....
Guess I have to fire up my CAD software and CNC milling machine and just replicate this design....
Online jpanhalt
« Reply #6 on: March 10, 2025, 08:19:48 pm »
1) I went to a SS stencil from OSH stencils: https://www.oshstencils.com/#%20  Shipping of course would probably be prohibitive, but there may be local shops with the same price/quality.  The cost + shipping was very reasonable.
2) I made my own printer (attachment) using an eBay machine/tooling plate (a flat aluminum plate with pre-drilled and tapped holes) and a manual drill press.  You may need to scrape a little to get the fit just right.  I got the tooling plate from an US dealer for about $50.  I'd give a link, but eBay search for old orders is completely messed up.  The shoulder screws were from McMaster.  Of course, your suppliers will be different and metric.
Offline meshtron
« Reply #7 on: March 10, 2025, 08:27:50 pm »
Yeah it's not a terribly complicated device for certain.  If you've got access to a mill and 3D CAD, might well be the right path.  Feel free to DM me if you want any info/pics about how it works (it's not complex but when I'm designing stuff I always love to see a "known good" example).
Offline temperance
« Reply #8 on: March 10, 2025, 08:40:56 pm »
I don't consider that a stencil printer. Something like that is difficult to use for fine pitch components.
There is no tension on the stencil and the stencil is not held flat-without an air gap-onto the PCB. As such the stencil will warp while applying paste and you end squeezing paste between the stencil and the PCB.
Online thm_w
  • Non-expert
« Reply #9 on: March 10, 2025, 09:02:58 pm »
Here is another simple design, not sure which would work better: https://www.aliexpress.com/item/1005008346534843.html
Link to OPs item: https://www.tindie.com/products/khs/mt-sp-a4-manual-stencil-printer/
Offline mon2
« Reply #10 on: March 10, 2025, 09:39:39 pm »
The last shared link to Aliexpress seems more realistic of what these stencil printers should cost. The earlier links are just too high IMHO.
Try contacting Elissa - this company is a manufacturer of such SMT stencil printers. Met them in Shenzhen during my visit to Nepcon (Shenzhen).
Her details:
Website: www.smtwenzhan.com
Skype: smtwenzhan[at]163.com
Tel/Wechat/Whatsapp: +86 13923713803
QQ: 2966592980
Add: 3F. Building D, Lihao Yongda Park, No.20 Dongfang Blvd, Matian, Guangming District, Shenzhen, Guangdong, China 518106
Offline temperance
« Reply #11 on: March 10, 2025, 10:02:49 pm »
That stencil printer is more like a nightmare.
-The arms (round rods) aren't strong enough to deal with the tension placed onto the stencil. The complete assembly will warp. (I have a Neoden printer suffering the same problem.)
-N X, Y and θ adjustments. It will be very difficult to place the stencil over the PCB.
-No proper stencil height adjustement.
Something low cost but not so fancy, capable of delivering the same performance:
https://nl.beta-layout.com/estore/order_product_details.html?wg=17&p=64
A proper stencil printer will cost > 1K.
The lowest cost stencil printer is just a very flat surface and some PCB material like this:
https://nl.beta-layout.com/estore/order_product_details.html?wg=17&p=21
Anything else without proper mechanics is a waste of money.
Online jpanhalt
« Reply #12 on: March 10, 2025, 10:57:46 pm »
I found something similar to what I got.  $45 on eBay,  Unfortunately it's in the US, but the search term may help.  MIC-6 aluminum is flat compared to ordinary rolled aluminum plate.
https://www.ebay.com/itm/125976495186?
Offline prutser
« Reply #13 on: March 11, 2025, 03:24:00 pm »
A colleague of mine made something similar for me using his CNC.
Before I had it, I used to put the PCB "in between" other PCBs and taped the stencil. I was not able  to get the paste applied correctly on 0.25mm QFN pads using this procedure.
Using this kind of stencil printer (both the PCB and the stencil cannot move), I could apply the paste for the QFN properly.
I have only used it for small PCBs where it is easier to keep the stencil flat on the PCB.
Offline jmelson
« Reply #14 on: March 11, 2025, 11:38:29 pm »
I made my own stencil frame, see :  http://pico-systems.com/images/StencilFrame.JPG
and http://pico-systems.com/images/Stencil.JPG  I now have added a hinge to the back to use framed stencils.
Jon
Offline Fire Doger
  • Country: gr
  • Stefanos
« Reply #15 on: March 18, 2025, 12:37:08 pm »
I have made a very similar to this. Vacuum works really well.
The following users thanked this post: thm_w, Kean
Offline khs
« Reply #16 on: October 30, 2025, 03:31:14 pm »
Good news,
the stencil printer is available again.
We learned that there is an astonishing number of ways for laser cutters to ruin the nice brushed surface of the base plate.
Additional: And if the base plate looks neat, it may still be that it is warped, so there is no flat surface for the stencil..
Meanwhile the problems are solved, but every day I have to hear that our stencil printer is an quite easy product to make...  ::)
Offline SMTech
« Reply #17 on: October 30, 2025, 03:43:29 pm »
Good news,
I'd rather gouge out my eyes with a wooden spoon, but you do you.
Offline khs
« Reply #18 on: October 30, 2025, 06:03:50 pm »
An acquaintance of mine once got a compressed air hose shoved right into his eye. His eye survived, but the retina didn't.
So I don't think it's possible to poke your eye out with a wooden spoon. 8)
    • LinkedIn Profile
« Reply #19 on: November 16, 2025, 08:37:20 am »
Well nice that it is on stock again...
But can't order as your web site says: "We solely sell to business customers and public institutions"
And I am not both of them (o;
The following users thanked this post: khs
Online jpanhalt
« Reply #20 on: November 16, 2025, 09:51:54 am »
My experience with solder paste is limited to the one stencil printer shown.  It seems most printers support the board on a flat surface.  That way, as you apply pressure to the board, you don't risk deforming it and forcing paste between the stencil and board in the middle.  The only reason I can imagine for using rails to support the board is if components are on the back side.
Offline Rat_Patrol
« Reply #21 on: November 16, 2025, 04:26:48 pm »
That is what pin support is for.
I 3D print custom holding jigs with supports for each board. They have built in "pin supports" for when you are pasting the top side, and components are already reflowed on the bottom. Same jig, so install is just part of setting up the line for that run.
Offline jmelson
« Reply #22 on: November 17, 2025, 04:12:44 pm »
My fixture (link to pictures in reply # 14) holds the board from the edges, as I often do dual-sided assembly.  For larger boards I put a small stack of washers under the middle of the board to prevent it from deflecting.  That has always worked well.
Jon
Offline alex_
« Reply #23 on: November 18, 2025, 02:08:43 pm »
What are your thoughts on these stencil printers ? various sizes available
https://jlcmc.com/product/b/L15/BR12406/smt-pcb-manual-solder-paste-stencil-printer-1010
Offline khs
« Reply #24 on: November 18, 2025, 04:39:54 pm »
Yes, Multi-CB is our distributor selling to business customers and public institutions only.
But there are three other ways to get the stencil printer: First is Ebay, second is Tindie and third is to contact me via khs-instruments directly.
Btw: We've made a new website https://smt-stencilprinter.com/ to provide smart phone users an easier navigation...
