Author Topic: Transparent ESD safe material  (Read 2707 times)
Offline olkipukkiTopic starter
« on: December 05, 2020, 08:34:41 pm »
Does <subj> exist or someway DIY with a 'generic' material and a special treatment?
Added: Need to be able to machine a custom shapes and drill holes
« Last Edit: December 05, 2020, 08:39:58 pm by olkipukki »
Offline Kean
    • Kean Electronics
Re: Transparent ESD safe material
« Reply #1 on: December 06, 2020, 04:23:26 pm »
I have recently been looking around for something like this myself again.  I know I've looked several times before.
I've used on Acrylic (Perspex/PMMA) in some test jigs and such that I have then treated with Desco Reztore Topical Antistatic - but I have no data on how well that works or lasts.
I also bought a spray can of Techspray Licron Crystal ESD but I'm not sure if I have actually tried it yet.  It is a lot more expensive but seems like it would be a somewhat more permanent treatment.
https://desco.descoindustries.com/DescoCatalog/Education-Awareness-Accessories/Reztore-Antistatic-Coating/10415/
https://www.techspray.com/licron-crystal-esd-safe-coating-3
The following users thanked this post: olkipukki
Offline mxhll
« Reply #2 on: December 11, 2020, 11:35:16 am »
There are some metallised film materials that you could apply to a clear acrylic backing.
(Basically thin antistatic bags, so only mediocre optical clarity).
If it is a 2D shape, you could look at ITO coated glass.
I have no experience in machining, but i can imagine it can be waterjet-cut or machined with abrasive/diamond tooling.
Online tszaboo
« Reply #3 on: December 11, 2020, 01:21:09 pm »
They usually add carbon into the material to make it conductive.
Carbon is black.
So I would look for dissipative materials. Or review the requirements.
Offline GerardG
  • Pick and Place support manager
    • smdassembly.com
« Reply #4 on: December 11, 2020, 01:31:01 pm »
Take a look at this one.
Acrylic antistatic material.
https://wkhgroup.co.uk/materials/antistatic-acrylic-and-polycarbonate
« Reply #5 on: December 14, 2020, 11:47:48 am »
Interesting, but the most available is very thin (around 1mm) for me, above that  - custom and min order $$$   :'(
Offline Whales
    • Halestrom
« Reply #6 on: December 14, 2020, 11:58:17 am »
I wonder if 'smoked' perspex uses carbon as the tinting agent?
« Reply #7 on: December 15, 2020, 09:52:19 am »
The requirements are quite simple - towards 100% transparent machinable and cost-effective material that easy to source from more than one supplier >:D
