Author Topic: Where can I buy this type of "flat" pins for my SMD to DIP pcbs?  (Read 4870 times)
Offline bytestormTopic starter
Hey all!
I am trying to find somewhere to buy this type of pin. The regular pinheaders are not flat, but square, so when used in a IC socket they damages the socket.
However I do find alot of small pcbs with this kind of flat/slim pins that make the adapter pcb fit just like a chip in the socket..
Anyone knows what they are called and where I could buy a larger quantity?
(the measures in the pic could differ a bit ofc)
Thanks!
« Last Edit: July 13, 2018, 07:11:54 pm by bytestorm »
Offline Doctorandus_P
Re: Where can I buy this type of "flat" pins for my SMD to DIP pcbs?
« Reply #1 on: July 13, 2018, 08:47:08 pm »
I typed "single row Header" in Ali and got:
https://www.aliexpress.com/wholesale?SearchText=single+row+header
You get a lot of results with the thick square pins, but also quite a lod with round pins, which are quite a bit thinner.
I measured 0.63mm on the square pins I have and 0.48mm on the round pins and these fit nicely in the "high quality" IC sockets with round holes, but are still to thick for the stamped IC sockets.
The following users thanked this post: bytestorm
Offline Howardlong
« Reply #2 on: July 13, 2018, 08:57:25 pm »
I use "machined" or "turned pin" pin headers extensively for this sort of thing.
« Reply #3 on: July 13, 2018, 09:53:22 pm »
Thanks to both of you for the tips. Sadly, the majority of the places I want to use them for have regular stamped sockets :(.. hmm
Offline oPossum
« Reply #4 on: July 13, 2018, 10:03:58 pm »
0.018" round pins will work with ordinary DIP sockets without damage. They also fit perfectly in machined pin sockets. I use round pin header strips that are 0.018" on one side and 0.025" on the other for making PCBs that plug into DIP sockets.
« Reply #5 on: July 13, 2018, 10:09:53 pm »
Where can I buy that type and what's it called? So I can be sure I get the correct ones :)
Offline TheRadioGeek
    • YouTube Channel
« Reply #6 on: July 13, 2018, 10:17:57 pm »
it looks like it could be one made by zierick??
http://www.zierick.com/pages/sm_edge_sd1699.php
Hope that helps. Good luck.
TheRadioGeek
Offline oPossum
« Reply #7 on: July 13, 2018, 10:19:36 pm »
I think that Mill-Max makes them if you want top quality. All that I have used are from eBay. Search for "round header -socket -female" and look at the pictures. It is easy to spot the type that you want.
A few examples...
https://www.ebay.com/itm/301747757572
https://www.ebay.com/itm/171830872054
---Edit---
Mill-Max 350 series
https://www.mill-max.com/products/socket/350-XX-XXX-00-001000
0.018 round pins also work great in breadboards
« Last Edit: July 13, 2018, 11:54:49 pm by oPossum »
Offline oPossum
« Reply #8 on: July 13, 2018, 10:20:28 pm »
If you really want the stamped metal pins... https://batten-allen.com/uploads/pdf/DIL-Catalogue2012.pdf
They are more difficult to work with than headers.
Offline oPossum
« Reply #9 on: July 13, 2018, 10:47:48 pm »
Some pics of a project I did that uses the 0.018/0.025 round headers.  Eight old 2716 EPROMs that I have no practical way to program are replaced by a single 27C128/256/512 EPROM. The small PCB plugs in to an ordinary stamped contact socket for the 74LS138, and the larger PCB plugs in to one of the machined pin sockets for the 2716. The pins work great for both types of DIP socket.
Offline tsman
« Reply #10 on: July 13, 2018, 11:22:11 pm »
Flip-Pins sound like what you want.
The following users thanked this post: oPossum, bytestorm
Offline Howardlong
« Reply #11 on: July 14, 2018, 09:05:28 am »
Exactly this, the "machined" or "turned pin" pin headers work perfectly well for stamped sockets without deforming them. Usually one side is thicker than the other, aim to use the skinnier side to mate with your socket and solder the thicker side on your breakout. Either way, these header pins are a lot skinnier than your average square cross section header pins.
« Reply #12 on: July 14, 2018, 06:58:11 pm »
Perfect!! Now Ill just have to decipher the datasheet to get the correct ones but now I have all I need! Thanks ALL!! :D
« Reply #13 on: July 14, 2018, 07:27:16 pm »
By the way, have a look at these new ones!! https://www.mouser.se/ProductDetail/575-3169061150000030
Dont see how many is included thou? Or are they really 0,5€ EACH??
Offline Howardlong
« Reply #14 on: July 14, 2018, 10:08:33 pm »
They are usually in single in line break off strips of 20, 32 or 40, like normal headers, but with turned/machined pins instead of square cross section.
I usually buy them in bulk when I’m in SE Asia, but I’ve bought them from Farnell at a price when desperate, Harwin D01 series for example.
Plenty of options on Amazon and eBay, eg:
https://www.amazon.co.uk/2-54MM-40WAY-TURNED-HEADERS-PACK/dp/B01HZU84Z0/ref=sr_1_2?ie=UTF8&qid=1531605204&sr=8-2&keywords=Turned+pin+header
https://www.ebay.co.uk/itm/5-x-32-Way-2-54mm-Turned-Pin-Single-In-Line-SIL-Header/263739555004?epid=22020174471&hash=item3d681a3cbc:g:8m4AAOSwpHpbFv4K
Offline flasonsmts
  • SMT Reflow oven wave soldering machine factory
    • China SMT reflow oven wave soldering machine factory
« Reply #16 on: July 20, 2018, 10:18:05 am »
this pins named leadframe, search on google you will find many suppliers, heres one:
http://www.yrdzkj.com/
but this website is in Chinese.
http://www.ctmgdq.com/enindex.htm
 this is english website, but their output is 50 million per month, I don't know if they will accept your order.
SMT reflow oven wave soldering machine pick and place machine SMT assembly line https://www.flason-smt.com/
