Author Topic: Help re-creating a robot claw  (Read 12648 times)
Offline rea5245Topic starter
« on: December 29, 2025, 08:30:31 pm »
I want to make a non-working model of this robot claw. I'm puzzled by the fasteners. Can anyone tell me what they are, or are they just figments of the artist's imagination?
Offline Gyro
Re: Help re-creating a robot claw
« Reply #1 on: December 29, 2025, 08:45:30 pm »
They look like high tech (the shape imparted by the press tool) solid brass rivets.
Edit: The shape wouldn't be hard to replicate, on one end anyway,  with a small lathe. Actually you could do the complete fastener if you turn two half length pieces, center drill and tap the inner ends and join with some threaded rod. This would make the parts easy to assemble.
« Last Edit: December 29, 2025, 09:01:35 pm by Gyro »
Best Regards, Chris
Offline coppercone2
  • √Y√... 📎
« Reply #2 on: December 30, 2025, 12:40:52 am »
that looks like AI confused grommets with rivets. It does not really make sense because why would you make the rivet thinner in that location
The only 'design feature' of such a thng would be that if you beat on it hard with a punch, you can shear the 'brim' off the rivet and push it out. You have less metal to go through. Kind of like a cotter pin/rivet hybrid thing, inspired by perforated paper. Maybe that is how you make power armor rugged and battlefield repairable for battle with arachnids, so the combat engineers run around with hammers and punches instead of grinders.
« Last Edit: December 30, 2025, 12:44:50 am by coppercone2 »
« Reply #3 on: December 30, 2025, 12:56:11 am »
It's not AI. This is from the cover of BYTE Magazine, April 1985. It was painted by the great Robert Tinney.
I don't know if he was painting from a real model.
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #4 on: December 30, 2025, 01:08:19 am »
I want to make a non-working model of this robot claw. ...
In my opinion I think any model of that would be non-working. Of course I'm using my mind's eye to say this because I don't have a "real" model of it, but I do not think it would function (open and close) at all. I think the two different arms or links on each side he painted would not function together in any usable manner.
What I think it is, is a cool looking claw that the artist dreamed up with little regard to whether it would actually work in any fashion that a real mechanical engineer would design.
« Last Edit: December 30, 2025, 01:26:24 am by xrunner »
« Reply #5 on: December 30, 2025, 01:28:01 am »
I agree.
This is from a cover of BYTE magazine. I have a personal art project of re-creating the covers as photographs of real-world objects.
So I just need it to look pretty. I don't care if it never works.
Offline xrunner
« Reply #6 on: December 30, 2025, 01:35:36 am »
I see.
Well then Gyro's suggestion would work if all you want to do is make it look like the artwork. Brass rivets or tubular rivets or hollow rivets just google those terms.
Offline coppercone2
  • √Y√... 📎
« Reply #7 on: December 30, 2025, 03:00:10 am »
actually it can be one more thing like a rivet that goes into a oversized counterbore and gets smushed in there
I don't know why but you could theoretically do that
or it can also be like a threaded insert  that goes into a counterbore and has a end threaded thing that goes in there. maybe that is what it is, so the depression is just a bolt that is a tiny bit shorter then the insert and the thread is not drawn
it makes more sense then a rivet for precise robots holding pencil. rivet is what you would use for a robot arm to tear something apart, maybe like a junkyard arm, I think it would be for situations where the load drastically and erratically changes
« Last Edit: December 30, 2025, 03:10:53 am by coppercone2 »
Offline jpanhalt
« Reply #8 on: December 30, 2025, 03:25:54 am »
What's pictured is probably artistic license.  That said, you probably want a low profile fastener.  Countersunk sex bolts allow that (attachment).  You can also achieve that with other fastener types. With a barrel nut (as shown) you can easily achieve a tight fastener without clamping what it's fastened too tightly (like a joint).  Another option is self-locking nuts.
The following users thanked this post: Kean
Offline Kean
    • Kean Electronics
« Reply #9 on: December 30, 2025, 10:26:21 am »
Rather than using single use rivets, you might be able to use bookbinding screws, aka Chicago Screws.
With regular motion they would probably come loose without threadlocker, but for your recreation they might be suitable and readily available in brass and different sizes.
I've not seen them quite as depicted in the artwork, but they are available with slotted, cross, knurled, and blank faces - and possibly other styles as well.
The following users thanked this post: Gyro
Offline Gyro
« Reply #10 on: December 30, 2025, 11:04:50 am »
I was trying to remember what those were called. Yes, they would save some effort, they could be touched up with a lathe to get the exact effect (maybe with some thread protection of the male one).
Best Regards, Chris
Offline jpanhalt
« Reply #11 on: December 30, 2025, 12:00:04 pm »
They are apparently the same as sex/barrel screws -- just used for a different purpose.
Offline Kean
    • Kean Electronics
« Reply #12 on: December 30, 2025, 12:41:54 pm »
Oh, yes.  Now the picture you included makes more sense.
I've never heard of them called that, but they indeed seem to be the same or at least within the same classification.
https://en.wikipedia.org/wiki/Sex_bolt
Offline Doctorandus_P
« Reply #13 on: January 01, 2026, 12:03:55 am »
You can buy a robot gripper like that for around EUR 15 from Aliexpress, but they do need an extra (hobby) servo, and they are made quite sloppily. I've thought about drilling up the holes, pressing in brass bushings and using precision axles to make them a bit better.
But overall, there are different mechanisms in these grippers. The cheapest aliexpress version works with two gears to make the sections move synchronously, other versions have two wormwheels with a worm in the center. There are also pneumatic actuated versions.
A generic search shows a bunch of the possible options quickly:
https://duckduckgo.com/?q=paralellogram+gripper+robot&ia=images&iax=images
On a sidenote: In the early 1980's there was a magazine called "Robotics Age". You may find it interesting.
Offline Andy Watson
« Reply #14 on: January 01, 2026, 12:43:11 am »
... you might be able to use bookbinding screws, aka Chicago Screws.
Also known as "furniture screws/bolts" or "furniture joint bolts".
