chem sharp is interesting.
You simply heat it with a torch and submerge it in a salt bucket and it starts reacting (glowing orange) and if you keep poking it it comes out really sharp, but you can make a rounded thing too. The surface finish is pretty nice
Absolutely wear gloves and goggles because it spits out little molten salt balls like a road flare (to a much lesser extent) that sting a little
You don't get a nice machined taper but its a electron emitter so that might not be important. A small blow torch is enough to heat it up.
If you dip a ground tip in there, it kinda smooths it out a little bit, but it can cause some minor scaring of the rod above it..
I got them very clean looking after I washed it, used a dremel brillo (600 grit) and then washed it again. Perhaps its an alternative to flattening the ground tip if your good with it if you want a ground tip. If you just use chem sharp the brillo is not necessary, I just had my diamond grind a bit too fast so there was some discoloration on some of the rods that I just sharpened mechanically, so I decided to buff all of them.
That diamond disk wears out pretty fast on a 1/8 electrode, so the chem sharp has some real potential there, because its less of a pain in the ass.
Certainly the most satisfying sharpening method I have ever seen. the more you poke the sharper it gets.
Does anyone know about exotic tig electrodes? I found that there is yttrium, La, Ce, Zr and Th and mixtures of them. But there must be more. Dysprosium, Strontium, Hafnium, Holmium, Pr, Niobium, Sm, Eu, Gd, Tb, Dy, Er, Tm, Yb. ... the electrode is more interesting then the welding machine to me
